Old 03-17-2012, 02:16 PM   #276
made2drag
made2drag's Avatar
Re: 86 squarebody made2drag
thanks guys, the alpine 7904 does work but its missing the face surround. until i find that im trying to find another one. found an alpine just like it that was a pullout but i was outbid. it went for 47 bucks. cd player didnt work but alot of times you can open them up and free up the mechanism and it works again
made2drag is offline   Reply With Quote
Old 03-17-2012, 04:15 PM   #277
bloodybigblock
bloodybigblock's Avatar
Im from alabama too...Im doing a k5 2wd called coppersled. Nice build man
bloodybigblock is offline   Reply With Quote
Old 03-27-2012, 09:16 PM   #278
mineralgrey01gt
Man thats awesome so far. Keep it up! Ill be following the build
mineralgrey01gt is offline   Reply With Quote
Old 03-27-2012, 09:35 PM   #279
made2drag
made2drag's Avatar
thanks...im in the garage right now trying to mount the rear bag brackets
Old 03-28-2012, 09:06 AM   #280
made2drag
made2drag's Avatar
got one rear bracket tacked and i welded in 1/4 inch round tubing to strengthen the notches some. it's mounted below the bed floor.
Old 03-28-2012, 09:12 AM   #281
made2drag
made2drag's Avatar
wont be long...by this weekend i hope im ready to put the bed on. i have to install everything and mount shocks.
Old 03-28-2012, 09:23 AM   #282
made2drag
made2drag's Avatar
most everything will be done in hydraulic hose. once installed and leak free im hoping i never have to mess with anything. i know DOT airline and fittings would be easier, but this pre-made hose comes in 12", 18", 24", 36", 48", 60", 72", 84", 96", then all the way up to 144". ends already on them. they range from 10 to 40 bucks. not that expensive seeing that the push to connect connectors are at least 10 bucks a pr....locally they cost me 12 bucks each. most of the sizes of hose i'll be using will cost under 20 bucks each and the ends are obviously never going to have trbl.....and i think 3500 psi will do.
Old 03-28-2012, 10:04 AM   #283
91Subbed
Nice!
91Subbed is offline   Reply With Quote
Old 03-28-2012, 10:06 AM   #284
91Subbed
Your gonna have to tell how to make that manifold on pic #281! lol
Old 03-28-2012, 11:48 AM   #285
made2drag
made2drag's Avatar
i bought it along time ago for my ball valve setup. 15 bucks at lowes.
for the compressor i'll end up running a hydraulic hose straight to the tank and use a tee instead of the manifold to feed the front valves. i was going to run the 4 valves for the rear off it too, but decided i will run 2 valves next to each rear bag and run 2 separate hoses from the tank instead.
the main reason i wont keep the manifold or the cross is since they are steel... they rust... and my valves may stick from debree. ive got to order a brass cross and a couple check valves. im going to run one gauge to measure one front bag, one for the one rear bag and one for the tank and mount them in the dash. might do 2 dual input gauges. one for front and rear pressures and one for tank.
Old 03-29-2012, 11:46 AM   #286
made2drag
made2drag's Avatar
got my valves and switchbox thrown together for a trial test. im happy with the 1/2 inch speed up and 1/4 inch speed down. it's nice to have all brand new stuff...except tank and comp... that is. may be a day or 2 before i post pics. im still hoping to mount my bed on saturday or sunday
Old 03-30-2012, 04:53 PM   #287
stepside83
stepside83's Avatar
coming along, i say you should do a video of your truck airing up and down for those that are new to the air suspension, lol
stepside83 is offline   Reply With Quote
Old 03-30-2012, 04:55 PM   #288
made2drag
made2drag's Avatar
ok, i have to finish the rear connections first. maybe this weekend
Old 03-31-2012, 12:17 PM   #289
made2drag
made2drag's Avatar
Old 03-31-2012, 12:18 PM   #290
made2drag
made2drag's Avatar
Old 03-31-2012, 12:21 PM   #291
made2drag
made2drag's Avatar
i still need to get a 12 inch hydraulic hose....didnt want to drive 30 miles to tractor supply today, so i'll change that out next weekend. and if anyone's wondering about the ball valve...it is to slow down this side since the other side has a longer hose. this way i can get both sides to air up and down at the same speed.
Old 04-01-2012, 09:56 AM   #292
made2drag
made2drag's Avatar
yesterday's progress
Old 04-01-2012, 10:14 AM   #293
stepside83
stepside83's Avatar
Looking good man, cant wait to see what it looks like with the bed on and all aired out
Old 04-01-2012, 06:26 PM   #294
made2drag
made2drag's Avatar
my rear tires are hung up on the tubs....and my axle can still move up 2 1/2 more inches. im not sure if im going to cut my tubs yet for the extra 2 1/2 inches of rear drop or keep them and bump stop them so i dont rub tires. i had the tub unbolted on one side but the Rhino lining bedliner is 1/4 inch thick and the tubs would need to be cut loose.... where they mount so they can come off. also, as you can see i should have went ahead and bought the 12 inch hydraulic hose. it still needs to be put in on the passenger side....but oh well, everything else worked out. and no i dont have shocks yet....now i know where i can mount them....that will be next week most likely
Old 04-01-2012, 06:28 PM   #295
made2drag
made2drag's Avatar
Old 04-01-2012, 07:09 PM   #296
maxxxy
maxxxy's Avatar
It looks sweet!! If I were you I'd put some bump stops in the rear, at least until you can get the front lower to match, Because right now it sits pretty level, and in my opinion the front end higher that the back isn't the best look.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 04-01-2012, 07:17 PM   #297
stepside83
stepside83's Avatar
That looks sweet man id just do the bump stops, get it to sit level when aired out, but i love how low the truck sits no i really cant wait to get my stepside aired out
Old 04-01-2012, 09:08 PM   #298
Pop's C-10
Pop's C-10's Avatar
looks sweet
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 04-01-2012, 09:44 PM   #299
mineralgrey01gt
Just about as low as mine without the frame z'd! Looking good man, great work for sure
Old 04-02-2012, 12:40 AM   #300
bbbc10
Diggin The SquareLife
bad fn ass!!!
bbbc10 is offline   Reply With Quote
