Old 11-01-2011, 08:03 PM   #276
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Re: Bolt in steering rack
Ordered mine today. Cant wait to get mine! I think this is going to make my truck so much sweeter to drive. I believe she said that that mine would be shipping out Monday or there abouts.
Thanks to No-Limit
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 11-01-2011, 09:30 PM   #277
robnolimit
robnolimit's Avatar
Thanks Chris, please give us some feedback. We're interested to know every detail.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 11-01-2011, 09:31 PM   #278
robnolimit
robnolimit's Avatar
Michelle will be posting up some product picts and the install instructions on wed.
Old 11-01-2011, 09:39 PM   #279
SweetandLong68
Your UncleBen
Of course Rob! Will do! I will also be installing full suspension and brake updates as well.
thanks
CHRIS
Old 11-04-2011, 12:39 AM   #280
Fastfun
Fastfun's Avatar
I received mine today SWEET!!!!!
Fastfun is offline   Reply With Quote
Old 11-06-2011, 02:51 PM   #281
robnolimit
robnolimit's Avatar
Newsflash RideTech will now be a stocking dealer for our C-10 rack & pinion kits. This fits in perfectly with their new True-Turn steering kits for muscle cars. The deal was struck at SEMA.
Old 11-06-2011, 10:50 PM   #282
SweetandLong68
Your UncleBen
Sweet Rob that is great!. Any insight on when I can expect my kit to be shipped? Eagerly awaiting mine!...
thanks
CHRIS RICE
Old 11-07-2011, 06:47 PM   #283
ibad57
ibad57's Avatar
Please post link to this product im interested!
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172
ibad57 is offline   Reply With Quote
Old 11-07-2011, 07:21 PM   #284
SBTork
Garage wrench
SBTork's Avatar
VERY cool indeed!!
Any time frame on them having these in stock? (I know it's early, I just have to ask)
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 11-07-2011, 07:42 PM   #285
robnolimit
robnolimit's Avatar
All remaining current orders will be shipped by wed. Ridetech will have them in stock after thanksgiving. - when their truck & trailer heads home.
Old 11-08-2011, 01:43 PM   #286
michellenolimit
Junior Member
COMPLETED AND READY TO GO!! Bolt in Power Steering Rack & Pinion to fit
1967-87 Chevy Pickup $849.00
Michelle
No Limit Engineering
Authorized Dealer for: Ridetech, Vintage Air, Painless, Ididit, Accuair, Flaming River, and many more
michellenolimit is offline   Reply With Quote
Old 11-08-2011, 01:48 PM   #287
michellenolimit
Junior Member
Here are the instructions (8 pages total)
Michelle
Old 11-08-2011, 01:50 PM   #288
michellenolimit
Junior Member
Instructions Continued:
Michelle
Old 11-08-2011, 09:05 PM   #289
Conundrum
Conundrum's Avatar
Looks great but I don't think it will work on my truck, I sectioned 1.5" out of my crossmember and it doesn't look like the rack mount will fit.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 11-08-2011, 09:19 PM   #290
dnd1978
dnd1978's Avatar
Conundrum,
Go to post 227
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 11-08-2011, 09:43 PM   #291
Conundrum
Conundrum's Avatar
Yeah, my whole steering shaft and support bearing will have to be different do to having a 2" upand 1" forward Z. But looking at the bolt holes for the outside bolts for the rack bracket, they look to be to high to work with a sectioned crossmember.
Old 11-09-2011, 12:44 AM   #292
gringoloco
A guy with a truck
gringoloco's Avatar
Can you elaborate on the 'reuse your stock steering shaft' bit? I don't see how this will work...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-09-2011, 10:36 AM   #293
SweetandLong68
Your UncleBen
Sounds good Rob! Cant wait to get mine.
thanks
CHRIS
Old 11-09-2011, 04:28 PM   #294
robnolimit
robnolimit's Avatar
The stock shaft has a slip shaft from top to bottom. The uuper joint has good flex. The lower rag joint gets cut off. The smaller side of the slip shaft is 3/4" DD, and slides into a 1"DD on the larger side. The stering u-joint is 3/4"DD. I have seen the factory slip shaft both ways, 3/4" on top, and 3/4" on the bottom. If your is on the bottom, simply cut the rag joint off and use that end of the shaft into the U-joint. If your truck has the large end on the bottom, cut it back a few inches, and insert a short length of 3/4"DD shaft, weld it in place, and then put that into the U-joint.
Old 11-14-2011, 01:55 PM   #295
Project1970
14.1 @ 96MPH
Project1970's Avatar
So there's no realistic way to make this work with the towers in the front holes? Hmm...time to figure out if I can move mine back, I think my engine is already sitting fairly close to the firewall though.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 11-14-2011, 03:39 PM   #296
gringoloco
A guy with a truck
gringoloco's Avatar
Cool. Didn't realize there was that much flex in the upper. Would make for a more 'stock appearing' install.
On the engine mount issue- have you installed your kit on a 73-87? The mounts, by design, use both the front and rear holes. Many 63-72 guys convert to the newer style engine mounts too, myself included.
-Chris
Old 11-15-2011, 12:24 AM   #297
broey
Square
broey's Avatar
I seriously think if there was an award for best product of 2011 this would win. finished product looks killer.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 11-16-2011, 03:18 AM   #298
robnolimit
robnolimit's Avatar
Thanks Broey. As to the motor mount issue, We have done one as a test. We took the front bolt out and marked the other two holes to be drilled. Drilled the two 5/16" mounting bolt holes. - the rear hole went through the motor mount as well. Then, we drilled out the front motor mount hole to 7/8" for the steering shaft, and fit the bearing and shaft. A small amount of die grinding was needed to get the shaft to clear the motor mount plate. We put a small weld, 1/2" long, on the leading edge of the motor mount to the frame. Everything works fine, but this truck now only has about 600 miles on the install, and we would like to see a bunch more. I'll keep you posted, and get a pict next time he comes by.
Old 11-20-2011, 12:07 AM   #299
76stepside
76stepside's Avatar
Anybody try to mount their rack with factory lower control arms only to find out it wont fit! The rack just sits on top of the bushing part of the control arms... how much of the control arm in this area is safe to trim down so I can make the rack work? Name:  1119112248.jpg
8.1l 496 4l80e
76stepside is offline   Reply With Quote
Old 11-20-2011, 02:50 AM   #300
broey
Square
broey's Avatar
Oh man that sucks. I hope they have an answer. If it were me though, I would just cut whatever amount I need to off. But, I'm just saying what I would do. Not what you should do.
