#276 |
Re: Here is a "Not Your Typical" 4wd Blazer build
thinking 8.1 liter for my build
2008 HD 2010 Camaro 2ss (The Wife's Ride) 2005 Suzuki GSX-R 1300 "Busa" 1969 C-10 (under Construction) 2013 Sonic LT "LIVE LIFE,TASTE DEATH" |
#277 |
.....I am working on it.....
That would be nice
![]() I decided I am gonna stick with my lil 5.3 ![]() |
#278 |
My 5.3 is a lot of fun to drive.
You have a PM. |
#279 |
Made my own motor mounts and got everything mocked up. I will tie them together with a tube under the oil pan in place of the stock cross member. Sorry for the bad pics, there were taken with my cell.
#280 |
GEARHEAD
That should work.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#281 |
Strong work on the engine mounts. Very nice. Also, I love the idea of an engine cage. Not only does it protect your 5.3L, but it also provides a spot for the coilovers.
#282 |
Thanks for the compliments!!
Its just a little too early to air it out, but I will make up for lost time when its done , ![]() Next I will be working on a crossmember to tie in the two mounts together. Than I need to do something about the tranfer case cross member. It sits about 1" higher then stock and about 1.5" forward. The stock cross member won't work because my radius arm mounts are right there, so I will either modify the stock one or build my own. I won't know untill I try to use the stock one first. If I don't like it, I will build my own. After all that crap, then I will need to build mounts for the core support. It was mounted to the leaf spring hangers, but obviousely those are gone. Its going to be a slow process, but at least its moving along again!! Stay tuned!! Posted via Mobile Device |
#283 |
Ok, not much of an update, but I finally took some better pics of the motor mounts with my camera instead of the cell.....
The header on the driver side will need to be modified to work. It hits the frame and the collector angle is not what I want. I have some tubing ordered. I will cut the tubes just above the top of the frame rail and then add "segments" to get the right angle I want. It will match the passenger side by the time I am done. Also set the radiator in place to see where I need make my mounts. The transfer case cross member now mounts to the top of the lower frame rails vs the bottom. I hacked it up a little, but nothing I cant fix later. It raised the transfer case about 1" (which is where it ended up), I had to re-bend the ends to get it where I wanted it. Last edited by sandking; 04-09-2011 at 12:46 PM. |
#285 |
GEARHEAD
Looking good. One question, with all the other tube work, why didn't you just make another tube one for the transfercase rather than cut and bend the stamped steel one?
The added gussets in the frame along with all the cage attachments will make the chassis very stiff. The motor mounts will be stiff too. Then you have this, which seems out of place.
#286 |
Um.............. Good question!!
![]() I figured I would try it first, if I dont like it, I can always build one anytime. At least for now, it gives me the location to get everything else in line and sets the location to work everything else around (exhaust, etc) I will have to make one that bolts to the vertical inside frame rails...... later ![]() |
#287 |
Build is awesome. Welds are incredible!
#288 |
Thanks!!
Next, I am waiting for the big brown truck to drop a delivery. Hoping to get my header done and the lower mounts of the radiator done. Also got all the parts to actualy do my whole exhaust. |
#289 |
love the build, dig the motor mounts,may need to make some for myself
#290 |
Thanks!!
Here is the start of my attempt to modify my headers to fit my application. You may ask, "why not buy ones that fit", well, what fun is that? ![]() |
#291 |
GEARHEAD
Here's an idea. Flip 'em over so they point up and run it without a hood.
#292 | |
make sure to get some rain caps though!
85 C10 LWB 305ci - 700r4 - 10 bolt - 3:08 gears Collecting parts for a 'mild prerunner" ![]() |
#293 |
better idea weld them back up flip them over and install a pair of turbos
#294 |
...or tell the po-po that you are running short tube headers.
#295 |
anymore progress????
#296 |
#297 |
ur really lettin me down man.... Cant wait to see more!
#298 |
GEARHEAD
Alright, the summer is over. Time to get back to working on this and quit working on your tan.
#300 |
Well folks, believe it or not, I started kicking this old girl around the garage again this past weekend.
![]() Got the modified header reworked for a nice fit, its ugly, but its done ![]() Also started working on the mounts for the 26 gal fuel cell. Stay tuned....... ![]() |
