#251 |
![]() Join Date: Dec 2018
Re: My New Truck
You'll have have to set your video's settings to ether public or unlisted for us to be able to see it. Unless you can figure out how to share a private video I have never done it so I don't know how it works on those.
Unlisted usually is the best way to go if you want to share a video but don't want it coming up in the YouTube search results.
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 Chevy c20 350 4speed 1998 Chevy c1500 4.3L 5speed 1999 Chevy k1500 Suburban 5.7L auto 4x4 2002 Chevy s10 4.3L auto 4x4 1971 Mercury Monterey wagon 400 auto Plus other misc. ... To many projects! |
#252 | |
![]() Join Date: Jun 2019
Re: My New Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 |
#253 |
Re: My New Truck
Fired right up! Sweet
#254 |
Re: My New Truck
Video worked.
I know you mentioned & swapped the cam but I never noticed the details/specs regarding your choice. What did you go with?
#255 | |
Re: My New Truck
Its a moderately priced cam. You can read more about it in the link below. Warning it you do a camshaft like this you WILL need a stall converter! https://sites.google.com/site/sloppy...sloppy-stage-2 Chev Gen III/IV (LS Series) 3-Bolt '97-Present Adv. Duration: 283/286 Duration @ .050": 228/230 Lift: .585/.585 Lobe Separation: 112 LC If you run this can you do not need to change the pushrods. Only the valve springs need to be changed to the PAC1218’s.
#256 | |
Re: My New Truck
#257 |
Re: My New Truck
Ok, on the cold air intake here is what I did. I took the factory Silverado air box (2001-2007). And I just modified it. I took off the outside cold air intakes where the Silverado would get its cold air from. I plugged those as the stock Silverado cold air intake tubes popped right out. I had some old gm plastic parts laying around, so i cut the up to fill these old Silverado cold air intake tubes. Baking soda and SUPER GLUE make a real good filler/glue for this (albeit messy).
If you’re wondering why i just didn’t cut a hole in the rad support. That isn’t going to happen, as my rad support was in perfect condition after 50 years so I am not going to cut it up. So instead i will punch a hole in the aftermarket inner fender liners.
#258 |
Re: My New Truck
So i just went to my local metal dealer and bought 4” aluminum tubes 24” long. (Didn’t really know how much I needed). I reset the air box in the right front corner of my Squarebody and after a lot of measuring and calculating i took the 4” hole saw and punched a hole in the bottom of the air box. I then used little “L” brackets to mock up where i wanted the tube. The bolts were later removed so air flow would not be restricted.
In the air box and on the outside of the air box any gaps i filled with a silicon type of caulk to make sure only the air outside the engine compartment is getting into this air box.
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 Last edited by Factory Guy; 06-15-2024 at 10:17 PM. |
#259 |
Re: My New Truck
For some reason this silver tube picture won’t save in the previous file.
#260 |
Re: My New Truck
Not having much luck uploading photos tonight. Heres a few more.
#261 |
Re: My New Truck
Here's some more of the air box...
#262 |
Re: My New Truck
For the intake tube I used standard 4" aluminum tube from the local metal dealer. I scuffed it up real good with a scotch brite pad then painted it with some Duplicolor Truck bed liner. Nothing fancy here.
#263 |
Re: My New Truck
I think it came out really nice!
#264 |
Re: My New Truck
Many thanks to TKCR for the "new" 3 point seat Belts. I think they look pretty much like they were installed in this 1973 from the Factory...which was my goal!
#265 |
![]() Join Date: Oct 2014
Re: My New Truck
Holy smokes! Those look great in there!
![]() Absolutely beautiful
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#266 |
Re: My New Truck
Nice!
#267 |
Re: My New Truck
So I got the LS up and running. Yeah!
I got the base tune from Brendan at Lt1swap.com. But now I need to get a real tune done. Anybody know of a place in Kansas City that does LS ecu tuning?
#268 | |
Re: My New Truck
He is great!
Seth Instagram: sethrosa11 My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225 1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802 1978 Big 10 http://67-72chevytrucks.com/vboard/s...d.php?t=771383 |
#269 |
Re: My New Truck
Does Andrew do GM stuff? I thought he was just doing Holley EFI tuning?
#270 |
Re: My New Truck
Good point. I am not sure. I would email him. Its worth an ask.
#271 |
Re: My New Truck
I sent him an email! Thanks!
#272 |
Re: My New Truck
Pretty sure he's strictly Holley based remote tuning. He's also in Texas now as well.
#273 |
Re: My New Truck
Rear Sway Bar?
Anybody got a source for Rear FACTORY SWAY BAR Bushings? Yes I have checked LMC Truck and Classic truck Parts of America (Riverside MO), Rock Auto and etc. Yes the Rear Sway Bar, was installed at the factory by GM.
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 Last edited by Factory Guy; 01-08-2025 at 03:58 PM. |
#274 |
Re: My New Truck
What is the bar diameter?
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
#275 |
Re: My New Truck
My dually had one before the 4-bar/bags/Panhard bar swap. I don't recall anything special about the bushings so whatever OD the bar is should work.
| Bookmarks |
