06-09-2018, 05:00 PM | #251 |
BlahBlahBlah
Re: A real BadSeed
Almost 24,000 views. I would say somebody must be looking at it.
06-09-2018, 07:40 PM | #252 |
Re: A real BadSeed
Just makin sure I'm not wasting my time. Lol. I have lots of progress pics comin up!
06-10-2018, 12:50 AM | #253 |
Re: A real BadSeed
Man, this is assume.
06-12-2018, 01:21 AM | #254 |
Re: A real BadSeed
Awesome fab work and build!
06-12-2018, 08:36 AM | #255 |
Re: A real BadSeed
Just keep the updates coming, you do awesome work.
06-12-2018, 07:28 PM | #256 |
Re: A real BadSeed
You aren't wasting your time. If you don't have any response, it doesn't mean no one is looking, it just means they aren't responding. Your post might help someone a year from now, or tomorrow. Even if it doesn't help someone while you're active on this site, you can always look at it like a journal of your build process. And even a way to keep the records of parts you've used or what exactly you did to the truck. Keep posting. Several people are watching.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
06-12-2018, 07:43 PM | #257 | |
Re: A real BadSeed
i just read through your thread earlier today. im a rookie!!!, and always enjoy reading the veteran guys post's of stock and custom builds...... please keep posting, it helps us ALL
Steven '67 SWB, 250ci, 3OTT.......this is my first build...... I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71" Last edited by stevenfromtexas; 06-12-2018 at 08:15 PM. |
06-15-2018, 03:06 AM | #258 |
Re: A real BadSeed
Ok. Thank you guys for responding. I'll keep going. Haha.
I came across the earliest picture I know of that was taken of the truck when my dad was driving it and working a ranch. The little girl in the picture is my 47 year old sister. And I was about 5 years from being born. Doing the math and a little estimating, that primer was on a 7 year old truck. It's like it's never had a shine on it. Lol. #BadSeed #RanchoAelegria |
06-16-2018, 05:08 AM | #259 |
Re: A real BadSeed
I designed some custom mounting feet for my A/C condensor to separate it from the radiator. There's a slight bend in the mounting feet. The core support is double walled where this mounts so I drilled through the first layer hiding the mounting screw inside the double wall. This will all be behind the radiator.
*The condensor that showed up in the mail was damaged, making it my mock-up condensor. That's why it looks bent in the pics. They sent a replacement and told me keep the junk. |
06-16-2018, 05:08 AM | #260 |
Re: A real BadSeed
The mounting feet were cut by DotLowRides in Texas
06-16-2018, 07:10 AM | #261 |
Re: A real BadSeed
Cool vintage pic man . Looks like we're about the same age give or take I'm a few years younger ... your work is very inspiring . So many good ideas .... this thread has 25k views . Keep it up dude !
M.A.G.A. |
06-16-2018, 09:07 AM | #262 |
Re: A real BadSeed
looking sharp. keep those pictures coming.
Project Double Tap http://67-72chevytrucks.com/vboard/s...d.php?t=555901 69 Olive Verde http://67-72chevytrucks.com/vboard/s...d.php?t=734720 |
06-16-2018, 02:50 PM | #263 |
Re: A real BadSeed
I found some billet mounting straps for a roll bar light mount. They worked great to hold my A/C drier canister
06-16-2018, 02:54 PM | #264 |
Re: A real BadSeed
Got my Hedman Hedders the other day. These fit real nice.
Hedman 69020 Standard Duty Uncoated Mid-Length Headers |
06-16-2018, 02:59 PM | #265 |
Re: A real BadSeed
I bought a small oil cooler with a 7" electric fan. I made a custom shroud for it. This this will most likely be located behind the cab, but it's still up in the air for now.
06-16-2018, 03:03 PM | #266 |
Re: A real BadSeed
I tapped the screw holes for these air-lift sensor mounts, installed my little 3H covers and found a home for the set up on the frame.
06-18-2018, 11:03 AM | #267 |
Re: A real BadSeed
Love the backstory, and seeing this build come to life! Well done man!
06-18-2018, 09:33 PM | #268 |
Re: A real BadSeed
07-03-2018, 01:44 AM | #269 |
Re: A real BadSeed
I shortened the trans crossmember to be installed on the boxed in frame. I drilled holes and welded the nuts to the inside to create a captive-nut situation. All the crossmembers are installed with this method
07-03-2018, 01:50 AM | #270 |
Re: A real BadSeed
I'm remaking the carrier bearing crossmember to accommodate the boxed in frame as well
07-29-2018, 11:57 PM | #271 |
Re: A real BadSeed
Couple more tubes
07-29-2018, 11:58 PM | #272 |
Re: A real BadSeed
I designed some more parts and after a looooooong shipping wait, I got to get them in.
07-30-2018, 12:00 AM | #273 |
Re: A real BadSeed
They fit nice
07-30-2018, 12:17 AM | #274 |
Re: A real BadSeed
Tacked in and checking exhaust for clearance
07-30-2018, 12:19 AM | #275 |
Re: A real BadSeed
Had to push it out and work on the minitruck a little
Tags |
67 c10, badseed, marley marvelous |
