Closed Thread
Old 04-23-2011, 12:05 AM   #2876
bigtruckboi2000
bigtruckboi2000's Avatar
Re: What did you do to your truck today?
Nada damn thing, but look at it sittin in the drive way.
[B][I]1965 Chevy C10 SWB w/350(68-79), 305 H.O Heads, Edelbrock Performer 1406 600 cfm carb, Torquer II Manifold, AC Delco HEI, TH400, Flowmasters,3.07 gears
2005 GMC Yukon XL Denali w/Mangnaflow Exhaust
1983 Cutlass Supreme w/ 350, cam, Holley 650 cfm, Street Dominator intake, carb spacer, hydromatic, Flowmasters
Patriots always talk of dying for their country but never of killing for their country.
bigtruckboi2000 is offline
Old 04-23-2011, 12:11 AM   #2877
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
well I was able to hook up the electric speedo sensor to
my dash Cluster .....
Cluster custom built by forum member "Putter"
JOHNORO is offline
Old 04-23-2011, 06:40 AM   #2878
C-10cutty
C-10cutty's Avatar
Thursday night I put the door weatherstripping on the cab, layed the carpet, and installed new sillplates.
Friday night I installed new divider felt and window channel in one door, door two tonight if I find time.
C-10cutty is offline
Old 04-23-2011, 09:57 AM   #2879
shuvl
shuvl's Avatar
Yesterday: handed interior of passenger door and painted it. Fixed window crank on drivers side. Sanded and primed parts of bed.
Today: more sanding, primer and paint on interior. May even look at oil leak.
shuvl is offline
Old 04-23-2011, 11:45 AM   #2880
glos55
glos55's Avatar
Got out the LMC catalog and went further in debt!
glos55 is offline
Old 04-23-2011, 05:32 PM   #2881
Leadfoot Lambert
Leadfoot Lambert's Avatar
Went to the junkyard in the rain, Got a decent hood, a seat that needs to be reupholstered, a dash cluster with gauges, a chrome front bumper, a floor shift steering column, a low trans hump cover, 2 horn buttons, a chrome wiper arm, a left front fender, found some brand new parts in a suburban, a full rocker panel, 2 rocker panel back covers, and left front and a right front floor panel patches, The yard operator let me drive my truck into the yard so I wouldn't have to lug tools or parts, I won't tell you how much I paid for all this stuff cause it will just piss you off!
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline
Old 04-23-2011, 06:31 PM   #2882
rendus
rendus's Avatar
Welded in the driver's side rocker panel and patched the driver's side floorboard. Scuffed and epoxy primed the entire floorboard and outside of the drivers door.
rendus is offline
Old 04-23-2011, 10:45 PM   #2883
awbrown
Well let me tell ya !! first I installed the ductwork for the heater I had a spare one and the original was broke (had to clean it out , mice you know ) ..installed a temp gauge .. put a gauge cluster in .. I pulled the other one to hook up the speedo cable and could hear something rolling around in it so I took it a part and found the speedometer needle had broke .. so behind the garage I just happen to have a cab (saved for a crew cab project ) and of the few things left in it was the gauge cluster .. The cable was routed wrong so I rerouted it (helps to have another truck that has not been butchered, that would be truck # 1) .. Then I was going to tackle the front fender and just do a patch panel , but it was just too bad up front . so I robbed the new one I had for truck #1 ,again...and the bolts .....I geased the front end , found the bolt that tightens the rag joint to the steering box was never tightened, and would not start into the threads.... took it for a ride , then changed the carb , and it still runs crappy.. so if it is in the 60's again like it was today I tackle the ignition...oh also put the seat from truck #1 in it , much better...........
awbrown is offline
Old 04-23-2011, 11:40 PM   #2884
Rich 5150 69
Rich 5150 69's Avatar
I got the feeling this will become truck #1,,,LOL
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 04-23-2011, 11:48 PM   #2885
awbrown
well , let's hope not !!! http://67-72chevytrucks.com/vboard/s...d.php?t=409840 here is the link to #1..
awbrown is offline
Old 04-26-2011, 11:19 AM   #2886
65Gregg
65Gregg's Avatar
I finished putting on my new mufflers, Flow Delta 40's, so far it sounds nice with no resonance at cruising speed. I have 2 1/2 exhaust w/an H pipe. There is a ton of difference from the old turbos. Now I just need to put my new headers on.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 04-26-2011, 09:34 PM   #2887
awbrown
First I tackled the wiring .. seems the lights were a bit too dim for my liking.. Thats right It made it's maiden voyage (outside of the sub division) and my boy and I changed the seat at the storage area,by then it was dark.. the volt meter was around 12 volts .. So upon further investigation I found the whole truck was run by one 8 ft 18 gauge wire off the battery .. So I changed it to a 10 gauge and then reworked the alternator bracket and found out why the PO had it so shimmed up in every direction .. the pulley is forward of where it should be , must be for a 6 cylinder .. so tomorrow we rob the pulleys and alternator off truck #1... that means it will also be converted to an internal regulator so I will have more wiring to do .. also changed the feed wire to the HEI to a 10 gauge insteed of a 20 gauge ....
awbrown is offline
Old 04-27-2011, 11:18 PM   #2888
Vernski
What happened to what did you do to your truck today?
I think somebody must have revamped this forum. So I'll post what I did today, I got my third brake lite hooked up and working. Not quite as hard as I thought it was going to be my neighbor is a electrician and I used his fish tape to pull the wires through the cab in the light hole. I used a Yukon 3rd light I bought on ebay. I hooked in to the brake light switch on top of the brake pedal. Hey it works and I'm extra safe now, here's a pic ....Vernski
Vernski is offline
Old 04-27-2011, 11:25 PM   #2889
bigtruckboi2000
hooked the light up on tach and tested out a few spots to hook up the volt meter I got for it.
Old 04-28-2011, 12:07 AM   #2890
PAPA KENT
PAPA KENT's Avatar
Re: What happened to what did you do to your truck today?
Originally Posted by vernski View Post
i think somebody must have revamped this forum. So i'll post what i did today, i got my third brake lite hooked up and working. Not quite as hard as i thought it was going to be my neighbor is a electrician and i used his fish tape to pull the wires through the cab in the light hole. I used a yukon 3rd light i bought on ebay. I hooked in to the brake light switch on top of the brake pedal. Hey it works and i'm extra safe now, here's a pic ....vernski
looks great! A nice light for the roof top.
PAPA KENT is offline
Old 04-28-2011, 12:10 AM   #2891
PAPA KENT
PAPA KENT's Avatar
Installed the last of my side trim.
Old 04-28-2011, 12:13 AM   #2892
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
It's right here. http://67-72chevytrucks.com/vboard/s...d.php?t=368988
Alan's Classic is offline
Old 04-28-2011, 12:40 AM   #2893
Blue Heeler
Blue Heeler's Avatar
took it for a cruz with my dog bought him a burger at in & out then came home and did a oil change.
Blue Heeler is offline
Old 04-28-2011, 01:30 AM   #2894
Vernski
Originally Posted by Alan's Classic View Post
I swear it wasn't there awhile ago Alan I guess I'm just getting old timers. Hey Papa Kent nice truck I like that color, What's under the hood there?...Vernski
Vernski is offline
Old 04-28-2011, 03:45 AM   #2895
monolith
Zero Albedo
monolith's Avatar
Lunched the 305 V6 on the way home from work.
Parts for sale shortly.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline
Old 04-28-2011, 07:56 AM   #2896
jbgroby
jbgroby's Avatar
What happened to the 305?
jbgroby is offline
Old 04-28-2011, 09:49 AM   #2897
lakeroadster
Hey Vernski,
Looking good! Reminds me of a song... "Up on the roof"...
You might want to add yous to this thread: Third Brake Light Thread
A few of us have used that same set-up, except we mounted them under the lip. Big Fenders turned us on to this in the aforementioned thread.
John
lakeroadster is offline
Old 04-28-2011, 10:13 AM   #2898
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
-well yesterday...
I finished off my 66 bbw parts truck... sold the rear bbw half of the cab to sftorange a while back.. cut off and saved the front top of windshield and roof panel, stripped everything, saved the front bed panel for my custom truck, and tried to save anything off the bed...which I couldn't, rust everywhere... they had put in a "new" plywood bed floor, and it was waterproof enough to rust the entire bed all around the perimiter!
I rolled the frame and v8 ( which turned out to be the original 283) under a good rust free-except for one rocker- 63 gmc cab.
then I put a front clip and-64 chev- and hood -61 gmc- on it.
installed and adjusted some doors I got from derek that have shaved door handles.
ran into an issue with mounting the brake...
the gmc cab still had a hole for the hydraulic clutch, with a rubber plug in it. the 2 m/c holes go across a 45 degree plane... wheras the 66 are horizontal, will have to drill some holes, and maybe install the 66 clutch/brake assembly.
I have a decent box going on this weekend.
I did take 1 picture..however it is still in my dads camera
will have to edit it in later.
jonzcustomshop is offline
Old 04-28-2011, 01:44 PM   #2899
Vernski
Hey Lake the reason I put the light on top of the cab and not under the lip is the angle of the LED's they are pointing up at about a 10-15 degree's I had a friend help me and we powered up the light and he held it at the angle under the lip and at eye level it wasn't as bright as on top where it sets level. Most of the mini cars, vans and suv's set low to the ground these days, so that was the deciding factor of placement. However it does look better under the lip, if I could have got it to sit at eye level I would have put it there. But this is about safety so that's the poop on that. And I sealed it from water using o-rings on the screw heads,made a gasket from an old inner-tube using a x-acto blade so it can be removed easier. I don't think it looks all that noticeable, but that's one for the opinion poll. If an administrator or someone would like to move these post's to the third brake light thread you have my ok cause I don't know how to do it. Thanks for the heads up John....Vernski
Vernski is offline
Old 04-28-2011, 07:22 PM   #2900
Alan's Classic
Vern, I requested "What happened to what did you do to your truck today?
" and "What did you do to your truck today? " to be merged when you first posted. I didn't think about the 3rd brake thread. Just post some pics in the 3rd brake light thread. I don't have the ability to merge threads.
Closed Thread
