Old 11-27-2024, 02:54 AM   #251
pjmoreland
pjmoreland's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Cleaned up and painted the replacement hub. There is a slight difference between the new and old. The inner seal depth is not as deep on the replacement. The seals I removed from my originals were thin (.25") even though the hubs appear to be made for the .31" wide seals everyone sells. I have been looking all over the place, and I can't find any .25" wide seals. The old thin seal I've got says, "Made in Singapore" and "UF 0215E" on it, but searching for that goes nowhere. The wider seals will probably work just fine.
pjmoreland is offline   Reply With Quote
Old 11-27-2024, 03:50 AM   #252
pjmoreland
pjmoreland's Avatar
I found a seal that should be the correct dimensions. It's SKF 24904. The I.D. and O.D. are the same as seal 442380, but it is .25" wide. It's what's spec'd for a 1974 Dodge W100. I ordered a pair of them.
Old 11-27-2024, 09:49 AM   #253
loudchevy
loudchevy's Avatar
Originally Posted by pjmoreland View Post
Haha. Yep! Seems like there are more trucks with speaker holes in the doors than without.
I got lucky and the PO cut them out above the kick panel closer to the window crank. Didn't bother to patch them since new door panels would cover them up. Never seen (2) speaker holes cut in a door, that was a first.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 11-27-2024, 11:06 AM   #254
pjmoreland
pjmoreland's Avatar
That was convenient. Two speaker holes per door is a first for me, too. My '68 had a round speaker hole cut down low on both doors. I bought a replacement door on one side due to exterior damage, and the replacement had a speaker hole, too.
Old 11-27-2024, 06:06 PM   #255
pjmoreland
pjmoreland's Avatar
I love the consistent progress! What's next on the list to tackle?
I missed your post a couple of weeks ago. Sorry about that! Here's my rough to-do list at this point:
Reassemble front hubs
Finish patching door speaker holes
Replace the center section of the dash to fix a butchered radio hole
Replace rocker panels
Replace rear window
Clean and paint frame rails
Rebuild entire brake system (new hard lines, booster, master cylinder, etc.)
Install parking brake cables
Convert 2WD NV4500 transmission to 4WD by replacing output shaft & tail housing
Replace NP205 long input shaft with a short one
Install engine, transmission & transfer case
Measure for rear driveshaft and get ordered
Clutch linkage
Go through entire electrical system and make repairs as needed
Build a tach gauge cluster
New bed wood
Reupholster seat
Those are the big items at this point.
Old 11-28-2024, 07:21 PM   #256
68bowtie
68bowtie's Avatar
You’re doing quite a bit more than I expected! Very cool.
Looking great, keep it up.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Old 11-28-2024, 08:20 PM   #257
pjmoreland
pjmoreland's Avatar
A few of the items on my list aren't strictly necessary, but they are easier to do now than later when everything is assembled.
Old 12-03-2024, 12:46 AM   #258
pjmoreland
pjmoreland's Avatar
I have all of the parts now to put the front hubs back together. I installed the bearing races, pressed in the studs and installed the inner bearing seal. One of the hubs has a deeper bore for the seal, but the hub is taller overall, so the seals on both hubs are at the same depth relative to the bearing.
Old 12-04-2024, 02:22 AM   #259
pjmoreland
pjmoreland's Avatar
Spent the evening attempting to reassemble the front hubs. Discovered three more bad parts though, so I only got one hub back together.
Old 12-06-2024, 04:07 AM   #260
pjmoreland
pjmoreland's Avatar
Spent the evening working on the passenger side door. Started by taking the interior panel off. One of the screws didn't want to come loose, so I had to drill it out. The threads in the square nut survived the ordeal.
This truck was outfitted with power locks at some point. Those are going bye-bye.
Old 12-06-2024, 04:12 AM   #261
pjmoreland
pjmoreland's Avatar
Cleaned out the inside of the door and then removed it and brought it into the garage for some repairs. Welded up the two speaker holes and some extra mirror holes. Also replaced some slotted screws holding the window regulator in with factory screws.
Old 12-06-2024, 04:15 AM   #262
pjmoreland
pjmoreland's Avatar
Found some rust in the interior bottom front corner of the door, so I fabricated a little patch panel.
Old 12-06-2024, 04:17 AM   #263
pjmoreland
pjmoreland's Avatar
Then I welded in the patch panel. I've got lots of grinding to do now.
Old 12-06-2024, 09:11 AM   #264
clay68c10
clay68c10's Avatar
Man, you nailed that curve. Nice work.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-06-2024, 11:49 AM   #265
pjmoreland
pjmoreland's Avatar
Thanks! I cut two thick pieces of steel to match the curve and then clamped the sheet metal between them and hammered it over to form the curve. I shaped the little squiggly part with a combination of pliers and hammering.
Old 12-06-2024, 01:48 PM   #266
loudchevy
loudchevy's Avatar
That's a nice trick. I'm banking that one in the vault.
Scott
2003 Tahoe Stock
Old 12-07-2024, 09:22 PM   #267
clay68c10
clay68c10's Avatar
Slick!
13 Tahoe LTZ
Old 12-07-2024, 10:59 PM   #268
pjmoreland
pjmoreland's Avatar
Worked on the doors and the passenger side rocker panel today. Smoothed out the welds on the passenger door and covered them with primer for now. Also filled in some extra mirror holes on the driver door.
Old 12-07-2024, 11:05 PM   #269
pjmoreland
pjmoreland's Avatar
Spent the rest of the day replacing the passenger side rocker panel. Started by drilling out the spot welds.
Old 12-07-2024, 11:11 PM   #270
pjmoreland
pjmoreland's Avatar
More drilling. I cut the bulk if the rocker off once the bottom edge was the only remaining attached portion. Then I discovered that the bottom lip only had one spot weld in it. That would explain why the driver side rocker is split open along the bottom edge. There was a rust hole back near the cab corner, so I welded a patch over it.
Old 12-07-2024, 11:18 PM   #271
pjmoreland
pjmoreland's Avatar
Cleaned up the metal with a wire wheel and then primed and painted it. I drilled holes in the ends of the new rocker panel and along the bottom edge of the floor. I then set the rocker in place and used a scribe to mark the locations of the holes. I removed the paint in the hole locations to prepare for welding. Welded the new rocker in place by filling the holes with rosette welds. Still need to smooth out the welds. I will apply seam sealer around the perimeter of the new rocker. Ran out of daylight.
Old 12-08-2024, 04:12 AM   #272
'68OrangeSunshine
'68OrangeSunshine's Avatar
Two questions, Pat:
What plant did that Stepside roll out of?
What kinda mirrors will you be using?
Old 12-08-2024, 08:13 AM   #273
1970cstblazer
1970cstblazer's Avatar
Thumbs up Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Amazing the inner rockers were intact. Definitely not from the salt belt. Nice fitment on the new rocker.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 12-08-2024, 11:27 AM   #274
pjmoreland
pjmoreland's Avatar
Originally Posted by '68OrangeSunshine View Post
Two questions, Pat:
This truck was built in St. Louis.
I will be installing these stock mirrors. Thankfully, the stock holes are still there.
Old 12-08-2024, 11:30 AM   #275
pjmoreland
pjmoreland's Avatar
It's fairly common around here. Rust in the roof is common here. I believe I'm good there though because someone resealed the drip rails at some point.
