![]() Join Date: May 2007
Re: '50 chevy 3100
woop woop! nice progress!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
Re: '50 chevy 3100
looks great man!
Re: '50 chevy 3100
Thanks guys, little stuff like this makes me feel like I'm learning a few things lol.
I'll need to repair right rear fender next.
1950 Build |
Re: '50 chevy 3100
Gotten a few things done lately. I think I've gotten all my cab leaks fixed. As I mentioned in another thread, the cowl vent seal is really thick. It works but I think I might take the advice to change it out.
We have had a lot of rain so it got tested out quick. Realized I had a little trickle from wiper arm seal. So I replaced both of those next. Had some light showers and it looks good so far, I'll see after a heavy rain. Cleaned up and painted my new battery tray. Seam sealed the edges but did drill two little holes for collected rain water that managed to get through. Welding skilled have improved since first doing original patches, me and a buddy went over a spot in the floor that I didn't like, and everything else looks good. Pulled out transmission crossmember. I had originally only had bolts run through it to keep it from moving and spinning. I decided it needed to be welded and I'm much happier with it. Even though it wouldn't be seen I wanted it to be done right. In another thread I have been getting wiring harness ready. Buying a few things and getting a full list and plan out before I go nuts. Also got a new alternator bracket in, next build I'll try not to misplace anything, and new thermostat housing to point hose towards radiator. Clamps are on the list but hoses are cut and fitted. A lot of this stuff is taking me a while and in a few cases I take a step back to redo something, but I know when I'm done it'll be a solid truck. Maybe not the prettiest lol but body skills are improving.
1950 Build |
Re: '50 chevy 3100
I didn't get a picture, but I put the driver side running board on too.
1950 Build |
![]() Join Date: Sep 2017
Re: '50 chevy 3100
Good progress.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
Re: '50 chevy 3100
Is the running board to cab corner gap right?
1950 Build |
Re: '50 chevy 3100
looks right
here is a pic of my 51 before it was disassembled |
Re: '50 chevy 3100
Thanks! I wasn't finding any good close up pics.
Got passenger side running board on and went over both again. I can hop up and down and no squeaks or groans! Rained some last night, no water in cab! I'm thinking a rubber mat and a I seat cover for now. I'll be prettyfying it slowly over next few months lol for now I just want it to run, be solid, and work out any bugs once rolling. I think I can start running wires after vacation!
1950 Build |
Re: '50 chevy 3100
Oh it's fun but its not 6 days in Hawaii!
First summer me and my wife are both teachers, school is done, debts caught up and lots of time for a trip or two.
1950 Build |
Re: '50 chevy 3100
Congratulations! You two have fun!
Re: '50 chevy 3100
Quick trip to father in laws before we leave Thursday, just got back and drove through a heavy rain. When it stopped I went out with a flashlight to check for and wet spots or trickles into cab. Dry!! I now feel comfortable getting wiring in after we get back.
1950 Build |
#13 |
Re: '50 chevy 3100
Good deal. Have fun.
#14 |
Re: '50 chevy 3100
Waiting on first of three flights to get home. A lot of time to kill. Thinking about my wiring harness buy list lol.
1950 Build |
#15 |
Re: '50 chevy 3100
Welcome home.
#16 |
Re: '50 chevy 3100
Been messing with electrical when I find time. Kept most of it on another wiring thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=750748 A couple of things have slowed me down. For example I didn't have the correct plug for steering column and I didn't get any smaller ring terminals, I think I need some # 10s. 7/32 size right? I'll get them ordered Friday. I have been driving around with the slip yoke from my driveshaft in the car for weeks. Finally managed to be on the side of town with driveshaft shop. 55 to shorten, 50 to balance and whatever u joints are. Showed me where to measure and said to pull it out 1 inch. Now to see how long it takes me to take them the driveshaft lol.
1950 Build |
#17 |
Re: '50 chevy 3100
Wiring is still on the other thread but I have gotten a few other things done lately too. The c10 exhaust got shortened and installed. I would not have attempted cutting and welding it a year ago lol. I was playing around with the fuel filler and I think I nailed it! Cut the factory one down and welded the tube from the factory one and onto the shortened piece. It came out pretty good so I'm gonna keep it.
Today I put the parking lamp to turn signal conversion kits in the grille. I also hooked up the horns. The grille is on! For the first time ever! Really, the grille and a few other things weren't bolted on so it took me over 2 hours to undo a few things and to get it all bolted up. The grille was a bit beat up. I'm pretty sure someone had had a small fender bender. I had to put a bunch of screws in it and I bent and beat it until it looked half way decent. It was rusted too so I used the wire wheel and painted it black.
1950 Build |
#18 |
Re: '50 chevy 3100
The grill turned out nice. Good job on the fuel tank and exhaust work.
#20 |
Re: '50 chevy 3100
Oh I still have some bodywork left, but I jump around a bit lol.
1950 Build |
#21 |
Re: '50 chevy 3100
go man go!
#22 |
Re: '50 chevy 3100
Productive morning today.
Ignition switch, headlight light switch, fan switch, dome light, and my little cluster of gauges installed! Yesterday I got the radio and speaker in but I still need to wire them up.
1950 Build |
#23 |
Re: '50 chevy 3100
That's very difficult upside down. Still, nice work.
#24 |
Re: '50 chevy 3100
Headlights in!
I also pulled the driver door off to work on it easier. Awhile back I had to repair a crack in the middle of a dent in the door. A PO had filled the area with lead and bondo. Not sure when the crack occurred, when the dent happened or after a while but it was a pain. Found out part of the reason there was so much bondo was due to a couple of high spots. Someone used enough bondo to clear the high spots and smooth out a nice door lol. So the first thing I did today was to beat those down.
1950 Build |
#25 |
Re: '50 chevy 3100
Messed with the door off and on all day. A little paint to help me see it in the light and it is much better than before!
In the right light I can see it still needs a little more attention but it turned out good. It was hard to be patient.
1950 Build |
