Closed Thread
Old 10-30-2015, 12:40 AM   #2801
OregonNed
OregonNed's Avatar
Re: What did you do to your truck today? Chapter II
I'm taking advantage of my truck being parked for the winter to do a few projects. Tonight I finished installing a new turn signal switch in my non-tilt column. It went easier than I thought, but I couldn't see any way of feeding the molded, half moon shaped plug through the small opening in the housing. I ended up making a clean cut near the dash connection and resplicing the wires back together. Turned out pretty good I think.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 10-30-2015, 08:04 AM   #2802
BugzC10
BugzC10's Avatar
Swapped out my Flowmaster Super 50s for a pair of Dynomax 17615 Installer Turbo mufflers dumped under the axle. ....Little quieter, but not as quiet as I would like. Don't have the room for a larger muffler without rerouting the pipes..
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 10-30-2015, 08:22 AM   #2803
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
Dumping the exhaust under the bed is always going to be noisy , try full length pipes and enjoy the quietude .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-30-2015, 08:27 AM   #2804
5567Cruiser
5567Cruiser's Avatar
Nice splice job Ned,I did the same thing with a tilt column.By the way my truck is not put away ayet as we have weather in the 60's and sunny next week!
GARY
67 LWB CST FLEET
56 CHEV 3100
55 CHEV BEL AIR 2DR SEDAN
67 BUICK GS400 CONVERT
5567Cruiser is offline
Old 10-30-2015, 08:40 AM   #2805
BugzC10
BugzC10's Avatar
Yea...I know....the space I have between the axle and bed is very limited and I don't want to go to a muffler shop to see IF they can make the 2.5" pipes clear.
If I go to a shop, I would probably have them reroute from the headers back.
BugzC10 is offline
Old 10-30-2015, 10:06 PM   #2806
ole dollor
ole dollor's Avatar
what Nate said x2
ole dollor is offline
Old 10-30-2015, 11:15 PM   #2807
Bomp
Bomp's Avatar
Working on firewall mod to put the dash back in but make it user friendly when needing to pull it back for maintenance when needed.
Stretched dash with mods in back ground.
Bomp is offline
Old 10-31-2015, 01:08 AM   #2808
Aus69c20
Aus69c20's Avatar
Got some new 16x7 steelies and 245/75 tyres for the c20
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline
Old 10-31-2015, 07:16 AM   #2809
Boog
laying low
Boog's Avatar
That's a real nice looking truck John.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 10-31-2015, 08:10 AM   #2810
Aus69c20
Aus69c20's Avatar
Thanks Boog
John
Aus69c20 is offline
Old 10-31-2015, 03:12 PM   #2811
BugzC10
BugzC10's Avatar
Swapped out the pair of Dynomax 17615 installer turbo mufflers I just installed back to my Flowmaster Super 50s. Turns out the turbos we not any quieter than the 50s and sounded crapy at idle and revved. Shipping them back.
BugzC10 is offline
Old 10-31-2015, 05:35 PM   #2812
In The Ten Ring
Was able to get more paint off the heater box. I hope I can get it all off and so, return it to OEM grey plastic glory.
In The Ten Ring is offline
Old 10-31-2015, 08:49 PM   #2813
sduckworth13
sduckworth13's Avatar
Installed my buddy buckets and dash pad.
Scott
sduckworth13 is offline
Old 10-31-2015, 11:30 PM   #2814
Mac's
I removed my gauges for a good cleaning. I plan to repaint the silver on the edges and then put the wood grain decal on it. I used self adhesive wood grain shelf paper on the glove box door and ash tray to see it I liked the look. It turned out so nice and matches the decal from Brother's Truck so well I might just leave it that way. OPINIONS?
1960 Buick Invictia 4dr Hard Top- 30,000 mile survivor
1965 Impala Conv- project
1967 Mustang, wife's project
1968 C20, driver/project
1952 Ford F1, son's project/my first truck
1990 Jeep wrangler, daily driver
Mac's is offline
Old 11-01-2015, 07:49 AM   #2815
88fordf150
88fordf150's Avatar
Nice!!!
Brad handshoe
88fordf150 is offline
Old 11-01-2015, 09:27 AM   #2816
sduckworth13
Originally Posted by 88fordf150 View Post
Nice!!!
Thank you
Scott
Old 11-01-2015, 11:49 PM   #2817
VWNate1
VWNate1's Avatar
FWIW ;
I like the sound of a robust engine ~
I often don't run any muffler at all but them I have nearly stock engine .
A crossover on a V configuration engine will always make it run better and mellow out the exhaust bark at the same time .
I can't imagine a rig so low you can drive it but not have space to run a 2 - 1/2" exhaust .
If the pipe gets too close to he bed wood , simply install a sheet metal heat shield like GM did back in the 1940's , it worked perfectly .
-Nate
Geezer
VWNate1 is offline
Old 11-02-2015, 01:09 AM   #2818
JJ's Sierra Grande
JJ's Sierra Grande's Avatar
very nice indeed
JJ's Sierra Grande is offline
Old 11-02-2015, 08:53 AM   #2819
jethro5333
first time out of garage in a long time. more polishing and assembly and it will be ready for a road teat.
jethro5333 is offline
Old 11-02-2015, 01:32 PM   #2820
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Two - tone looks sharp! .
-Nate
Geezer
VWNate1 is offline
Old 11-02-2015, 03:22 PM   #2821
OregonNed
OregonNed's Avatar
I've had new fender emblems sitting on the bench for a couple of years now, so I decided to change them while my truck is parked. The bed has been pulled and new bed wood is being milled and prepped. I pulled the inner fenders as part of the job, and I am going to have them painted to match my exterior paint.
Old 11-03-2015, 06:42 PM   #2822
ole dollor
ole dollor's Avatar
[QUOTE=OregonNed;7362541]I've had new fender emblems sitting on the bench for a couple of years now, so I decided to change them while my truck is parked. The bed has been pulled and new bed wood is being milled and prepped. I pulled the inner fenders as part of the job, and I am going to have them painted to match my exterior paint.
Looks great, but thats a lot of work to change emblems good luck on your truck ....
Old 11-03-2015, 09:32 PM   #2823
colgad
colgad's Avatar
It has been a few years ago but I think I did it by removing the pins from the half moon connector by just depressing the little tab. I wrote down the color and what hole they were in. If I had to do that today I would just take a cell phone photo of it.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 11-03-2015, 09:42 PM   #2824
Mac's
I installed a new dash pad. I used wing nuts because it was awful hard getting the little nuts on!!
Mac's is offline
Old 11-03-2015, 11:28 PM   #2825
Myoldtruck
Myoldtruck's Avatar
While at the local u-pull it yard and browsing, i ran across a 71c20 that was pertty well picked over. i found the original power steering pump and bracket still in place, i have manual steering now. 25.00 dollars and it was all mine.
Myoldtruck is offline
Closed Thread
