09-15-2011, 01:13 AM | #2801 |
RAT1968 '68 Cab/'71 Parts
Re: What did you do to your truck today!
Painted out the "yellow tag" on the Vintage Air drier (showed thru the grille);
90% installed on the new grille (How the Hell do those square nylon expanding clips work?...I never can get them to work without shaving them); Installed sound deadner under the hood. Pulled and painted the plate for the "male" side of the hood latch; Installed "female side" of the hood latch on the rad core support and grille and grille center bracket. Light day. No pics today. Nothin' really to show.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
09-15-2011, 08:46 AM | #2802 | |
My old compressor died too, but just from age. I replaced the compressor motor with one I picked up from Harbor Freight. 2 years and it is still running strong. In my case it was about the same price as rebuilding my old one.
09-15-2011, 12:18 PM | #2803 |
English Chevy Owner
Woo Hoo she runs!
See my build thread for more details! http://67-72chevytrucks.com/vboard/s...05#post4900805
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
09-15-2011, 10:03 PM | #2804 |
Dyno'ed the 406 for it.
'05 Silverado '02 Avalanche '85 C10 '71 C10 '51 3100 |
09-15-2011, 10:48 PM | #2805 |
"brand new second-hand"
would you share what's in it? like heads,cam,pistons/cp ratio carb size...sure is impressive
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
09-15-2011, 11:32 PM | #2806 |
Fabricate till you "puke"
I licked the sticker, stuck it on the plate.....then I got on my Harley & rode crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
09-15-2011, 11:54 PM | #2807 |
Trick flow 2.100/1.6. Custom Isky solid roller 600 lift 250@.050, Custom JE pistons for the wedge heads. Compstar crank. 11.75:1 and 750 DP. I ran it on supreme with 30* timing.
09-16-2011, 01:48 AM | #2808 |
Sanded the bedsides and hammered out some dents. I get to put the bed back together tomorrow though!!
68 short fleet cst 71 custom deluxe lwb RIP (parts truck now) 71 Datsun 510 49 GMC 150 (waiting for me for the past 15 years) |
09-16-2011, 10:47 PM | #2809 |
Didn't get anything done, but I did manage to annoy the UPS guy with these pieces arriving all at once. LOL. Now to get the engine finished up.....
09-17-2011, 08:20 AM | #2810 |
PROJECT 7DEUCE
MMMMMMMMMMM BLOWER..... Very nice...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-17-2011, 11:32 PM | #2811 |
The Red Menace
I bought a used tailgate to replace mine. It has some surface rust I'll have to clean up, but at least it's not rusted through like the old one is.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
09-18-2011, 12:26 AM | #2812 |
~Rest In Peace~
went out and practice leaving the line with transbrake and made some adjustments to my 4 link ,its hooking up real nice now .
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
09-18-2011, 01:44 AM | #2813 |
nothing major....finally adjusted the head lights, replaced two bulbs and adjusted the carb, best I could do without a vacuum gauge.... running pretty good. tomorrow will check the timing again....
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
09-18-2011, 09:30 AM | #2814 |
PROJECT 7DEUCE
Painted more parts with satin clean really diggin the look of this stuff..
09-18-2011, 12:47 PM | #2815 |
post a pic of something painted....
09-18-2011, 11:05 PM | #2816 |
removed a bit more of the old and crusty. not alot of time for the truck this weekend. had to dodge rainstorms while landscaping and finish speading gravel for the jeep's new parking spot. hopefully i will be ready to start cleaning and boxing the frame in front of the cab in the next few weeks.
09-19-2011, 12:12 AM | #2817 |
Junior Member
Today may son and I finished welding in all the patch panels and outer rockers on the cab for my '67 swb stepper. I probably should say my son is the welder while I am the patch panel fabricator.
After we got stuff cleaned up we looked over the cab and marked all dents that we need to fix and discussed what to do next Sunday. You see we only work on my truck on Sundays, my son and his family and me. Since I am a novice at sheet metal work I have learned quite a bit while working on the cab beside how to make patch panels. Here are few that many of you may already know about. Don't use a 4.5 inch angle grinder with a cut-off wheel or grinding disk without wearing leather gloves or a face shield. The first day the grinder got away from me and nicked both of my fore fingers and the sparks pitted my glasses. Here is another one be ever vigilant about where the sparks are going, set my shirt on fire also the first day. Now when I use the grinder I wear leather gloves, a face shield and no flammable shirt. I have become pretty good at making patch panels from the sheet metal from an old hood. Hopefully I will learn more next Sunday.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-19-2011, 12:13 AM | #2818 |
Picked up a 71 GMC 2500 for $1600 with the intention of it being a parts truck for my 71 C20. Upon closer inspection this "parts" truck is more rust free than my Chevy, and all numbers matching as well. Can't bring myself to take it apart yet.....
Not sure what to do |
09-19-2011, 01:48 AM | #2819 | |
The Red Menace
09-19-2011, 06:49 AM | #2820 |
Continued working on my doors, removed the outer skin from the passenger door and started installing new skin.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
09-21-2011, 12:11 AM | #2821 |
Installed this. This is just a dress rehearsal, push rods get here tomorrow then I can bolt down the intake, carb, etc.
www.tomthetruck.blogspot.com <-- Aka build thread. |
09-21-2011, 12:21 AM | #2822 |
71 bb longhorn
After the carb was rebuilt a few months ago the truck still wasn't running right so the guy that did it for me came to the conclusion that the gas tank was the culprit so out it came today and hopefully be back in tomorrow (Wish I would of changed when the truck was in pieces) I thought it was good.
71 2500 Gmc longhorn with a 402 turbo 400. 09 F150 Supercrew 4x4 05 Mazda 6 sport accept that somedays you are the statue and somedays you are the pigeon. |
09-21-2011, 08:09 PM | #2823 |
PROJECT 7DEUCE
Heres one of the pics I actually remembers to shoot of my satin paint job for who ever asked..
09-21-2011, 08:21 PM | #2824 |
sharp as a marble
I drove it to work today! 72 Blazer 2WD. had been neglecting it for more than a month, and she responded as expected. Cranked right up!
09-21-2011, 09:02 PM | #2825 |
Old member
Installed the shock relocator and had to lose the rear sway bar.
