Closed Thread
Old 08-29-2010, 07:43 AM   #2776
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: How about some pics of 60-66 Trucks
My '63 910 chassis has that option.
You always come up with the coolest stuff aero
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline
Old 08-29-2010, 08:17 AM   #2777
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
this is just... WOW! love it!
jonzcustomshop is offline
Old 08-29-2010, 08:29 AM   #2778
lakeroadster
My truck had a set of those helper leaf springs on it. The PO had heated the original coils to lower the truck and there was only about an inch of travel before the helpers would kick in.
When driving the truck over bumps in the road the helper springs would engage and bounce the back end up into the air. Like an amusement park ride .
The way the PO mounted the helper springs was to take a piece of I-beam, cut it in half down its length and then he welded the web and flange of the beam to the frame.
The other scabbed on plate must have been a rear bumper mount?
PO's... go figure....
lakeroadster is offline
Old 08-29-2010, 11:21 AM   #2779
Clark Davis
Hi Everyone
Here is some pictures of my 1965 GMC. It has a small block 350 motor with a 4 speed transmission and a 12 bolt rear diff with 4:11 gears. I just finished the 4 link suspension for the truck.
Clark Davis is offline
Old 08-29-2010, 01:42 PM   #2780
markeb01
Senior Enthusiast
markeb01's Avatar
Sadly with a lot of previous owners, these were just yard trucks and they really didn’t care what the modifications looked like, as long as they sort of worked. That looks better than the 57 Chevy sedan I bought. It had a 350 installed, and the engine mounts were stick welded cold. Both had broken off, and one side was held on with vise grips while the other end was help up with a C clamp! I thought it prudent to tow it home.
Originally Posted by Clark Davis View Post
Hi Everyone
Beautiful work, can’t wait to see it finished.
markeb01 is offline
Old 08-29-2010, 05:23 PM   #2781
willyp
willyp's Avatar
Air Lift link
http://shop.airliftcompany.com/
I used their bags tucked into the rear coil springs. They'll need to know the width inside of your springs and height required.
The bags were not a GM item in those years. The Chevrolets had a helper leaf spring.
i just removed these from my truck. when i installed the 6 inch drop the aux leaf springs rested on the ends of the rear control arms. what a PITA to get off.
The price of cool aint cheap.
willyp is offline
Old 08-29-2010, 06:45 PM   #2782
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
1960 and 1964 Timbren's have a pair of these?
http://www.timbren.com/ses-kits.htm
aerotruk63 is offline
Old 08-29-2010, 06:48 PM   #2783
stripingbyakin
stripingbyakin's Avatar
Here's my rig..
-Josh
Negative Camber Kentucky Chapter
1964 Short Fleet
stripingbyakin is offline
Old 08-30-2010, 08:35 AM   #2784
lakeroadster
Not Mine..
Old 08-30-2010, 12:49 PM   #2785
markeb01
Senior Enthusiast
markeb01's Avatar
The hood inserts look cool. Is the vent panel chromed?
markeb01 is offline
Old 08-30-2010, 12:51 PM   #2786
Malibob
Malibob's Avatar
stripingbyakin- really like the truck man. good colors too.
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline
Old 08-30-2010, 01:44 PM   #2787
Dan in Pasadena
Dan in Pasadena's Avatar
No offense intended but the only thing I was thinking was that truck would be perfect WITHOUT the chrome vent panel and hood vents.
Different strokes for different folks. Or in this case, "different trucks for different...uh...er...."...you know what I meant
P.S. I'd forgotten how awesome the slot dish mags were when they are in as-new condition. You pretty much only see them dulled down nowadays. In the mid '60's if you were WEALTHY enough to afford those (and no one would have put them on a truck in those days) you were the schit! I remember seeing them on a dark green matallic GTO in '68 and thinking that was the most beautiful car I would ever see.
Dan in Pasadena is offline
Old 08-30-2010, 03:35 PM   #2788
lakeroadster
Yes it was chromed.
The black truck had a lot of personal touches. For instance it has wood grain in the body side molding, and the same woodgrain on the little chevy emblem located cab trim.
And I liked the hood inserts also (but as you can see from the picture of my truck below, I am hardly impartial).
Old 08-30-2010, 04:48 PM   #2789
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yes it was chromed.
Got any from under the hood? Curious how they mount.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Old 08-30-2010, 04:52 PM   #2790
Dan in Pasadena
Lakeroadster,
I hope you didn't takre my opinion the wrong way. I did not mean to offend. I think the hood insertts are practical from the "letting heat out" stand point, but I think I would have preferred louvers. Then again, louvers are expensive and those hood inserts could probably junkyard sourced if you were lucky to find some in decent shape.
Love your rims, especially the fatazz tires in the rear!
Old 08-30-2010, 05:31 PM   #2791
lakeroadster
Dan,
No offense taken!
I got the Camaro louvers off Ebay. I have designed an air induction set-up to use these to feed the air cleaner, similar to the cowl induction used on Camaro's, see pdf's below. I have most of the parts, but other items are taking priority at this point.
Mike,
The louvers simply bolt to the hood, (6) studs each louver.
Old 08-30-2010, 11:37 PM   #2792
62 Bowtie
62 Bowtie's Avatar
Custom?
62 Bowtie is offline
Old 08-31-2010, 06:14 AM   #2793
aerotruk63
aerotruk63's Avatar
V12
Old 08-31-2010, 10:50 AM   #2794
Strodder
Daring to be Different
Strodder's Avatar
Ugly Custom
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline
Old 08-31-2010, 12:07 PM   #2795
REDNOSE65
REDNOSE65's Avatar
Originally Posted by stripingbyakin View Post
Here's my rig..
x2
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
The making of a Red Nose...
http://www.67-72chevytrucks.com/vboa...d.php?t=396518
REDNOSE65 is offline
Old 08-31-2010, 12:22 PM   #2796
mannyb.
mannyb.'s Avatar
i finally got the grand slam kit from cpp installed. 5" springs w/ c notches in the back, 3" springs and 2.5" drop spindles in the front. its still sitting in my boss' warehouse. hopefully get all the new brake lines bent and bled tonight.
has anybody used this front setup? my tires are scarily close to the fenders and i was wondering if anyone has had rubbing issues. 15" rims w/ 235/75 tires..
1963 LWB C10. tired 230. soon to be sbc350!!!!
i just wanna go fast!! shake & bake, baby
mannyb. is offline
Old 08-31-2010, 02:00 PM   #2797
REDNOSE65
REDNOSE65's Avatar
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
Old 08-31-2010, 05:24 PM   #2798
63sbssbbw
UCA63
63sbssbbw's Avatar
Is that you back in '64 Rednose LOL
Nice truck , not sure about the mop though
T
member#7816
'61 GMC in progress
Old 08-31-2010, 05:44 PM   #2799
McC_65_91
McC_65_91's Avatar
Originally Posted by 62 Bowtie View Post
Custom?
WTF???? wow that is ugly looking, anyone got more info on this??? kinda interesting....
McC_65_91 is offline
Old 08-31-2010, 05:59 PM   #2800
enick72
enick72's Avatar
there was a thread a while back of a guy building a early 60s V12 truck. He finished, drove it in some parade and donated it. The picture above was a guy that chimed in and had already completed his build. If yo saw under the hood you may think differently. I think it would have been better looking if the wheel opening wasn't so big but each has there own taste
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline
Closed Thread
