Old 08-28-2017, 04:29 PM   #251
II_Slow
II_Slow's Avatar
Re: 55*6BT My 55 w/ Cummins power
Maybe - first I need to confirm that the PCM is seeing the Engine Speed Sensor out. I just gapped it over the weekend. The original damper was broken when the '94 truck was wrecked, and the replacement damper (from Cummins) was a larger diameter. The sensor mounting tabs were slotted to align to either, but I had not gapped it to .050 until Saturday. It's gapped now, and wired from the PCM Tach Out to a Dakota Digital Diesel Tach Adapter which has an LED that flashes with pulses in. I haven't fired the truck with the sensor gapped, but last time I ran it wired this way there did not appear to be a Tach Out pulse train (no flash on the interface). I need to read the ESS output signal voltage and see if it changes when it's over the notch in the damper. Just really hard to get to it, and I hate to splice into the sensor cable but I really need to see the voltages.
And yep lots of hours in the rad cover, but it came out even better than expected. I just ordered a new master cylinder reservoir - the last of the old cruddy parts. It should look pretty good under the hood when I get it all painted and cleaned back up. It's really crowded under there - even with all that engine set-back. But I had to have the big radiator, big intercooler, and of course A/C and that stuff had to go somewhere.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 08-30-2017, 07:30 AM   #252
lower50's
lower50's's Avatar
Well it's looking great!! When you get all the bugs figured out you and everyone else will be loving it.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 09-13-2017, 04:32 PM   #253
II_Slow
II_Slow's Avatar
Well the junk hood hinges finally pushed me over the edge. The left and right hood hinges are not symmetric - they open and close on different arcs. The right side is 2 inches high when closed. I just ordered a pair of Eddie Motorsports polished billet hinges MS149-22P. Found some on fleabay and did a chat session on Summit. Sent them the link and they matched the price! Regularly $700, dropped to $571.50. Still redonkulous for a pair of hinges but should be a really nice touch for the engine bay. Being a drag racer, I'm very particular about the engine and engine bay. Also have a new reservoir for the master cylinder. This thing is packed under the hood like a late model truck. All complete there except wiring the cruise control canister, installing the relays for the grid heater, and securing the main harness. I plan on sneaking it down the highway to a local car show Saturday morning.
