#276 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Project#1: Bright Horizons - 68 Swb big block on Air!
Very interested in the should belt upgrade as Id like to do that to my 72
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#277 |
I have herd that the belts from a 73 - 87 will work
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
#278 |
![]() Join Date: Jun 2011
I too would like to see this done
#279 | |
wow.... I want a set now just like these mine are close but not as good lookin as those for sure
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#280 |
VA72C10
![]() Join Date: Mar 2008
I'll be sure to post up the belts when I get them back. Going to look close to factory but not the correct boot.
Accuair elevel setup with dual compressors will be ordered as well as new 68 lower trim and I will get back to working on the cab by early next week. Posted via Mobile Device
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#281 |
oooh Accuair okay I want full pics of every step and a kodak album off all pictures and steps sent to me
#282 |
was just checking to see any progress, with all the work on the shop truck I did not know if anything was being done here or not? Now I know
#283 |
VA72C10
Actually...it's a logistic issue...not the shop truck's fault. I can't get the truck out to weld the roof. Actually, I can't actually even maneuver around the truck right now. It's surrounded by his and customer's vehicles. I'm working on that issue now...
#284 |
![]() Join Date: Sep 2012
interesting ...
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD 70 CHEVY C/10 LWB x 2 ----- SOLD 67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN " Build thread : http://67-72chevytrucks.com/vboard/s...15#post6826315 |
#285 |
VA72C10
It's like paint prison...I see how that happens...just need to work on getting my own shop so I don't rely on others working around my project. I am getting back on it this week...if I can't get to it to work, I will bring it home because progress needs to be made.... other than ordering parts. Things will move quickly once the cab repairs are completed....almost all new sheetmetal for the front clip and bed...
#286 |
VA72C10
Got the roof welded on today. Still have a few small filler patches I have to make and weld in but it's solid and together. Fit came out very good. door gaps actually look better than with the old roof and window measurements are all 100% the same.
#287 |
VA72C10
Will upload pictures later. My phone died on me though so only progress pics.
#288 |
VA72C10
As I mentioned before, if I were to do this again I would use a grinder, band saw, or air saw....not a sawzall with a floppy blade....going through the three different skins that come together caused the blade to deflect between 1/16" to 1/8" leaving a combined "hole" of 1/8" to 1/4" in a few areas...thankfully all the main mating points were spot on so everything has lined up beautifully and openings all look good Here are the pics I got before my phone died...all four posts are now welded and I did a LOT more grinding and die grinding in the grooves after this as well as two of the small patches so it's very solid and almost complete Posted via Mobile Device
#289 |
Great work brother
#290 |
Looks good
#291 |
VA72C10
Thanks guys. Waiting on the accuair parts to arrive...will be fixing up a door to get it ready to go on the truck and getting the hood prepped...then will be getting all the new sheetmetal delivered...
#292 |
shaping up
#293 |
nice build
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
#294 |
how far out is the work on the accuair setup?
#295 |
VA72C10
Thanks! Will know as soon as I get an ETA from them...they told me last week it would be 7-10 days before they shipped because of SEMA. Once I get it I will mock it all up. First though, I need to get the bed off and front clip off/motor pulled...I'm going to finish the roof first, get that body worked and in primer, then hopefully will have my shop truck on the road so I can pick up the front clip and engine/tranny. Will bring the engine/tranny home to paint up the way we have planned and then mock up the accuair...
#296 | |
Man of Mini-Talents
![]() Posted via Mobile Device
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#297 |
VA72C10
![]() ...I imagine most vendors who are at sema have similar lead times ![]()
#298 | |
Man of Mini-Talents
Glad you aren't on the side of the road and need a part. Posted via Mobile Device
#299 |
Going to watch this and probably other projects you do in the future. Hope you didn't get too wet yesterday.
![]() 2005 K2500 Duramax (hauls the junk home) 1967 Chev C10 (hauls a$$) 1970 Suburban (Yukon XL 4 door) 1968 GMC 3/4 ton (sheetmetal only, chassis gone) 2005 Malibu (wife's car, still a Chevy) Project Family Hauler New Home for Chevys (Moved in and working) |
#300 |
VA72C10
Thanks, came through the storm fine. Wasn't bad at all here. Praying for those on the coast and up north who were affected...
