10-15-2017, 09:29 AM | #2876 |
Re: PO has me PO'd
[url=https://flic.kr/p/ZnRj3W]20171014_105356
paper dolls and cut outs are over, now just mount the template to my 1/4" plywood and cut out and my spacer plate should be done
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
10-16-2017, 11:22 AM | #2877 |
Re: PO has me PO'd
10-16-2017, 11:27 AM | #2878 |
Re: PO has me PO'd
[url=https://flic.kr/p/CopucJ]20171016_110440[
I want to add a oil filled gauge to the engine compartment for first fire, found an adapter with a 1/8" port parts s/b here thursday
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-16-2017 at 02:55 PM. |
10-18-2017, 06:31 PM | #2879 |
Re: PO has me PO'd
11-03-2017, 09:16 AM | #2880 |
Re: PO has me PO'd
[url=https://flic.kr/p/CY6uUs]201711
achieved WOT on first try, but dropped a nut under plenum, still looking been careful not to lose OEM throttle clip, but I did, now have to source one out ordered cable adjusters from lokar, so I can install kick down cable [url=https://flic.kr/p/G8vqQa]20171102_113031
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-03-2017 at 09:29 AM. |
11-04-2017, 11:04 AM | #2881 |
Re: PO has me PO'd
11-14-2017, 04:51 PM | #2882 |
Re: PO has me PO'd
11-15-2017, 12:57 AM | #2883 |
Re: PO has me PO'd
I still enjoy following along with every post Jim. It’s looking good.
Posted via Mobile Device |
11-15-2017, 06:11 PM | #2884 |
Re: PO has me PO'd
Thanks Chad for hanging on.
worked on the battery tray today
11-15-2017, 06:17 PM | #2885 |
Re: PO has me PO'd
Maybe I will get mine done soon. I keep saying it will be done by Christmas. Its been 2 1/2 years. I dont lack much at this point. Doors and the interior.
BR549 |
11-15-2017, 10:00 PM | #2886 |
Re: PO has me PO'd
I had good luck with Tri-plus doors, what do you have to do on the interior
11-16-2017, 09:33 AM | #2887 |
Re: PO has me PO'd
[url=https://flic.kr/p/GDTo82]20171116_082202
[url=https://flic.kr/p/Zvo8wJ]20171116_082112 Finished up the remote oil filter, aftermarket battery tray was warped when welded, made install a PITA. Keep the thread sealant off the first couple threads Now I can install larger capacity oil filter sure going to miss my tool tray, when I install my dual batteries. But, first I have to find and figure out the harness
11-18-2017, 11:57 AM | #2888 |
Re: PO has me PO'd
Hoses were hitting inner wheel well, had to change in and out for clearance
[url=https://flic.kr/p/21Cxx1X]20171117_094835
11-18-2017, 12:06 PM | #2889 |
Re: PO has me PO'd
11-18-2017, 12:07 PM | #2890 |
Re: PO has me PO'd
[url=https://flic.kr/p/21zQpEu]20171117_104736
Now I can re-install oil pan, since fittings are tight, needed clearance to swing the wrenches
11-18-2017, 12:54 PM | #2891 |
Re: PO has me PO'd
11-20-2017, 11:01 AM | #2892 |
Re: PO has me PO'd
I have everything done in the dash. I still need to install my roll bar, flooring and seats. I am going to line the floor first with FATMAT and then lay rubber flooring in rather than carpet. Once I am done with that, its just a few little things and then I will be ready for a test drive.
BR549 |
11-20-2017, 08:47 PM | #2893 | |
Re: PO has me PO'd
11-29-2017, 11:45 AM | #2894 |
Re: PO has me PO'd
ok, so today I got the bright idea to mount my tins on the cylinder head. Plan to make a bridge off of the perimeter bolts( my vortec heads have center bolts and perimeter bolts) using hexagon stock
After some thought, I came up with trying my repro(GM) scripts. Seems like they will work as well [url=https://flic.kr/p/21UVpvw]20171129_092226 [url=https://flic.kr/p/21ZW4g6]20171129_102801
12-16-2017, 10:11 AM | #2895 |
Re: PO has me PO'd
I found some sheathing that looks like original, and some shrink tubing with the same weave. Only, this stuff melts at a much lower temp. So, don't use a blow torch, when an alcohol lamp will do
[url=https://flic.kr/p/HzPpvr]20171215_093227
12-16-2017, 04:58 PM | #2896 |
Re: PO has me PO'd
pin out crank and cam sensor
wire crank sensor function a) 20ga. Lt. Green sensor power (5-12v) b) 20ga. Yellow/Black sensor ground c) 20ga. Blue/ White CKP signal cam sensor cavity function a) sensor ground b) CMP sensor signal c) sensor power (5-12 volts) crank sensor( fast) a) black b) red
12-19-2017, 08:44 AM | #2897 |
Re: PO has me PO'd
12-29-2017, 11:49 PM | #2898 |
Re: PO has me PO'd
Inspiring work Jim!
Rob "1967 Wanna Be" 1972 K5 Blazer |
12-30-2017, 01:58 PM | #2899 |
Re: PO has me PO'd
[url=https://flic.kr/p/DnbwAp]20171230_112323
Thanks, but at the moment, it's daunting.....trying to get my computers and cam & crank sensors to talk to one another, I can't find a yellow wire. As Vic says " I hate it, when it goes in one color, and comes out another" Welcome aboard, this is the best forum around. No BS, just a bunch of Motorheads helping each other out
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-30-2017 at 02:04 PM. |
01-12-2018, 12:13 PM | #2900 |
Re: PO has me PO'd
[url=https://flic.kr/p/JogKbk]20180109_100258
[url=https://flic.kr/p/23dX6UW]20180107_100745 [url=https://flic.kr/p/FfBYiU]20180111_124653 If you can read this...please turn me over!!!
