Old 01-23-2008, 02:13 PM   #276
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good Blazer...
As-is, but my powder guy blasts everything beforehand- I have never had adhesion problems with his work. I even 'clearanced' my LCAs after powder with a 6lb sledge and didn't lose a even a flake of coating. I'll be sure and go check it tonight though so I can rest better...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-23-2008, 08:42 PM   #277
Rokcrln
Rokcrln's Avatar
Originally Posted by SCOTI View Post
Gringo, did you have your DM powder-coated as is or did you debur the edges a little?
I did on mine 'cause I was worried about the powder 'lifting' off the sharp edges like it did on my ECE hidden-hitch.
Sorry to hear about your hitch, mine was like a work of art when it showed up! You need to call up Stan and let him know about the problem you had because that is not like them to let somthing pass like that. Even a sharp edge should not lift unless the powder coater just missed somthing.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-23-2008, 11:15 PM   #278
SCOTI
SCOTI's Avatar
Kevin
LFD Inc.
Looks like it wasn't blasted. I just feathered back the peeling stuff & used my readily available Krylon semi-flat black.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-24-2008, 01:48 PM   #279
gringoloco
A guy with a truck
gringoloco's Avatar
More hood progress today. I did not get to spend much time in the garage due to an extended nap after work...
I got the core support mounts pretty much done. Finish welded them and used barrel nuts inside the square tube to accept the attachment bolts. This will also serve to keep the tube from collapsing due to over tightening or from the weight of the hood.
Since the Buicks are a little narrower than our trucks, I needed to merge two hinge assemblies together. I simply cut them to fit and slipped in a 6" piece of threaded rod. I drilled two holes to plug weld and then stitched the seam. I'll grind/sand it smooth and paint after everything is fitted.
Rokcrln had trouble clearing the radiator mounts on the inside when he did this setup and ended up trimming them to fit. Mine just barely clears. This may change when the radiator is installed. I don't know if he was maybe using the 4 core mounts or if my setup is a 1/4" different or what, but I'm glad it worked out so nicely.
-Chris
Old 01-24-2008, 10:36 PM   #280
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Good progress. I love these hinges, I even got a set myself
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 01-25-2008, 04:02 AM   #281
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I haven't caught your thread in a while... things are really coming together. It looks good!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-25-2008, 02:03 PM   #282
gringoloco
A guy with a truck
gringoloco's Avatar
Hood is ON TILT! Clearance is a little tight when opening/closing at the rear of the hood and fenders, but it works pretty well. Just have to be careful to not chip the paint. This should be alleviated when I get the rear sliders in. They are designed to raise the hood up a little for clearance, then it kinda 'drops' into place at the end of its travel.
The hood hinge supports are simply 2x2 angle, cut and bent to fit the shape of the hood, bolted in the stock hinge holes at the rear and welded at the front. They will hardly be noticeable with a coat of paint on 'em, and even if you do see 'em they don't look out of place.
-Chris
Old 01-25-2008, 02:11 PM   #283
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sweeeeet !!!!!!!!!!!!!!!!!!!!!!!
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 01-25-2008, 02:14 PM   #284
babyblueoval
babyblueoval's Avatar
I see a reference to a car your hood hinge came off of. What car?
How will you latch it in the rear and keep it from "wobbling" side to side when driving? Is that something you haven't figured out yet?
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 01-25-2008, 02:16 PM   #285
babyblueoval
[QUOTE=babyblueoval;2546032]I see a reference to a car your hood hinge came off of. What car?QUOTE]
Oops. nm I see the link to the how to thread.
Jim
Old 01-25-2008, 08:48 PM   #286
Rokcrln
Rokcrln's Avatar
Looking good! Is that all the way open, what is stopping it from opening more if anything? Mine almost opens 90*, that might be what the 3/4" dimention is you were asking about. I need to check mine but it is burried in my project lot right now so it is kind of hard to get to.
Kevin
LFD Inc.
Old 01-25-2008, 10:38 PM   #287
jkade
jkade's Avatar
How low is the front since you cut the fenders? I like the hood job BTW.
Thanks, Kade
jkade is offline   Reply With Quote
Old 01-26-2008, 12:17 AM   #288
Frizzle Fry
Frizzle Fry's Avatar
Hell Ya!
Frizzle Fry is offline   Reply With Quote
Old 01-26-2008, 07:27 AM   #289
gringoloco
A guy with a truck
gringoloco's Avatar
Kevin
LFD Inc.
It will open further, but this is where it rests with the springs in place. After looking at the pics of yours, it appears to lean further forward than mine. The angle of the hinge arms is different than mine when all the way open. Did you do anything to the bumpstops on the hinges? That's the only way I see that I could get it to rest open any further.
Thanks, Kade
The hood pics above are aired-out. Frame is about 2" off the ground. This will change when the drop spindles go in...
-Chris
Old 01-26-2008, 08:36 AM   #290
Frizzle Fry
Looks like you'll have to cut more from the fenders when the drop spindles go on, ya?
Old 01-26-2008, 08:56 AM   #291
jkade
jkade's Avatar
The hood pics above are aired-out. Frame is about 2" off the ground. This will change when the drop spindles go in...[/QUOTE]
OIC you ain't got no drop spindles Just wondering why you went this route on the hood instead of mounting the hinges to the firewall? I think what you are doing looks good but I have to ask since I will have to do something similar Looks like the 67 may be gone so I may get back to work on the blazer but I will never catch up with you Keep up the good work.
Old 01-26-2008, 10:06 AM   #292
Rokcrln
Rokcrln's Avatar
Simple because he can! It is alot easier to mount new hinges to the fire wall but that is just what they expect. When you have a front tilt it looks stock when shut and as you open it the first 6" of movment looks totaly stock then the hood starts sliding forward and finally comes to rest flipped in front of the grill. It just does'nt get any better
loco~ The only thing I can think of is I have the 3/4" stand off on my hood mount and that will give more leverage when open. I did not do anything to my stops but I can not remember if I have the rubbers in their or not. I will find out Sunday because I will be setting my front end on my Blazer. I have alot of cleaning up to do around here since my Dump runner has been down for a face lift
Kevin
LFD inc.
Old 01-26-2008, 11:12 AM   #293
jkade
jkade's Avatar
Kevin
LFD inc.
I wasn't saying that I thought it was a crappy way to go about making the hood open I like being differnet and doing things a different way so I was just being curious.
Old 01-26-2008, 11:15 AM   #294
Rokcrln
Rokcrln's Avatar
I never thought you were saying it was a crappy way to go! What gave you that idea?? I Just gave the reason why I did mine and what I tell people when they ask why!
Kevin
LFD Inc.
Old 01-26-2008, 11:28 AM   #295
SactoJim
SactoJim's Avatar
Damn cool!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 01-26-2008, 11:31 AM   #296
jkade
jkade's Avatar
Kevin
LFD Inc.
[QUOTE=Rokcrln;2547357] Simple because he can!
That is what threw me off track, no big deal and I may have to go that route too That is why I was asking, and no harm no foul
Old 01-26-2008, 01:27 PM   #297
gringoloco
A guy with a truck
gringoloco's Avatar
Yeah, but I'll still probably set the bumpstops to stop it somewhere around this height so I can still roll aired-out(either accidentally or on purpose.)
I haven't seen any firewall mounted hinges that I like. They all look kinda out of place to me. I like the way Rok's version of this just looks like it 'belongs'.
I appreciate you checking for me. It's a mystery to me at this point. Even at its current angle, I'm still very happy with the results.
Originally Posted by SactoJim View Post
Damn cool!
Thanks! Your truck is killer! I wish my pickup was half as nice...
-Chris
Old 01-27-2008, 02:53 PM   #298
Rokcrln
Rokcrln's Avatar
And you should be it looks great!
Kevin
LFD Inc.
Old 01-28-2008, 03:57 PM   #299
Dinos63
chevy only
Dinos63's Avatar
gringo . nice work ,truck looks killer
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 01-29-2008, 05:46 AM   #300
Rokcrln
Rokcrln's Avatar
Well I had a friend come over and give me a hand cleaning thigs up a bit. I am still waiting to do a dump run once LowBuck is finished up.
Here are a few pics from today (yep you get all 5 or none) of the tilt front end on my 70. We pulled off the stock front end as one piece now I just need to pull it apart and store the good stuff and toss the bad. I did remove the stock hood bumpers on the tilt front end but will put some back in before paint or anything so that may give me an extra bit of an opening. Also I noticed my hinge spreader bar sits on the radiator support as it touches the bump stop locations. I also included a few pics of other stuff we moved around. The 51 F1 is a future street rod project so I can play around with chopping, chaneling, sectioning, shortening and a few other mods. It is a factory V8 flathead truck that only has 48K on the ticker. It was a friends dads truck that he put in a barn in the 60's and pulled out last year when I bought it from him. I know it's not a Chevy but will be one bad @ss truck when done all the same.
Kevin
LFD Inc.
