Old 01-13-2022, 09:11 AM   #276
KevinK7
KevinK7's Avatar
Re: Project "Financial Burden": 1968 SWB C10
subscribed, ...holy smokes you got some mad skills
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 01-14-2022, 12:23 PM   #277
cj847
cj847's Avatar
Originally Posted by 68 C10 Driver View Post
Update, finished that under dash repair...
Interesting. It appears your leak originated from the windshield. I have always assumed that this type of leak was from rats nest, etc clogging the drain path down the side of the cowl. Nice job on the repair.
Was the passenger side also rusty from the windshield?
I just picked up a 67 and I was under the dash the other day and noticed severe rust in this area, hence my keen interest.
cj847 is offline   Reply With Quote
Old 04-03-2022, 08:30 PM   #278
Old_Truck_Fan
Thanks for the comments. I finally finished up all the wiring. I'm still working up the courage to hook up the battery and test things out. In the meantime, I worked on some smaller items that always take longer than expected. I needed to merge the parking brake cables from a Gen 4 Camaro to fit my rear brakes with the stock ends to connect at the trailing arms. The best solution I could come up with was JB welding the stock trailing arm fittings to the Camaro cables since they shared the same diameter. I also needed to rework the transmission mount which allowed me to test out my new SWAG off-road finger brake. It worked out really nice and is a lot easier than trying to bend 3/16 thick material with a hammer in a bench vice.
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675
2011 Dodge Ram 1500
2012 Camaro ZL1
Old_Truck_Fan is offline   Reply With Quote
Old 04-03-2022, 08:45 PM   #279
Old_Truck_Fan
I made good progress on finishing up the interior since the dash wiring is now complete. I spent quite a bit of time time mocking up the shifter and shifter handle. I 3D printed a shifter base using the dimensions from Core Shifters and then made a cardboard version of a Hurst shifter handle. In the end I went with a Mopar B body shifter handle and the Core Shifter forward shifter conversion with the "F" fulcrum height. The shifter travel is just 3.5 inches from first to second. I used the stock 4-speed shifter bezel and boot and 3D printed a transition bezel from the rectangular stick to the round hole in the boot. Lastly, I put all the electronic modules in the glove box and I really like the Restomod Air AC controls and the Dakota Digital RTX gauges. My to-do list before starting paint and body is getting small.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 04-03-2022, 08:46 PM   #280
Old_Truck_Fan
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 08-06-2022, 08:42 PM   #281
Old_Truck_Fan
I finally hooked up the battery and checked all my electrical work. All seems good and there was no smoke. I also installed a custom driveshaft from Denny's. I needed to figure out a radiator overflow tank and decided to make mirrored tanks on either side of the core support. One is for the radiator overflow and the other is for the windshield washer fluid. I made a simple radius brake for the outer profile and then used my 3D printer to make a hammer form for the ends. It was a fun project and I got a little more experience with aluminum welding. I also made some steel brackets with dimpled corner gussets, again using 3D printed tooling.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 08-06-2022, 08:44 PM   #282
Old_Truck_Fan
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 08-06-2022, 08:49 PM   #283
Old_Truck_Fan
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 08-07-2022, 08:58 AM   #284
Jiggers72-GMC
Jiggers72-GMC's Avatar
Wow, great idea, very well done, nice workmanship
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 11-13-2022, 11:33 AM   #285
layinrocker65
layinrocker65's Avatar
Any updates on this project?
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 11-21-2022, 02:53 PM   #286
Old_Truck_Fan
Hi layinrocker65, I'm still working through all the small items. Here are a few of the recent pictures. Sometimes you need to go back a little to move forward. I've been working on the panel gaps and I rewired my AC system with the latest controller module from Restomod Air.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 12-23-2022, 09:15 PM   #287
Old_Truck_Fan
I test fit my carpet and found a few YouTube videos helpful for putting in the hole locations. I used a thin wall tube that was heated up using a propane torch. It made quick work of cutting through the carpet, backing and padding creating a nice OEM look. I also decided to go with a bed mat from Holley. It's specific to the truck so it hugs the contours perfectly. I just had to add in the hole for the fuel tank fill. I also modified the old choke knob with a magnet to hold the Terminator X 3.5 inch screen. When not in use everything looks factory.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 12-23-2022, 09:24 PM   #288
Old_Truck_Fan
I almost have all the minor details sorted before tearing everything down, perfecting all the panel gaps and starting on paint and body work. I've been able to test out all the electrical systems including the Terminator X setup (minus starting the engine) and everything is functioning correctly. I think I have everything covered so that re-assembly is easy. Do you guys have any words of wisdom on what you wished you checked before everything was painted that I may have missed? Here are the last pics before I start tearing things back down.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 12-23-2022, 09:26 PM   #289
Old_Truck_Fan
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 12-26-2022, 08:43 AM   #290
mr.mud1
mr.mud1's Avatar
absolutely gorgeous truck but more impressive (to me) is the workmanship,unreal how nice everything is an so clean.very very nice.some people don't realize how much thought and effort goes into making parts and pieces look so simple and clean.it'll be a shame to cover alot of it up.beautiful work.
mr.mud1 is offline   Reply With Quote
Old 01-01-2023, 12:05 PM   #291
Old_Truck_Fan
Thanks! You are right, it does take a lot of time to dial everything in, but I'm enjoying the journey. I've started to tear everything back down knowing that when it goes back together it will be for good.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 08-11-2023, 07:55 AM   #292
Old_Truck_Fan
Well the entire truck is now in totes for the most part aside from the frame and body. All the pieces can now receive their final finishes one part at a time.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 08-11-2023, 08:01 AM   #293
Old_Truck_Fan
I'm nearly finished with dialing in all the gaps and body lines which has taken a significant amount of time to balance everything out. I don't know how many times I've had things on and off, but it's getting close.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 08-11-2023, 09:35 AM   #294
Stickman
Stickman's Avatar
You have some serious skills sir. Absolut beauty of a truck.
Stickman is offline   Reply With Quote
Old 08-13-2023, 10:02 AM   #295
cornerstone
cornerstone's Avatar
Incredible work on a beast of a truck. Can't wait to see it on its maiden voyage.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 10-12-2023, 04:37 PM   #296
Shifty One
Shifty One's Avatar
Master class in awesome!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 01-06-2024, 11:04 AM   #297
Old_Truck_Fan
Thanks for all the encouraging comments. I added in several 1/8 alignment holes between all the body panels for when things go back together. Using Cleco's seems to work out pretty nice. Everything is now fully disassembled and I just sent the frame and numerous other parts out for powder coating. Now I need to work on laying down that original 503 green paint code. I've got a quart of test paint to try out.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 01-10-2024, 12:42 PM   #298
raggedjim
raggedjim's Avatar
Can't go wrong with 503! Nice work, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 01-10-2024, 03:20 PM   #299
KevinK7
KevinK7's Avatar
Amazing!, ...this truck is going to be incredible. Super impressed with your skills, ..and man that shop is CLEAN
'68 C10 50th
Old 01-10-2024, 07:17 PM   #300
Jiggers72-GMC
Agreed, he must have an app where it erases all the clutter from the pictures, wow
