Old 10-09-2012, 05:02 PM   #276
63split
63split's Avatar
Re: Dutch 1955 build
Originally Posted by _Ogre View Post
i like the look
shave that standing seam and you will have this look
Ok i took Ogre's advise and shaved the standing seam
also fitted the gas pedal in place
and checked if the wiper motor would not interfere with the brake booster
63split is offline   Reply With Quote
Old 10-09-2012, 05:20 PM   #277
hotrod1
56 - autocross
hotrod1's Avatar
I have always wanted to know how you fill and maintain a master cylinder like that? Can you enlighten me please?
By the way, what pedal set up did you use?
hotrod1 is offline   Reply With Quote
Old 10-09-2012, 05:59 PM   #278
63split
63split's Avatar
by using a mirror and a bottle like this
the same procedure i use on my 55 panel with underfloor pw brake setup
where the master cilinder is located right under the seat without an access hole
from above
the pedal setup i use is a modified underfloor setup
the rubber brake pad is from a corvette, the gas pedal is from lokar.
Old 10-09-2012, 06:17 PM   #279
hotrod1
56 - autocross
hotrod1's Avatar
from above
Can u still run an ac unit (vintageair) with the master up there?
Old 10-09-2012, 06:27 PM   #280
63split
63split's Avatar
I dont know ? i wont run an ac unit because we dont have California heat
Old 10-09-2012, 06:33 PM   #281
Kim57
Kim57's Avatar
The fire wall looks good. I may be a bit prejudiced though.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-09-2012, 11:37 PM   #282
oldman3
oldman3's Avatar
I agree that the firewall looks much better with the lip removed....Jim
oldman3 is offline   Reply With Quote
Old 10-13-2012, 08:10 PM   #283
Dan in Pasadena
Dan in Pasadena's Avatar
done some more on the tailgate today
63split. Your work is simply amazing. I am super impressed.
I have been looking for bed roll end treatments and Russell turned me on to your threat. After looking this photo over I really like what you've done but I have a question:
Doesn't this create a place for water to collect at the bottom of this smooth transition you added? I don't see a weep hole and you didn't mention putting any kind of rust preventative on the back side of the steel you added.
Also, I haven't looked ENTIRELY through your thread but I didn't see any closing off of the bed tube. I knew someone once who added a 3-4" wide, long strip of sheet steel closing the tube underneath because he wanted to use an old style vinyl tonneau cover but not drill snaps into the bed tube, so he put industrial strength Velcro under the tube on that strip he added. Something like that would close off this dead end your tube treatment creates.
Dan in Pasadena is offline   Reply With Quote
Old 10-14-2012, 12:28 AM   #284
OrrieG
OrrieG's Avatar
I did my firewall like yours, but left the horizontal projecting seam. I will be driving the truck in weather and it diverts the rain and snow melt to the side and off the electrical stuff on the back of the engine and firewall.
OrrieG is offline   Reply With Quote
Old 10-14-2012, 01:01 PM   #285
63split
63split's Avatar
hi the inside is zinc plated and the added sheetmetal is zincor plate, but as soon as everything is painted
i will put in some wax in these kind of places
there is also a weep hole on the inside
Old 10-14-2012, 01:10 PM   #286
63split
63split's Avatar
this truck will try to avoid bad wheater, kind a only alowed to play in good wheater
Old 10-14-2012, 03:32 PM   #287
63split
63split's Avatar
last week done some small things that take a lot of time
and dont show much progress, cleaned up some holes on the dash
and holes for the sunvisors we wont use, and fit all things that need to go under the dash like defroster hose, blower fan and gauge cluster
to see nothing will interfere with the brake booster setup.
made a bracket for the fuse box
the fab work is as good as done on the cab so it can be made ready for primer and paint.
now i will get working on the bed agian
i was thinking for a while in what direction to go on the taillights
i going to integrate these corvette taillights in the rear fenders
2 on each side , well at least thats the plan....
made some pipes that wil need to be cut in a 30 degree angle
and cut one hole into the fender
Old 10-14-2012, 05:49 PM   #288
OrrieG
OrrieG's Avatar
Talking Re: Dutch 1955 build
Sissy
Old 10-15-2012, 05:25 PM   #289
63split
63split's Avatar
well thanks OrrieG
tonight i have made some cups for the the tail lights
yesterday i had made some tubes and tried to cut them in a 30 degree angle
with a belt saw on my work. but could not get a nice clean cut
and wrinkled the tubes
so i took the best of both sizes and cut them open and spread them out,
and then traced over on new sheet metal
rolled the inner tubes
and here the outher tubes
and closed them up, next will be to cut a hole in the outher tubes
to weld the inner tubes in
Old 10-15-2012, 06:15 PM   #290
Kim57
Kim57's Avatar
Looks like you came up with a good solution to your problem.
Kim
My build thread
Old 10-15-2012, 09:48 PM   #291
CURSED GEARS
So simple, yet, trick on the little cups. You make them out of cardboard first?
CURSED GEARS is offline   Reply With Quote
Old 10-15-2012, 11:18 PM   #292
oldman3
oldman3's Avatar
Slick....Jim
Old 10-16-2012, 05:58 PM   #293
63split
63split's Avatar
no i had the tubes cut in an angle and then cut them open and made it a flat piece again and used it as a template
Old 10-16-2012, 06:06 PM   #294
63split
63split's Avatar
have finished up the taillight cups
cut open the outher pieces
and welded in the inner pieces
and a lot of grind work later.......
tomorrow night i will determine the final location and fit them in the fenders
Old 10-16-2012, 06:11 PM   #295
Kim57
Kim57's Avatar
Those came out real nice.
They should look good in the fenders.
Kim
My build thread
Old 10-16-2012, 11:22 PM   #296
oldman3
oldman3's Avatar
Very nice...Jim
Old 10-17-2012, 04:37 PM   #297
63split
63split's Avatar
got them in the fender on one side
Old 10-17-2012, 06:13 PM   #298
hotrod1
56 - autocross
hotrod1's Avatar
I like those taillights. Ever consider making the housings and selling them? I would be interested.
Old 10-17-2012, 09:44 PM   #299
Chevette
Chevette's Avatar
Lights look real good. I like the way you fab'd them.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 10-17-2012, 09:54 PM   #300
Kim57
Kim57's Avatar
Those look sweet.
Kim
My build thread
