Old 06-08-2011, 04:58 PM   #251
oldman3
oldman3's Avatar
Re: Jimbo's 67 Long bed step side build
Pic 1 Painting the inside of cab with encapsulator paint.
Pic 2 Front part of inside of cab.
oldman3 is offline   Reply With Quote
Old 06-08-2011, 05:01 PM   #252
oldman3
oldman3's Avatar
Pic 1 Making new trans cover to fit 700R4
Pic 2 It was made in a couple pieces, in case we need to get to shifter parts.
Pic 3 Another view.
Old 06-08-2011, 05:04 PM   #253
oldman3
oldman3's Avatar
Pic 1 Making mount for Lokar emergency brake handle.
Pic 2 Close up view.
Pic 3 Handle in place.
Pic 4 Another view.
Old 06-08-2011, 05:06 PM   #254
oldman3
oldman3's Avatar
Pic 1 Doing more finish work on lower part of firewall.
Pic 2 Still working on back of cab.
Old 06-08-2011, 05:11 PM   #255
oldman3
oldman3's Avatar
Pic 1 Started making up the exhaust system, drivers side. Used 2-1/2" pipe.
Pic 2 More of exhaust system.
Pic 3 Routing over the axle, etc.
Pic 4 Not to clear, but you can see some of it.
Pic 5 Pass. side has been tacked in place.
Old 06-08-2011, 05:15 PM   #256
oldman3
oldman3's Avatar
Pic 1 Bracket made to support pipe.
Pic 2 This is my home made isolators, work very well.
Pic 3 Showing both sides in place.
Pic 4 Bothe sides done.
Pic 5 Mount and flanged, so it can be taken apart for coating.
Old 06-08-2011, 05:18 PM   #257
oldman3
oldman3's Avatar
Pic 1 Flange, bracket combo at muffler.
Pic 2 Bracket for back part of exhaust.
Pic 3 Doing final welding.
Old 06-08-2011, 05:21 PM   #258
oldman3
oldman3's Avatar
Pic 1 Exhaust all disassembled.
Pic 2 Box for shipping to HPC in Oklahoma City, Okla.
Pic 3 All parts in box ready to go.
Old 06-08-2011, 05:22 PM   #259
oldman3
oldman3's Avatar
Hope you enjoyed todays post, see you tomorrow.......Jim
Old 06-08-2011, 09:59 PM   #260
bollybib
bollybib's Avatar
Pretty neat. Nice to see some shiny stuff peeking at us now.
I'm fitting up a dual exhaust kit right now (without welding capability), so it's refreshing to watch you cut and fit as you like.
It looks like you have experience working with many types of materials, too. That always comes in handy.
Did you work in a GM St. Louis plant by any chance ?
Your fan,
Jim
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 06-09-2011, 09:54 AM   #261
oldman3
oldman3's Avatar
Your fan,
Jim
Hey Jim, thanks for the comments. No on the St. Louis plant, worked in the Detroit area plants. Detroit Forge and Gear & Axle, I was an Environmental Engineer, so don't know a lot about the other stuff.......Jim
Old 06-09-2011, 04:12 PM   #262
spike38
spike38's Avatar
Great build!!!
Look forward to your future updates.
Spike
spike38 is offline   Reply With Quote
Old 06-09-2011, 07:01 PM   #263
oldman3
oldman3's Avatar
Originally Posted by spike38 View Post
Great build!!!
Spike
Thanks for the compliment Spike, next update starting now.....Jim
Old 06-09-2011, 07:05 PM   #264
oldman3
oldman3's Avatar
Pic 1 Mocking up AC, alt, and power steering brackets before removing engine for clean up.
Pic 2 This is the 327 engine, getting ready to tear apart for checking and clean up, etc.
Old 06-09-2011, 07:08 PM   #265
oldman3
oldman3's Avatar
Pic 1 Bottom of cab in epoxy primer.
Pic 2 The next day bottom of cab being sprayed in regular primer.
Pic 3 Another view, all in regular primer.
Old 06-09-2011, 07:11 PM   #266
oldman3
oldman3's Avatar
Pic 1 Taped up and ready to spray cab with epoxy primer.
Pic 2 From view.
Pic 3 All in epoxy primer
Pic 4 Front view in epoxy primer.
Old 06-09-2011, 07:14 PM   #267
oldman3
oldman3's Avatar
Pic 1 The next day it was sprayed with regular primer.
Pic 2 Front view.
Pic 3 The next day started blocking regular primer.
Old 06-09-2011, 07:19 PM   #268
oldman3
oldman3's Avatar
Pic 1 My son Mark modifing old engie mounts to clear headers.
Pic 2 Drivers side was already cut.
Pic 3 Both sides done, added angle iron to original mount and then bolted on at bottom of frame lip, needed it this way for header clearance.
Pic 4 Close up view. A little grinding and filler, should look good.
Old 06-09-2011, 07:22 PM   #269
oldman3
oldman3's Avatar
Pic 1 Cab sprayed with regular primer again, with guide coat.
Pic 2 Cab ready for final sanding.
Old 06-09-2011, 07:25 PM   #270
oldman3
oldman3's Avatar
Pic 1 Disassembly of frame for sand blasting.
Pic 2 Removing some of the old greasy crap from front crossmember.
Old 06-09-2011, 07:26 PM   #271
oldman3
oldman3's Avatar
Well that should keep you picture junkies happy till tomorrow..............Jim
Old 06-09-2011, 07:51 PM   #272
Cameron 1137
Cameron 1137's Avatar
NO! we want more! haha, JK, looks great so far!
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
Old 06-09-2011, 11:27 PM   #273
oldman3
oldman3's Avatar
Thanks for following the build......Jim
Old 06-10-2011, 02:33 PM   #274
bollybib
bollybib's Avatar
wow i never thought of myself as a picture junkie until now...
i'm a little relieved that you didn't work in St. Louis plant so i won't be tempted to pump you for assembly info haha
movin' right along lookin' fine.
jim
- Jim -
Old 06-10-2011, 09:03 PM   #275
oldman3
oldman3's Avatar
jim
Looks to me like your doing pretty good with the info......Jim
