Old 07-30-2012, 11:15 PM   #276
fredscarryall
fredscarryall's Avatar
Re: slamburban
installed the a/c lines and i'm taking it to the a/c shop next week to get charged.
fredscarryall is offline   Reply With Quote
Old 07-30-2012, 11:22 PM   #277
fredscarryall
Re: slamburban
finished the install on the power window and made new door panels out of abs plastic
Old 07-30-2012, 11:24 PM   #278
oldman3
oldman3's Avatar
Re: slamburban
Looking "cool"....Jim
oldman3 is offline   Reply With Quote
Old 07-30-2012, 11:27 PM   #279
fredscarryall
Re: slamburban
installed interior sun visors. dont know if i like them. they are probably clocked in the wrong position and need to be adjusted.
Old 09-15-2012, 04:49 AM   #280
Ratical
Ratical's Avatar
Re: slamburban
Any progress since your last post?
Ratical is offline   Reply With Quote
Old 09-16-2012, 01:07 AM   #281
fredscarryall
Re: slamburban
ya man.i took it to the rock around the block main city cruise in downtown Gresham and won a sponser choice 1st place award. on monday i am taking the burb to Lonnie at Carolina kustoms in Portland to remove the garbage airbagit.com air ride system and replace it with a ridetech system. he is also going to be fixing my bump steer problem i have been having since day one.i cant go above 40 mph without wondering all over the road because the pressure in the gm powersteering pump is to high for the mustang 2 rack.i tried a use one of thses mullin/borgeson flow control valves with the spacers in it but it is to hard to fine tune.so i bought a heidt flow control valve and line kit from summit that has a manual in line adjuster valve on it.should have it back in about a week.
Old 09-16-2012, 01:23 AM   #282
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: slamburban
from what i know a thunderbird r&p is better suited for a gm pump.thats what mine is.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 01-28-2013, 04:52 AM   #283
48 GMC BURB
48 GMC BURB's Avatar
Re: slamburban
Fred
Havent seen you on in a while ,I trust all is well ?
Two questions , What did you end up doing for the headliner ?
& how are the exhaust cutouts working,leaks ?
TKS
KC
48 GMC Burb
51 Chevy AD 3100/C 4 byShannon
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
48 GMC BURB is offline   Reply With Quote
Old 01-29-2013, 03:52 AM   #284
fredscarryall
Re: slamburban
i havent been doing much to the suburban lately.i order an original style coated cardboard headliner.the plan is to take it to the uphostery shop in the next few weeks and get them cover in the same blue vinyle that the seats are done in.as far as the cut outs. i blew a fuse the first time i used them.i had to drive with open exhaust until i got to a friends house for about ten miles ,hoping i wouldnt see a cop. for some reason the factory had an in line 5 amp mini fuse. once i replace it with a normal size fuse block and a 20 amp fuse.i havent had a problem.after i get the headliner done.i am going to get the hood louvered.i dont think theres not enough air flow in the engine bay and once the outside temp get up to about 80 it knocks pretty hard. my tune guy said it might be to much static heat. i thought he was full of crap.but when its under 70 outside it runs perfect.i figure it may be worth a try for less then $100.anyone have any ideas beside timing or air fuel mixure?has anyone had simliar problems?
Old 01-29-2013, 09:51 PM   #285
99 to Life
99 to Life's Avatar
Re: slamburban
slam, I haven't had knockin but I get starting issues when it is really hot out. I've since put a phenolic spacer on my carb and insulated my fuel lines, and it has really helped. Also I run high test gas and it has really helped. I def think there are air flow issues and have thought that since day one. I'd try insulating your fuel lines, run the spacer (not aluminum) and try that out. I've thought of some louvers for the side of my hood, but not on top, would rather not if I don't have too. I actually don't run the rubber hood trim so I do have a little gap where the hood meets the fender, so that might help some. I'd say if you temp is below 200 deg it wouldn't be so much of a timing issue. Could maybe try different temp spark plugs. My temps are about 190 or so on a really hot day, I'm usually around 180 I'd say. I see you have lots of aluminum and chrome stuff in your bay, all of which is just soaking in heat. I'd say the biggest key is keeping the fuel cool first, aside from timing to your cam specs. oh lastly, I think they make heat shields that go under your air cleaner, that way all that hot air isn't going right back into your cleaner. Plus gas today is just filled with ethanol, I'd run the better stuff because your compression might be on the higher side. one last thing I'm doing this summer is wrapping my headers, for sure.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-30-2013, 02:40 AM   #286
fredscarryall
Re: slamburban
thanks for the ideas.i going to buy a carb spacer and insulation sleeving tomorrow. i think this is what your talking about
Old 01-30-2013, 10:12 AM   #287
99 to Life
99 to Life's Avatar
Re: slamburban
yeah pretty much. the spacer I used is phenolic, its like a composite material. that one looks like plastic, but still better than aluminum. Mine is open spread, which I have heard the four bore ones like this are pretty good to, give the fuel a more direct path, since its up a bit higher it has a chance to get sprayed around a little I guess. Either way, I can guarantee those two things will help. I've got my fuel insulated from pump all the way to carb. Oh and my visors are kinda like yours, they just don't seem right do they? I haven't really played with them too much, I just shuv them into the roof.
Old 01-30-2013, 10:31 AM   #288
solidaxel
solidaxel's Avatar
Re: slamburban
Time well spent tuning your distributor to the specs of your cam should show great improvements to both starting and performance, especially your vacuum can, and total advance.
A lot of problems are blamed on the carb but are masked by the distributor and timing
JMTCW!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-08-2013, 08:48 AM   #289
55dude
55dude's Avatar
Re: slamburban
door panels look great!
55dude is offline   Reply With Quote
Old 07-01-2013, 02:36 AM   #290
fredscarryall
Re: slamburban
had to rebuild the motor again. had a cracked head from my craigslist special and looks like when I reared that car it hit my crank pulley and wiped out my crank bearings. Descided to run without the hood for a while and cover the bolt holes with allen bolts. took the moons off the rims and installed spider caps.
Old 07-01-2013, 09:59 AM   #291
oldman3
oldman3's Avatar
Re: slamburban
Sorry about the engine, wheels look good...Jim
Old 07-01-2013, 09:46 PM   #292
99 to Life
99 to Life's Avatar
Re: slamburban
dang man, sorry for the string of bad luck. It will all come together again and I bet you'll make it even better.
Old 01-31-2014, 03:24 AM   #293
fredscarryall
Re: slamburban
Latest pics
Old 01-31-2014, 09:56 AM   #294
99 to Life
99 to Life's Avatar
Re: slamburban
nice man, luv this thing. glad your back out. friggin ice age over east here. can't wait for spring.
Old 01-31-2014, 10:39 AM   #295
oldman3
oldman3's Avatar
Re: slamburban
Looking good...Jim
