#251 |
![]() Join Date: Oct 2012
Re: My 1967 Chevy K20 Build Thread
Clay, nice job restoring the inner heating assembly. It looks brand new.
Scott 1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#252 |
![]() Join Date: Dec 2022
3/1/2025
The engine is running! A few weeks ago I was able to get the engine to fire up and run long enough to break in the cam, but I had a few issues. In addition to some oil and coolant leaks there was a timing and vacuum issue that just wouldn’t allow the motor to run right. It was running hot and just seemed to dog quite a bit. I wasn’t really sure if I had a timing issue, or a fuel issue or what, so I opted to take the carburetor and distributor down to an old school place out here in Phoenix called “Carburetor’s Unlimited”. The owner, Bruce, identified a few issues right off the bat and recommended a recurve on the distributor along with a Pertronix ignition setup and coil. He also went ahead and redid the carburetor and even plated it the correct gold-ish color! I got it all reinstalled and she fired right up and was purring like a kitten! Per Bruce’s recommendation, we set the initial timing to 8* BTDC and the old 327 is humming along nicely! I still need to do final adjustments and will get the timing dialed in more after the truck can move under it’s own power. Here is a quick video of her running! https://www.youtube.com/watch?v=kczJtPlMQU8
Clayton Sikes Peoria, Arizona 1967 Chevy K20 "The Town Truck" Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
#253 |
![]() Join Date: Dec 1999
That is great to have a place like that close by.
Saw your video on YouTube before I saw your post here. When I watched the video I thought the fan doesn't stick out of the shroud very far. Might be far enough, but I know you usually want the fan about half in and about half out of the shroud. Hopefully just something to be mindful of and you don't have cooling problems.... |
#254 | |
Honestly, I have no idea how far it needed to be in. LOL I just put it on the way it came off. I was actually thinking about putting a clutch fan on it anyway. We will see what happens and if it overheats I will figure something out. Clay
#255 |
Saw in the video, it looked like you got your brake lines sorted out.
For your exhaust did you use the factory type muffler hanger? It's the flat metal strap with the 'eye' bolt and the 'eye' hook? When I redid mine I think I ended up with an extra set... |
#256 | |
I was able to reuse the factory muffler hanger except for the flat strap piece itself. That was too far gone to salvage. The bracket itself was able to be cleaned up and reused. The strap was a standard 1950's Chevy muffler strap that I ordered from Napa. Here is a link to the strap I used: https://www.napaonline.com/en/p/EXH3...e_google&gQT=1 Clay
#257 |
chevy truck fan
Clay , great to hear that the engine is running... nice job all the way thru!!!
#258 | |
Engine sounds great! Good update
#259 | |
Clay
#260 | |
Thanks Scott! Yeah, Bruce definitely knows his craft for sure. He is a walking encyclopedia of carb and dizzy facts! Clay
#261 | |
Clay
#262 |
Good to hear that fixed the issue. So the truck moved under it's own power???
#263 | |
![]() The clutch wouldn't fully disengage and the brakes are still a bit spongy.....I am glad Kelly wasn't around...that would not have instilled a lot of confidence. Clay
#264 |
chevy truck fan
Clay,... too funny!
I completely understand though... After a few builds you will learn like I have and to put a bunch of shop equipment and tools in front so that when that MIGHT happen then you just mess up the tools & not the house!... the wife will be ALOT more understanding & not NEAR as mad!!! funny how that is....
#265 |
chevy truck fan
P.S. very cool to know it is under own power! great job! very cool!!!
#266 | |
I can fully relate! I have run just about every vehicle I own into the house at one point or another....my wife is fully prepared! LOL Clay
#267 |
3/2/2025 - 3/31/2025
Engine wiring and initial test drive I have spent the past few weeks tinkering around with the wiring and brakes. I have more or less completed the engine bay wiring including building my own battery cables out of welding cable and using military style battery terminals. I am trying to keep the engine bay looking as factory as possible so I have been wrapping the wires where appropriate with vinyl tape versus using wire loom. The new AAW harness is just fantastic! It is of excellent quality and the instructions are super easy to follow. The brakes have been a bit of a challenge to get figured out. The main challenge is that some of the flared ends have a slight leak. I believe that this is due to the lines being stainless steel and you really have to crank them down to get them to seat right. That is kind of scary as I don’t want to go all gorilla on them and strip anything. The “Tee” fitting on the front driver side is the bigger problem…..It seems to weep a bit where the banjo bolt goes through it. I put new copper washers on it, but it still leaks so I have to figure that out. The front left wheel cylinder also has a slight weep where the rubber line goes into it. I have tightened that up as far as I dare to, so I think that it may just be a bad casting….that is all too often the case with a ton of these parts coming from China. I also had to pull the rear drums to adjust the brakes there and to fix a drip that was leaking gear oil out of the rear drum oil seal. I must have nicked it putting the axle together. The Chinese drums don’t have a knockout in them to adjust the star wheel, so I had to pull everything apart to get it adjusted somewhat close. I now have a solid pedal, but I will need to address the fitting weeping. I have the engine running ok….I still need to do some adjustments and it smells like it is running rich, but I was finally able to take her around the block on the inaugural drive! For the first time in over 2 years I got to drive the old girl!! She drives just like I remember these old trucks drive…..like ****! LOL!! I have become way too accustomed to power steering, power brakes and an automatic transmission…..but I was ****ting in tall cotton when I heard that old Chevy whine as I rolled her around the block. Lastly, I spent a few days doing some cutting and buffing of my ****ty paint job…..it still looks amateur-ish, but not too bad. She shined up pretty good. I also had to install the “20” emblems on the side just for visual effect to break up the 2 acres of blue sheet metal. After reading another thread about barrel nuts, I picked some up at Napa so I wouldn’t have to pull the fenders to use the speed nuts on the emblems. They kind of work their way out a bit, so I may have to put some locktite on the studs to keep them in place.
#268 |
And.....just so I can kinda keep up with Scott (loudchevy) on his build, here is a quick video of the inaugural test drive. :-)
It goes without saying that my puny little SBC 327 doesn't sound nearly as cool as his BBC 454! LOL!! https://www.youtube.com/watch?v=dhAN6LaPID0
Clayton Sikes Peoria, Arizona 1967 Chevy K20 "The Town Truck" Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 Last edited by Chaparralman1974; 03-31-2025 at 11:33 AM. |
#269 | |
Lots of time and effort to get to this point. Great job!
#270 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
It sure looks good to me! Sounds great too...
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#271 |
![]() Join Date: Aug 2004
That is sharp! Love the blue/white
Congrats on the first drive, that's a great feeling.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#272 |
Sharp! Great job.
#273 |
Congratulations Clay,
It’s got to feel pretty good to be back behind the wheel of a REAL truck again! I’m jealous of that beautiful blue and white paint job. Sure wish the old farmer that had my truck originally had left mine that color, instead of (badly) changing it. Now comes the fun part-bolting on all the shiny parts, fine tuning that great classic running gear and putting on some MILES! Just hope you have more luck keeping the gear oil on the INSIDE of that T221 than I have so far. Have fun, Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
#274 | |
![]() ![]() Join Date: Jul 2003
Happy to help. They are a total biatch to R&R. My 70 Blazer's spring broke in 1992, and it was not a joy to replace.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#275 |
![]() Join Date: Apr 2008
Sounds and looks good!
71 C10 72 K20 72 K10 Super Kirk |
| Bookmarks |
