Old 06-16-2010, 10:55 AM   #276
Dinos63
chevy only
Dinos63's Avatar
Re: something different 66 long travel truck
Yup looks killer! The backs all done now also, spare tire rack dimple dye floor, racing seats
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-16-2010, 01:24 PM   #277
blackmopar
pics of the dimpled floor? That thing turned out really killer Dino - the legs in the shoot aint bad either!!
Im still debating using that front A-arm treatment for a Gasser on my 64.........
blackmopar is offline   Reply With Quote
Old 01-28-2011, 10:17 PM   #278
Miller92
Miller92's Avatar
Hey Dino, you still got this flatbed? I wanna make my '63 a flatbed pickup and get rid of my fleetside bed.
Miller92 is offline   Reply With Quote
Old 01-28-2011, 10:27 PM   #279
Dinos63
chevy only
Dinos63's Avatar
No i trashed it sorry kat!!
Old 01-29-2011, 12:07 PM   #280
kieth
kieth's Avatar
Originally Posted by badriand View Post
Cool, i had a 96 chevy stepside 2 wheel drive i put a 6 inch fabtech lift on with 33's yyyeeeeaarrrrssss ago. I guess the big tires and such killed my power and truck never seemed to drive right no matter what i did so i eventually lowered it again. When you get a set of tires on there i think it will make it look really good.
You should have changed the rear axle ratio, to 4:11 or such, the large diameter tires are like running a 1:98 rear axle ratio Kieth
kieth is offline   Reply With Quote
Old 01-29-2011, 12:30 PM   #281
kieth
kieth's Avatar
Looks like a great Baja Pre Runner, frame upgrade would be the next step....if one is to really use it for Off Off highway, but now it looks like FUN
Old 01-30-2011, 01:56 AM   #282
Dinos63
chevy only
Dinos63's Avatar
I kinda miss that truck
Old 01-30-2011, 09:20 AM   #283
protrash64
Resistance is Futile
protrash64's Avatar
That thing was cool Dino........did the camo bench seat end up in someone else's truck?? I swear I saw it somewhere....
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-30-2011, 01:01 PM   #284
Dinos63
chevy only
Dinos63's Avatar
YEAH I GAVE IT TO ERIC
Old 10-05-2012, 01:45 AM   #285
racingroger69
DYNO63: I have a 71c10 2wd I am wanting lift the suspension about 3 inches or so....this fabtech kit that you bought for your truck....is it the 88-98 kit? would it work on my 71? what kind of mods did you have to do to make it work on your truck? how much total lift did it actually give you? how did you lift the rear? my rear is coil springs too and will be wanting to leval the truck out after i install this kit up front...am wantin leaf springs in the back is there a conversion kit out there that you know of?
racingroger69 is offline   Reply With Quote
Old 10-05-2012, 07:39 AM   #286
clemdaddy
clemdaddy's Avatar
dude... you're flipping me out. how many active projects you got going right now? just found this one and it is extra cool.
clemdaddy is offline   Reply With Quote
Old 10-05-2012, 12:58 PM   #287
justcuz
justcuz's Avatar
Hey Roger,
If all you want is 3 inches of lift to be able to run 32 or 33 in tires, find as set of big block crew cab dually front coils. The old Chevy part number is 328101.
Here in the west for off road use we left the trailing arms in the truck (they act like big traction bars, thats why Nascar uses them) and had springs wound for the rear. But today you could find a set of H2 rear springs and bolt them in back. The coil pockets are about the same as the pigtails on the stock springs and may work.
The reason most old pre-runners (and race trucks) had a nose up attitude was twofold, 1. it transfrred weight to the back of the tradionally light rear end of the pickup so when you were driving down dirt roads it kept the rear planted a little better and 2. Coil springs after taking a 500 or 1000 mile beating off road lost their tension and sagged an inch or more and you ended up with a level truck. I had a 61 Chevy with torsion bars that held up to the beating way better than coil springs. It was a 1/2 ton shortbed stepside that I swapped 3/4 ton torsion bars into. Another advantage to the torsion bar front ends was the ball joints were bigger than the coil sprung ones and lasted longer. Back then almost everyone was running Fords with twin I beam, so us rare Chevy guys were on our own for suspension developement. Later of course the Chevys became more common starting with Mickey Thompsons Big Red and the Parnelli Jones/Walker Evans yellow shortbed. The red shortbed pictured is one that was built by us here is So Cal.
When you were driving these trucks you could tell when the springs were giving up because the front would start banging the bump stops and the rear end would start fishtailing more in corners.
Lastly you can convert these old trucks to leaf springs easily. It was an option available from the factory, I would bet the frame holes are pre-drilled for the mounts. If I was going to the trouble to convert to leaf springs though I would go with the 1988 and up 64" rear springs for a much better ride than the old 52" or 56" stock springs.
justcuz is offline   Reply With Quote
Old 10-03-2013, 03:53 PM   #288
Mater/10
Mater/10's Avatar
Hey bud, im building a prerunner out of a 84' gmc. can i possibly get a parts list for your front suspenison set up ? my rear is leafs but i already got that covered Thanks !
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625
1969 Chevy Nova 2 dr I6 250/powerglide
1967,68,69,70,71,72 Chevy Frankenstein
Mater/10 is offline   Reply With Quote
Old 10-14-2013, 12:33 PM   #289
71veronica
71veronica's Avatar
if there was only a kit that i could buy i would do this in a heart beat. I want it
71veronica is offline   Reply With Quote
Old 10-16-2013, 11:31 PM   #290
Dinos63
chevy only
Dinos63's Avatar
the company doesn't make the arms any more, but call porterbuilt I bet he would make ya a set that would be kick a$$
Old 10-25-2013, 03:14 PM   #291
justcuz
justcuz's Avatar
You need to go to RaceDezert.com and check out the built Chevy pre-runners over there. Remember though a true pre-runner will not be real tall, but will have a decent amount of suspension travel with a relatively low CG.
Old 10-25-2013, 04:42 PM   #292
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
some shots I have saved of it:
Old 01-10-2014, 01:24 AM   #293
Boulevard Speed Shop
Boulevard Speed Shop's Avatar
Hey Boulevard Speed Shop ...
to the forums and Ohio
But ....
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Boulevard Speed Shop is offline   Reply With Quote
Old 02-24-2014, 11:42 AM   #294
Please read the rules and guidelines ...
Your support is appreciation ...
1962 GMC Custom Cab Fleetside Short Bed Bagged
2008 GMC Sierra Z71 Extended Cab Short Bed Leveled
Old 03-18-2014, 01:39 AM   #295
The63Project
hewlett i will get all the info on this and pm you, on what i have used
Could you fill me in on what parts you used and how you did this please, I'm restoring my 63 chevy and want to do something similar to this, because it's so dang awesome!
-Jay
The63Project is offline   Reply With Quote
Old 09-02-2014, 12:11 AM   #296
Dinos63
chevy only
Dinos63's Avatar
been off the site for awhile been busy at my appliance shop.Still working on stuff had a lil time wanted to do another lifted truck found a clean donner
Old 09-02-2014, 12:13 AM   #297
Dinos63
chevy only
Dinos63's Avatar
this time i use strong arm to work out well... 27" to the rocker 37x17 on 12 "wheels
Old 09-02-2014, 01:30 AM   #298
19GMC66
19GMC66's Avatar
Awesome truck! I want one.
19GMC66 is offline   Reply With Quote
Old 09-02-2014, 01:32 AM   #299
Dinos63
chevy only
Dinos63's Avatar
hmm trade maybe lol
Old 09-02-2014, 10:12 AM   #300
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
hmm trade maybe lol
Very cool. Doesn't look like this truck will make it to the Git Down in November.
66Gilbert is offline   Reply With Quote
