Old 09-07-2022, 03:02 PM   #1
72c20customcamper
72c20customcamper's Avatar
Re: What did you do to your truck today.The 3rd chapter
Since it’s raining I decided to soak some parts in Rust 911 very impressed with the two day soak . I intentionally left half out to see the results .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 09-07-2022, 03:32 PM   #2
72c20customcamper
Should be easier to take apart . The vent widow would hardly move prior to soaking
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-07-2022, 10:31 PM   #3
cab4word67
cab4word67's Avatar
dang that is some cool stuff
cab4word67 is offline   Reply With Quote
Old 09-08-2022, 06:27 PM   #4
72c20customcamper
Truck is wearing me down guess it could be I’m only a week out of Covid too. I really want to drive it before the snow flies I should have these in paint hopefully by Saturday . Passenger door is already in prime so I just need to do the passenger fender and hood .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-08-2022, 06:47 PM   #5
HO455
HO455's Avatar
Originally Posted by cab4word67 View Post
I did my alinement today and found I have 9.5 deg caster on the left side and 11 deg on the right side. Camber is .25 on both sides. I cant go less on the caster on the right so I mite increase the driver side. Anyone out there see a problem with them being 1.5 deg different?
Well I could I guess, we will see tomorrow.
That's a big gain of caster. How far forward did you drill the new index holes?
I moved mine 3/4" and my caster came in at 5.30*.
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 09-08-2022, 07:02 PM   #6
cab4word67
cab4word67's Avatar
I moved the hole 3/4 just like was said to. But I think my tubular uppers have 4 degs built in from CPP. The truck is driving like a dream now. We are going to do it to the 65 next, mabe then he can drive straight lol.
Just looked they have 5 degrees built in.
Old 09-08-2022, 07:44 PM   #7
LNP
Seems like a whole lot of caster to me. If everything is even it probably does drive nice. If the arms had 5 degrees made in them then I wouldnt have moved them at all. Just my two cents.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 09-09-2022, 08:58 AM   #8
HO455
HO455's Avatar
That makes sense. Personally I would definitely try to get both side within half a degree of each other.
RIP Bob Parks.
Old 09-09-2022, 01:35 PM   #9
cab4word67
cab4word67's Avatar
Both sides are now equal at 9 degs caster and .25 camber. Truck drives nice.
just a note if you buy CPP upper and lower tubular control arms each has 5 degrees built in yielding 10 degrees total caster, so I think that my 9 is just fine for my application.
Old 09-09-2022, 06:29 PM   #10
72c20customcamper
Just cut in the white hard to see but it came out real nice . Tomorrow it’s main color time .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-09-2022, 06:34 PM   #11
72c20customcamper
Just need to figure out where to put my tape line for the break between the saddle and white on the fender
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-09-2022, 06:44 PM   #12
cab4word67
cab4word67's Avatar
that sure does look good, you arent painting them outside?
Old 09-09-2022, 07:31 PM   #13
72c20customcamper
The small spots . Tomorrow I’ll be using a screened in room not perfect but I lost the booth I used . Friend sold the shop
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-11-2022, 08:16 PM   #14
BLP1969
Originally Posted by Liz View Post
Chapter 2 is now complete, bring on 3. What did you do to your truck today?
I ordered a clock to go where the vacuum gauge goes to complete my gauge cluster, it already has the tach.
BLP1969 is offline   Reply With Quote
Old 09-12-2022, 10:49 AM   #15
A1971Blazer
A1971Blazer's Avatar
I found a 10 bolt front axle cheap with the gear ratio I wanted so I figured I could rebuild it cheaper than just re-gearing my D44....
A couple of rainy days and it's going back together now
all replaceable parts from the inside out are new...
pressure washed inside and out...plugged all openings, sandblasted and wire brushed the housing...primed , painted and partially re-assembled...
I'll install all the outer stuff once it's in the truck
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 09-15-2022, 07:39 PM   #16
72c20customcamper
Hung the drivers door today and started to put shiny stuff on . Fender and full assembly of the door tomorrow. Only truck I have that the ampmeter works
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-15-2022, 08:14 PM   #17
72c20customcamper
Visors cleaned up nice.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-16-2022, 07:19 PM   #18
72c20customcamper
Did some more on the truck. Soon I won’t be able to work on it , as it is now I have to pull it out of the barn to work on it not enough room in the barn with all the posts . Lock came out ok some really deep scratches. When I went to work on the window and regulator found one of the rollers was toast . Should have looked more closely so it’ll be a few days till I get a them . Start on the passenger door tomorrow
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-16-2022, 11:49 PM   #19
Smitty
Smitty's Avatar
Thumbs up Re: What did you do to your truck today.The 3rd chapter
Looking better every day. Coming along nicely, this labor of love!
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 09-16-2022, 11:55 PM   #20
Louisvillekytruck
Great work Mark looks beautiful
Louisvillekytruck is offline   Reply With Quote
Old 09-18-2022, 08:18 PM   #21
pjmoreland
pjmoreland's Avatar
I cut some pieces out of the dash of a truck at the wrecking yard today to use as templates for cutting A/C vent holes in my dash.
pjmoreland is offline   Reply With Quote
Old 09-19-2022, 03:44 PM   #22
72c20customcamper
Probably be able to sell them after your done with them
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-19-2022, 03:45 PM   #23
pjmoreland
pjmoreland's Avatar
Yes, I hope so. Will feel less wasteful for cutting up a dash if multiple people can use them.
Old 09-19-2022, 03:47 PM   #24
72c20customcamper
Not much done today was doing firewood but I managed to get one door card done . The little black speck is a bug but the panel was dry when it landed . Used leftover paint from my 04 Tacoma .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-19-2022, 05:42 PM   #25
LNP
You're doin some kickass work there
Harley
