#2826 |
Re: What did you do to your truck today!
Installed the a rear tailgate band....should of done this years ago..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#2827 |
Fixed the 6 month old gas sending unit that decided to ground itself out last weekend. Relatively easy, at least.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#2828 |
I've been boxing my front framerails and tying in the front crossmember by the steering box.
![]() In preperation for adding a winch and winch bumper. |
#2829 |
sharp as a marble
![]() Join Date: Jan 2007
Replaced the rear control arms. I have been dreading this, but it went well. I did this on my 69 SWB, and with a torch, and 4-5 hours I replaced them. Today, I started at 11, and was done at 1. EVERY bolt was well behaved, and I did not break a bolt, and the torch was never lit! I had a good day.
#2830 |
dazed and confused
how does it ride now?
members met: redbaron69, billsbowtie,nc67 |
#2831 |
The Red Menace
I notice your tailgate doesn't have the lower molding. Is that by choice or was it always that way? I'm asking because I just got a used tailgate for my truck and it has holes for the upper molding but not the lower. I always thought it was all or nothing.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
#2832 |
On my wife's 69 I swapped out the alternator for a CS130 105A from an 89 Suburban. I am going to shorten the stainless steel all-thread sticking out in the second picture.
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
#2833 |
~Rest In Peace~
charge up the battery and then drove it and did a burnout
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
#2834 |
Old member
![]() It was pouring down raining so I haven't tested it yet. We left this afternoon also for the weekend. Next week I report back. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#2835 | |
RAT1968 '68 Cab/'71 Parts
I just passed a year of work.... and the frame and suspension and engine and trans were already built when I got her. Tomorrow I'm making final preparations for putting the front clip on...It's happening Saturday. One guy working alone. And, I guess that's what you get.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#2836 |
pushed it out... did some wiring ended up with a radio speaker and radio, dome light and engine harness that works at the end of the day then pushed her back in..... more i install the heavier it gets... good thing i am close dont know if my skinny @ss can push it n and out much longer!
#2837 |
I drempt about how im going to install my fresh 454 t400 with a 205 this weekend and hopefully start it to hear the roar in my ears again. Im missing the sounds of my baby as I cruz down the street with no were to go
#2838 |
Drove it to work today
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350 1966 Caprice 1968 Impala (Frame Off LSX Project) 2001 Tahoe LT 2013 Hyundai Elantra 2010 Kawasaki Z1000 |
#2839 |
Just a car guy
Installed CPP Long panhard bar, shock relocators, and toxic shocks.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
#2840 |
Bled the brakes.... and then broke the front line...Ordering some pre-bents from somewhere later today.
The boys showed up to put the front clip on. Bolted down the cab and front clip. The body lines are as straight as we could get them. Later (after she's running), it's off to the body $hop (somewhere) for some straightening of the lines.... and MUCH later, to paint jail. Put the hood on just because there were three of us...and we could!!! ![]() But I now have an engine bay.
#2841 |
Took the little lady out to lunch& drive in our 71 short/fleet 4 1/2 hours later we got home! truck ran great. Also the conversation was fantastic! I'm a very lucky man. cheers, Pat
#2842 |
Met member Flint70step today. He was near my place, and came by a to look at my 67 K20 and 68 panel. We were going to adjust carb on the 67, but after pulling a few plugs, discovered 2 things. 1. it was tuned fine, 2., reason it smelled rich was 1 plug was toast. Flint was the first besides my kids to ride in the 67. Great guy.
1962 Chevy K10 factory 4x4 stepside longbed http://67-72chevytrucks.com/vboard/s...d.php?t=494632 1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded 1968 Chevy 1/2 ton panel wagon, V8 and powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=483345 1978 Ford F250, beater stepside 2008 Jeep Wrangler 4 Door 2010 Chevy 4x4 plain jane work truck |
#2843 |
I got my new project 68 off the trailer and started taking it apart.
#2844 |
Drove her for about an hour then parked her. Tried to start her up about twenty minutes later and ....nothing. Got some heat soak going. Had put a heat shield on awhile back and thought I had it beat. Planning the remote solenoid now. Hope that fixes the problem.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#2845 |
Pinstriped my glove box door. I was bored so what the heck. The blue was a litttle over reduced. Oh well.
Bud |
#2846 |
More work on the wife's 69. Removed the saddle tanks and the plastic lines that were run to add them. Removed the funky, scary rubber fuel hose that was run from the drivers side saddle tank all the way up to the fuel pump. Changed the door locks and and ignition switch to a single key. Moved the windshield washer bottle to the drivers side fender. Removed the old leaky trailer brake unit and ended up having to make a new line from the master cylinder to prop valve.
Yesterday we went to pick n pull and scored a pair of good inner fenderwells and a washer bottle bracket.
#2847 |
Got my winch box all put together and welded up.
![]() ![]() Tomorrow I'll get that mounted up under the truck, and then make templates for the rest of the bumper out of some cardboard. Anyways, this is sort of what I'm shooting for, less the turnsignals. ![]() Last edited by RossRinSD; 09-25-2011 at 02:16 AM. |
#2848 |
![]() ![]() Join Date: Jul 2002
nice work on the glove box door there doubleb.
#2849 |
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!! ![]() |
#2850 |
My new ramhorn manifolds came in today.
1981 Dodge D-150 (under construction) 2007 Chevy Suburban 2010 Dodge Charger R/T 1980 Kawasaki KZ 440 2004 Harley Sportster 1200 |
