#276 |
![]() Join Date: Jul 2011
Re: 1959 Fleetside REBORN
That's the ex-electronic engineer in DAD. Thanks Kim57.
Thanks ChuckDriver.
Build for my 1959 Fleetside... http://67-72chevytrucks.com/vboard/s...d.php?t=518308 |
#277 |
Yes, in the southern desert part, and it seems to get worse every year. From mid june to mid september historic average high is above 80 peaking at 92 around the third week in July. This year we had like 10 days the highs were over 100, and 48 out of 50 consecutive days the highs were over 90. I'm adding ac to my truck and the Chevelle when it gets its turn.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#278 |
If everything goes well tuesday or wednesday.
#279 |
Removed gas tank to install air ride stuff, brackets etc., and installed our new 1000hp axles from DDS. Fuel tank reinstalled and started reinstalling front suspension. Now 4 months 14 days and 3 hrs. later we have a roller.
Tomorrow we will be starting to install the fuel, brake and air lines. We need to be done by monday becuase we can't find our tools any more.
#280 |
Lookin' good. I bet it feels nice having it on the ground. Now the sad part is tearing it down for paint.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
#281 |
Your frame is really looking nice.
What are you doing for paint? Kim |
#282 | |
Duponts PPG with rock guard on top.
#283 |
Wow all the hard work shows,its nice when a plan comes together.that looks to be camaro rear is this correct.should have avery good weight balance.keep up the good work.
#284 |
Yes, it's from a 2010 camaro ss with 14.4 rear disc brakes and 3.45 ratio.
#285 |
Here's a few more shots while I'm waiting to goto branch....
#286 |
Well got my front frame thru fitting installed. And straightening coil tubing sXXXs.
#287 |
Nice work.
Kim |
#288 |
A320 Pilot/USAF Retired
Gettin' there!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#289 |
I'm not tail-gating, I'm drafting. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
#290 |
Thanks. Been busy with plumbing problem and it was not with the truck.
Thanks, Wheres that 25 hr. Thanks. I keep stepping foward, I think!
#291 |
Have not worked on the truck that much due to a weasal of a neighbor. He reported me to the county inspector for having abandoned vehicle in my driveway. Granted, one was the cab chained to the avacodo tree next to my driveway. And it was not on the dolly like in the pic.
Now with the case CLOSED. We can continue, getting things ready for sandblasting on Monday.
#292 |
Looks good, tell your neighbor he's a douche!
My '59 Build Thread |
#293 |
I had a neighbor call about a car once also, or maybe it was just my wife because she didn't like it either.
Kim |
#294 | |
![]() Very nice work you do, keep upp the good work! |
#295 |
I have a piece of crap neighbor like that as well. He called the city on me because I parked my Ram in the grass while I backed out and took my GMC for a spin. Now I have to play musical cars to get my truck out and heaven forbid I park on actual earth because it violates city code...may he die the death of a thousand venereal diseases!
All the frame work looks awesome. This thing is gonna rock for sure.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#296 |
Well its on the road again. Sort of.....40 pcs. sent to sandblasters. We will see how much metal we get back, Still 40 pcs.!
#297 |
You get your hot rod back from the blaster yet?
#298 |
Chevette,
quick reasponse is yes. Received about 1:30pm, then started spraying with PICKLEX 20(acid base coating as seen on trucks). Need a shower and some FOOOD! Pics tomorrow of the swiss cheese.
#299 |
Well here are the bad parts.....
#300 |
The good, well sort of.... Found a wrench!
