04-27-2015, 11:22 PM | #251 | |
Re: Meet Homer (the motor home)
I belonged to a gun collection forum in which ANY talk of mod = immediate deletion and continued talk = banning. I see it both ways, it's your truck so it's your business but once all long wheel base trucks are gone, it'll be a sad world. How much would you have asked for her when the quote above was made? |
04-27-2015, 11:36 PM | #252 |
Nice build, I'm liking it.
About the bumper, the width looks good in the pics, ties in the widening of the bed to the point that people might look at it and know something is different, but hmmm? What I saw was to fill in the empty areas between the bed and the bumper, adding the diamond plate to the bumper and following the fender profiles. I like that the bumper would give some protection to the wide fenders if you were backing up and had a blindspot oops.
Matt 43 |
04-28-2015, 09:52 AM | #254 | |
I would have sold it back then for about $1500 which was what I had in it at the time. I am glad I didn't. Now I way to deep into it to do anything but finish it. I also "see it both ways" which in this case is builders point of view and what a passerby might think is "best for the truck". I believe (like most things in life) there are always at least two sides to every story. If I open up a build thread and check it out I try to always post a "positive" comment. I know I appreciate feedback. If I open up a thread where someone has deliberately asked "What do you think" about a particular item ie;paint, wheels, slammed, lifted, etc. I will tell them what "I think". As to the rear bumper I thank everyone for their response. I hung it last night and would look at it and say "it's ok as is', then walk to the other side angle and say "no it needs to be narrower. I guess I will just let it be for a while. Not even sure it will always live there. Just wanted to hang something there to cover the hole. I also have a receiver hitch to go underneath. Not sure I will do that much hauling, but would not feel super comfortable bumper towing even though they did it for millions of miles before the receivers came along. Not to mention the drops available. I guess my "moral to the story" is this; "If someone asks for opinions they should not be offended when one is given that differs from their opinion". "If someone does not ask for "Your Opinion", but just says hey look what I did. Then maybe we should use caution when giving opinions, or just look for the positive and try and point that out to keep the discussion civil. Someone coming into a thread a month after you remove two tons of motor home and cut out 60 inches of wheelbase out of a frame and saying "you should not have done that". I think they should keep their d*mm opinion to their self. But as always that's JMO
"Life is too short to drive a boring vehicle". Later, Wayne |
04-28-2015, 09:55 AM | #255 |
Two more weeks then time to Rock and Roll on that dually. I saw the bed floor you scored in an ad you are running for the bed sides. Looks solid.
05-01-2015, 11:15 PM | #256 |
Do you think this is too much rake?
Wanted to see what all the fuss is about with these trucks being dropped in the weeds so that's what I did. Literally dropped Homer right in the dirt. Seriously though, needed to work on wiring, headers, tranny lines and all that stuff up front and Homer sits so dang high in the air, so I took off the front tires and gave him a little altitude adjustment so I can reach all the stuff without climbing on a ladder/crate.
05-02-2015, 07:54 AM | #257 |
That's certainly one way to get easier access. Makes getting under it a bit of a challenge I'd imagine.
05-04-2015, 01:10 AM | #258 |
Looking good! Coming along nicely.
05-04-2015, 12:13 PM | #259 | |
Pulled the exhaust manifolds off this weekend and got some Hooker headers installed. Sounds like such an easy thing to do doesn't it? Took hours and a couple trips to the parts store. Bought header bolts, too short. Took em back, longer ones. Would not go into 3 of the bolt holes, hit the tubes. Little drill work on the flange and finally got em in and bolted up. Changed out the master cylinder and brake booster last night. For a change, it went smooth. Sure was nice the push rod attached outside of the firewall with easy access.
05-04-2015, 06:39 PM | #260 |
Hey have you thought about a rolled pan instead of a bumper? could locate the receiver hitch behind the plate if you wanted to tow something. and I like the rake.... Not so much the wheels, I bet the sparks would fly when you stop....Hey all kidding aside. think you will have it at good guys this November? I know what you talking about the headers. just those few bolts, pain in the back side. is that a 67 or 68?? 68 has to go thru the smog test. Its time to take mine thru this month.
05-05-2015, 10:26 AM | #261 | |
I am planning to have it ready for Goodguys. Might take it on Friday, Chevelle on Saturday, probably pass on sunday. Homer is a 68 but no smog with Classis insurance. Still not sure on the seat, so you get first dibbs.
05-15-2015, 10:52 AM | #262 |
any updates?!?!
05-15-2015, 11:17 AM | #263 |
Well, yes and no. in that I mean this;
I had hung the doors and front sheet metal to make sure I could align the doors etc. after chopping the top off & on. Well I had the doors close enough I knew "I could get there from here". Well, my bodyman came out last Sunday and said, "they're close, but let's get em closer", so off came the bumper, front fenders, and we started massaging the door openings. Before he left they fit the hole much better. we will be starting on the final bodywork this weekend. I will take some pics and post em up as time allows. Hoping for a lot of progress this weekend.
05-17-2015, 08:19 PM | #264 |
Well ole Homer moved a little forward this weekend with the help of my bodyman friend Corey. Young man has some serious skills in the body and paint work field.
My goal was to get the inside of the roof that I grafted onto Homer the same color as the rest of the inside of the cab. I didn't want to restore the entire enterior at the time, only paint what is necessary to make the new roof and cab back match. took a bit of time to get the A pillars 100% straight and all lines good but it came out awesome. Here's a few shots.
05-17-2015, 08:20 PM | #265 |
few more
05-17-2015, 08:22 PM | #266 |
couple more
05-17-2015, 08:28 PM | #267 |
The 60-66 GMC/Pontiac guy....
Yeah that's some serious skills.
The cab looks great.. I can't say the same about mine.. lol I'm back at square one. .
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
05-17-2015, 09:04 PM | #268 |
Damn man ,Homer is looking good .Im ashamed to say my old 1 ton is still sitting in the same spot at the bodyshop out back. Im currently trying to get my wife's 81 Trans Am back on the road but Old Ton will not be forgotten for long .Keep the pics coming ,love your progress .
05-18-2015, 01:27 AM | #269 |
Sweet!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
05-18-2015, 07:35 AM | #270 |
I am liking where you are heading with this... I skipped through alot of this build so the question may be redundant but are you putting a Fleetside bed on this or a flatbed...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
05-18-2015, 10:11 AM | #271 |
Thanks Chris. Why back at square one? Hidden damage on your cab?
05-18-2015, 10:16 AM | #272 | ||
During the build I have posted pics of my Chevivrolet. Yep, tailgate is 6 inches wider too.
05-18-2015, 10:21 AM | #273 | |
05-18-2015, 11:34 AM | #274 |
Well that will be cool...
05-18-2015, 12:10 PM | #275 | |
If I use the C&C diff I'll need to cut up my bed floor... Among other issues
