Old 10-03-2012, 09:04 PM   #276
VA72C10
VA72C10
VA72C10's Avatar
Re: Project#2 67-72 Restoration's Shop truck
Dimpled the frame for ps earlier....also working on the trac bar and shock mount install...
Put my battery on the charger and it's already reading 12.5 so I'm not going to charge it....I have it handy if needed but should be good to start up....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-03-2012, 09:06 PM   #277
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by Xeen View Post
Just 9 days to go before the meet, it's time to break out the Superman suit
Some dirty shop clothes will have to do
Originally Posted by BMERDOC View Post
I didn't think you caught that! I tossed and turned until 4 in the morning! I had a busy mind and couldn't sleep. I'm working on 3 hours of sleep today.
Glad to see the trans 'member came and and good thing its not raw...one less thing to paint! Cross your fingers that engine/trans installation goes smoothly!
Sorry you couldn't sleep....thinking of bagging your truck weren't you?
Speaking of the engine/trans install...I sent you a text
Old 10-03-2012, 09:20 PM   #278
Xeen
Xeen's Avatar
My guess is from the time he gets there you two will have the truck running and driving in 6 hours or less.
Ohhhh its a time challenge.
You two can play beat the clock.
Of course that is all predicated on the idea that you are both working and one guy isnt sitting around supervising the other guy working
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-04-2012, 12:08 AM   #279
VA72C10
VA72C10
VA72C10's Avatar
If one of us gets to sit i'd like that job
Will update with pictures and progress tomorrow
Old 10-04-2012, 04:17 AM   #280
VA72C10
VA72C10
VA72C10's Avatar
Who am I kidding...I'll update tonight or is it this morning technically
Have to tighten a few bolts and connect the e-brake and brake lines....also have to swap the lower bolts in the bags....need 4 1/2" and had 5" so they won't tighten all the way of course...
Also going to trim down the rear bumpstop for now....they will be removed completely when I notch it...
Old 10-04-2012, 04:23 AM   #281
VA72C10
VA72C10
VA72C10's Avatar
Couple pics with it still jacked up and one with it on the bumpstops. Also of course will need to run the air management....might do schraeder valves for now...
Old 10-04-2012, 04:27 AM   #282
VA72C10
VA72C10
VA72C10's Avatar
And things always happen for a reason....remember my steering wheel I was upset at myself for ruining the paint with a hurried clear coat?
I'm upset no more
Aircraft stripper took off all the new paint as well as the red paint that was on there....leaving a fawn wheel there are a couple small cracks....but once I finish stripping the paint and hose it off/clean it up....i'm using this wheel the way it is
Old 10-04-2012, 07:27 AM   #283
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Nice job man ! movin right along. nice save on the wheel too !
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 10-04-2012, 07:57 AM   #284
CC69Rat
CC69Rat's Avatar
No notch?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 10-04-2012, 08:04 AM   #285
Bennett68C10
Bennett68C10's Avatar
Looking Good
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 10-04-2012, 09:08 AM   #286
Rusbuilt
Rusbuilt's Avatar
Nice! I want bags!! lol
Rusbuilt is offline   Reply With Quote
Old 10-04-2012, 11:06 AM   #287
VA72C10
VA72C10
VA72C10's Avatar
Thanks!
Originally Posted by CC69Rat View Post
No notch?
The plan is to build my own notch when I put the accuair e-level on. Just running out of time for the 13th to at least have it on the road....
Originally Posted by Bennett--G4L View Post
Looking Good
Thanks!
Me too . I put them on my first truck but never finished that one because of a layoff. Then had one with bags in the rear for a few months that I had to sell to get the cash to finish my blazer project.
So this will be my first bagged driver....been looking forward to it now since I joined the board.....20k+ posts later and I'm here
Old 10-04-2012, 11:10 AM   #288
VA72C10
VA72C10
VA72C10's Avatar
I will also see how it rides with the bag "hats". Have heard some complaints of not enough air in the bags but from what I've read those guys didn't have 2" blocks (2 1/4 effective with the ece trac bar setup) and they rode with the trucks really low....I don't care to ride super low....just at a 4/6 or 5/7 drop....so I "should" have plenty of air in the bags at ride height....
If not, when I notch it I will remove the hats and drill directly through the frame for the air fittings.
Will get some pictures in a few min....
Old 10-04-2012, 11:32 AM   #289
Xeen
Xeen's Avatar
The speed at which you are getting this thing done is just crazy impressive.
You never know you still might have time to get extra things done because if it rains one day before the 13th you can fabricate your notches and then the next morning you can instal them and you will be all set
Old 10-04-2012, 12:19 PM   #290
VA72C10
VA72C10
VA72C10's Avatar
Thanks. Since this is my planned career I've been putting a ton of time in each day. Most days a minimum of 6 hours....some days as many as 14 hours with interruptions between and some of that time buying parts and of course posting on here
Old 10-04-2012, 12:24 PM   #291
VA72C10
VA72C10
VA72C10's Avatar
Old 10-04-2012, 12:25 PM   #292
NewType72
NewType72's Avatar
Can't wait to see the "unfinished"product in the end have been watching with anticipation and drive for working on my own cab to get ready for my big frame off project
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 10-04-2012, 12:50 PM   #293
VA72C10
VA72C10
VA72C10's Avatar
Thanks, will have a lot more still to do on the truck after the meet. Bed wood, new door window seals, new (nice used) door guts, the c-notch and accuair system,.......
And down the road I really want to do an ls swap.
Old 10-04-2012, 01:55 PM   #294
BMERDOC
BMERDOC's Avatar
Sa weet pics of the rear suspension! I'll be bringing most of the tools back and all the brake fluid I can carry. Need anything else?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-04-2012, 02:17 PM   #295
VA72C10
VA72C10
VA72C10's Avatar
Need a 1 1/8" socket but I think I will pick one up to have...if you can bring a better 1/2" drive ratchet than the one I have so I can tighten up everything in the rear that would be great.
Old 10-04-2012, 03:07 PM   #296
Xeen
Xeen's Avatar
I had to buy a Craftsman 3/4" breaker bar and 1-1/8", 1-1/16", 3/4" sockets to remove some of the nuts on the rear end of my truck because I broke three craftsman 1/2" Ratchet Drivers and a 1/2" breaker bar before I realized I needed a 3/4" breaker bar LOL
Old 10-04-2012, 04:16 PM   #297
CC69Rat
CC69Rat's Avatar
Nothing like a tight rear ..
Chad
Old 10-05-2012, 01:00 AM   #298
NewType72
NewType72's Avatar
Best comment on the build so far ^
- Dylan
(209)-985-7721
Old 10-05-2012, 01:05 AM   #299
VA72C10
VA72C10
VA72C10's Avatar
Engine and trans are IN!
Despite a few bolts that didn't want to cooperate we got them mounted up. Bmerdoc also helped me button up the steering so now all that needs is the pump and lines ran...(and the wheel )
HUGE thanks to Nick (bmerdoc) for coming by again after work and staying late. Remember guys, he's working on getting his truck ready for our upcoming meet also!
Stil have to tighten the tubular crossmember bolts and install the torque converter to flywheel bolts but a BIG step forward tonight. Hoping I can get everything else buttoned up so Sunday Sunday Sunday we can fire it up!
Old 10-05-2012, 01:08 AM   #300
VA72C10
VA72C10
VA72C10's Avatar
