09-28-2012, 02:07 PM | #251 |
Re: Project#1: Bright Horizons - 68 Swb big block on Air!
Seatbelts look amazing! Btw I had a set of those Flowtechs on my BB and it made tremendous torque with them. Made 633 HP 666 TQ on a 535 with AFR heads. So they can yield some impressive numbers. Ground clearance was just fine on a 4 inch drop in the front. I obviously needed bigger headers but they work fine on a smaller engine. Never let them get hot (like from timing being jacked up( because they will rust in no time then (I suppose any header would though) but otherwise they hold up fairly well.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
09-28-2012, 02:11 PM | #252 |
It's going to look like a barbershop pole when you are done with it.
09-28-2012, 02:22 PM | #253 |
I trust you on the seat belt choice (and everything else), but just was curious what the differences were. The shoulder belts would be nice though as my daughter will be riding with me. Hope to get down there soon. Kind of bummed out I haven't been able to make the trip again since meeting you.
09-28-2012, 03:14 PM | #254 |
VA72C10
Chop is done. Went well on both pieces...sprayed rust neutralizer as preventative maintenance since it was opened up....grinding now welding next. Pictures when done so I can beat the rain...
Looking for a 67-72 swb or blazer project in or around VA. |
09-28-2012, 03:27 PM | #255 |
A guy with a truck
Can you go into detail about where/how you are measuring for your cuts? Seems like precision would be important for this kind of job...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-28-2012, 03:30 PM | #256 |
The suspense is killing me.
I don't care what anyone says it takes brass clankers to chop a roof, you've got the right stuff man! |
09-28-2012, 03:43 PM | #257 |
Posted via Mobile Device |
09-28-2012, 04:09 PM | #258 |
C/10 junkie
Wow this is looking great!!
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
09-28-2012, 07:13 PM | #259 |
VA72C10
I'll respond to everyone later
And I have the sheet I used for measurements I will post and do a step by step....but likely after oct 13th as every minute till then is taken Couldn't weld because of pending rain and distance from plug will explain later. Will need some more grinding and a few small filler pieces made but overall I am happy since I did 99% of the work myself (only had help lifting the old roof off and new one on) but glenn was great with information and they say: "give a man a fish....." I feel confident I could do this again....and could take on a chop top if someone wanted in the future.... Posted via Mobile Device
09-28-2012, 08:19 PM | #260 |
VA72C10
Trying pictures again... not working right now....will try this evening...
Posted via Mobile Device Posted via Mobile Device
09-28-2012, 11:36 PM | #261 |
I dont mean to disrespect but a chop top is a totally different animal. looking forward to pics !
09-29-2012, 12:21 AM | #262 | |
VA72C10
09-29-2012, 12:26 AM | #263 |
VA72C10
Roadster!
09-29-2012, 12:35 AM | #264 |
VA72C10
The thing I learned and would change is choice of tool....the sawzall blade deflected and caused it to not be 100% along the line as it went through despite my best efforts....I will use a cutoff wheel to finish the cuts and if I ever do another...glenn uses the sawzall and recommended it and it works, but not as precice to me.
Also, I would never chop the other top first....with the new roof sitting on the ground it was hard to make sure the tape was at the same angle. I triangulated the best I could, but as you all know...there aren't too many sharp corners on these trucks.... Here's the sheet I made so I can confirm the window openings. Only one clamp on each corner in these pics...a little tweak and it will fit very nice with minimal work. And pics of where it sits as of now....waiting for mon or tues so I can physically get to it to weld. Posted via Mobile Device Posted via Mobile Device
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 09-29-2012 at 12:41 AM. |
09-29-2012, 03:06 AM | #265 |
Nice job dude! Looking forward to the weld-up and final measurements!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
09-29-2012, 11:23 AM | #266 |
Cordless band saw might give you the cuts you want.
09-29-2012, 11:33 AM | #267 | ||
VA72C10
09-29-2012, 01:19 PM | #268 |
I use a mini air body saw for sheetmetal. Harbor Freight (hate that place but I still have some stuff from there) has one for only 12.99 on sale all the time and it works beautifully if you keep it oiled. It is like a mini sawzall and is way more precise than I can get with anything else and I have used everything else many times before. Just don't get the HF blades as they are crap. Get good American made blades if you can find them and you will be able to do much more precise work. Another nice thing about it is you can cut curves even better than an air nibbler does (without distortion). Can't do that with anything else really besides a nibbler or jig saw.
09-30-2012, 01:33 AM | #269 |
VA72C10
Finally received the hidden hitch....had some shipping issues and delays mainly due to me getting the label to them...then the company not printing it out for a week...
10-02-2012, 08:17 PM | #270 |
What furl tank are you going to run under the bed; I am looking for one that doesn't hang below the bumper line. Great work and I appreciate the thread with all the pics.
10-05-2012, 09:57 AM | #271 |
Subscribing to this thread.....Cant wait for the air install.....
------------------------------------------------------ ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560 |
10-05-2012, 11:08 AM | #272 | |
VA72C10
10-05-2012, 11:09 AM | #273 |
VA72C10
Me either....one of my favorite parts! Accuair will be ordered next week!
10-07-2012, 12:53 AM | #274 |
im going to stay tuned looks good keep the pics coming
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
10-08-2012, 11:51 AM | #275 |
VA72C10
Thanks! Decided I'm going to upgrade to shoulder belts on the truck as a bonus. Jastos has really stepped up with some top quality products on the truck and the shoulder belts will just be some icing on the cake Plus, more importantly; His daughter will be riding in the truck with him often so I think it's a great upgrade for safety. Since the factory style boots aren't available...I'm using the closest ones I can find and also make the belts a little longer so they buckle closer to your lap instead of having a buckle sitting on your chest the whole time. Seems both more comfortable and safer to me...
