Old 11-27-2008, 04:15 AM   #276
kizer
Its Deja Vu time again
kizer's Avatar
Re: My 1965 build thread
Man that going to be one hot looking truck when its all done.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 11-27-2008, 08:48 AM   #277
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Man, this thing is coming along really nice !!!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-27-2008, 08:50 AM   #278
LILRED66
LILRED66's Avatar
Alan:
Impressive, truly impressive. Keep the pictures loading...
LILRED66 is offline   Reply With Quote
Old 11-27-2008, 07:26 PM   #279
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Originally Posted by LILRED66 View Post
Alan:
Thanks Kizer, John and Tony. My download cable from my camera is smokin'
I got the rear shock upper perches changed out. This is what I use to gring the head of the rivet off.
Then knock it out. It is really easy to do with the bed off.
The rear end is almost done just need the spring retainers from CPP. Nothing is tight yet. I will wait till it's on the ground before torquing.
Since there is not much to do to the frame. I worked on getting the AC box mounted.
There is a clearance issue wth the cowl vents. I think I can bend the handle down. There is a cover that covers the lines that I have removed for now.
Alan's Classic is offline   Reply With Quote
Old 11-30-2008, 12:12 AM   #280
Alan's Classic
Still waiting on CPP parts to finish up the frame. I've been dreading cutting in and mounting the defrost ducts. It took alot of measuring and figuring it out as I went. I think it turned out good. I think the openings are big enough not to whistle. I might hook up a airline on the duct and see what happens.
I drilled holes and put pieces of thread all in the holes and welded the top of the rod even with the dash and ground flat. I had to put 1"extensions (washers) because the nut was too close to the duct so I couldn't tighten it up. With the extension it worked great.
Old 12-02-2008, 12:42 AM   #281
Alan's Classic
I still haven't got my parts from CPP. I called today and was told that one item is back ordered. They should have relayed the info. That might be the problem with others not getting their items in a reasonable time.
I did get something in the mail today. I got this off of ebay. It's a serpentine setup. It came with everything (including bolts) except a water pump. I've got to see which water pump I have to use. It is in awesome visual shape. It is used, but at a 1/4 the cost, right now I call it a great deal.
I also started to work on one of the bedsides. I'm welding up the joints for a smoother finish.
Old 12-02-2008, 12:48 AM   #282
joe231
joe231's Avatar
that is awesome!
i want to weld up our seams, you got any tips?
CHEVY ONLY
Old 12-02-2008, 12:54 AM   #283
Alan's Classic
Originally Posted by joe231 View Post
that is awesome!
Jump around with the welds to keep the heat down. I stayed on my welds too long. I knew better. I should have kept my weld lenght to under an inch. It made a few bumps that I tapped down. The metal in those areas are strong unlike in the middle of the panel. Don't forget clean metal. I can't remember if you have any welding experience or not.
Old 12-02-2008, 03:13 AM   #284
wbr775
wbr775's Avatar
very nice how long is it on back order
wbr775 is offline   Reply With Quote
Old 12-02-2008, 08:12 AM   #285
4dranch
Shloooooong bed member #2
4dranch's Avatar
super, super, super.. very cool Alan
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 12-02-2008, 08:23 AM   #286
Alan's Classic
I ordered on November 19 and found out yesterday (Dec 1) it is back ordered. I'm chomping at the bit to get them. Once I get them the frame will be rolling.
Thanks David. I feel so close but yet so far away from completion.
Old 12-02-2008, 10:49 AM   #287
4dranch
4dranch's Avatar
Time will fly when you start putting it back together. Thanks for sharing your progress with us.
David,
Daughters 66 truck:
Old 12-02-2008, 10:59 AM   #288
joe231
joe231's Avatar
thanks,
i do have some experience. I'm certified and weld lots of heaver stuff.
still a bit of a novice when it comes to sheet metal.
I have read lots on the subject, and know the techniques, just need practice and a better welder
CHEVY ONLY
Old 12-02-2008, 11:16 AM   #289
scotts62
One day...
scotts62's Avatar
Looks good man! nice work!
Hey Joe you can use my welder works good for sheet metal
Scott
93 crew cab build
Project 62
Old 12-02-2008, 07:05 PM   #290
joe231
joe231's Avatar
CHEVY ONLY
Old 12-02-2008, 07:28 PM   #291
Alan's Classic
As of monday they should recieve it in 2 days. It's the lower control arm Ubolts. Who would've thought?
Old 12-02-2008, 08:10 PM   #292
Bazooka
Keepin it old school
Bazooka's Avatar
Turning out nice...
Bazooka is offline   Reply With Quote
Old 12-02-2008, 08:31 PM   #293
Old School Kid
Rottenwood Garage Member..Yes!
Old School Kid's Avatar
Thing looks great, I can't wait to see it!! Great things come to those who wait, and take their time!! Your going with dop 2.5" spindles and 4 in the rear? Just wondering.... What ever happens I'm sure its going to be cool..
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way.
My 65 (SOLD)
http://67-72chevytrucks.com/vboard/s...d.php?t=317013
My 51 (SOLD)
http://67-72chevytrucks.com/vboard/s...80#post3551880
Racetruck III (SOLD)
http://67-72chevytrucks.com/vboard/s...72#post4254972
Rottenwood Garage and Speed Shop.....where everything must be racy!
Gone to dark side for a while...1966 F100 in the stable
Old School Kid is offline   Reply With Quote
Old 12-02-2008, 09:48 PM   #294
Alan's Classic
Your right 2.5/4 drop for now. Thanks for the comments. It's time to go out to the shop and see what I can get into.
I've got a list of parts that I need for my 383. I built it, but then took alot of stuff off of it to get another engine running. The 383 has about 500 miles on it. The parts list is just a bunch of nickel dime things. I need another small block that I could pelfer off of. Hey sdailey are you home? You've got a small block right.
Old 12-03-2008, 12:53 AM   #295
Alan's Classic
Here is the 383 as it sits now. It's been on the stand for about 8 years bagged up.
The temp gauge is fixed.
I figured out how to roll the speedo back. The zeros are in the wrong position on the shaft which is easy to fix, but then I ran into a bigger problem.
The housing was froze up. I eventually got it freed up.
The needle was froze up on the shaft which eventually broke. It had to be removed to take the speedo apart. I don't think I can repair the pin. Anybody got a speedo for sale? Ebay here I come.
speedo exploded view
Old 12-03-2008, 01:28 AM   #296
joe231
joe231's Avatar
at that last pic
CHEVY ONLY
Old 12-03-2008, 08:35 AM   #297
Alan's Classic
at that last pic
I thought somebody would get a kick out of that pic.
Old 12-03-2008, 08:38 AM   #298
sdailey
The Few, The Proud
sdailey's Avatar
Yeah, you just stay over on your side of the fence and leave my small block alone.
You know if you need something just name it.
Shannon
sdailey is offline   Reply With Quote
Old 12-03-2008, 07:04 PM   #299
ol Curt
Junior Member
ol Curt's Avatar
Alan,
I am enjoying the thread. Seeing you get things done inspires me to work on mine. Keep up the good work!
ol Curt is offline   Reply With Quote
Old 12-03-2008, 07:55 PM   #300
shortbed70
shortbed70's Avatar
Wow man thats one slick project you got there,subscribed..
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
