02-21-2013, 10:47 PM | #276 |
Re: Chucks 72 Cheyenne Custom Camper
Not sure. Every rubber mat I've bought has been like this. Carpet goes all the way back.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
02-21-2013, 11:10 PM | #277 |
oh ok.
-Rus |
03-30-2013, 07:16 PM | #278 |
Today Rus came up and helped me knock out some things on my trucks. Thanks again Rus! We got the tranny cooloing lines on and the old external tranny cooler off. What a mess. We also looked for a tranny leak. Found that the bolts that come with the new pan have washers that allow fluid to seep out. I'll take the pan off and silicone the pan on and seal around the bolts.
We also took the nasty brown carpet out and I cleaned the floor. There was a plate on the drivers side. I was going to leave it for now but I think I'll pull it and put some metal down and seal around it all. This will be temporary. I'll fix it properly when the truck is redone.
03-30-2013, 07:16 PM | #279 |
the plate lol
03-30-2013, 07:25 PM | #280 |
O dang...same thing they did to me except the plate didnt cover the hole....
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
03-30-2013, 07:52 PM | #281 |
lol
=MATTHEW 69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
03-30-2013, 08:03 PM | #282 |
Square78 installed the gasket pictured. It looks like a hoss to me! Maybe they make a trans pan gasket like this. It has metal inserts around the bolt holes to set the amount of "squeeze".
This is his comment: "Its the Fel-Pro one piece silicone neoprene gasket with metal core. Its pretty much the best one you can get. You dont need to silicone 4 pieces of gasket together around the main-seals and pray it doesnt leak. Its expensive, but its worth it to not have to worry about pulling the pan again anytime soon. Summit racing has them cheap. Im in canada and they seem to retail for around $100. I got mine for $70 or so. I dont mind spending the extra to not have to worry about it." BTW---did you thank the PO for the contribution to your license plate display? That one definitely needs to go on the wall with the background story alongside!
JK |
03-30-2013, 08:11 PM | #283 | |
I'm fixing to pull it and see which state it is. I found a receipt from a Family Dollar in the truck from Wyoming. We'll see. And yes it'll go on the wall above the garage doors. I need one of those oil pan gaskets too. I'll check into both of those. Thanks.
03-30-2013, 08:35 PM | #284 |
I pulled the plate and its Nebraska! I cleaned it and hung it with the same screws that held it to the floor.
It was hiding a crater of a hole lol. I think this truck will eventually get a whole new floor.
03-30-2013, 08:58 PM | #285 |
That looks like the start of what I call a Fred Flintstone situation!
03-30-2013, 10:57 PM | #286 |
I like the plate!
-Rus |
03-30-2013, 11:03 PM | #287 |
LOL i have to get a garage dangit I want to be cool like you guys
03-30-2013, 11:19 PM | #288 |
You are cool! You know that!
03-31-2013, 10:18 AM | #289 |
Got these off of ebay
http://www.ebay.com/itm/110931492354...84.m1439.l2649
03-31-2013, 11:44 AM | #290 |
Good deal! That should seal those valve covers up!
-Rus |
03-31-2013, 08:48 PM | #291 |
I hope so. I'm watching some on ebay that are aluminum.
I did something today that just goes against my train. I so called patched my floor. This will just keep the fumes and rain out at best. I just put some aluminum flashing and silicone down. I will replace the floor of this truck if I ever get to restore it. But for now it gets this temporary cover up. Disclaimer: This is not how I repair my trucks normally and I wouldn't even call it a repair. lol
03-31-2013, 08:52 PM | #292 |
C10 Club Tennessee
Hey, if it works.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
03-31-2013, 08:56 PM | #293 |
I'll turn these.
I'm going to get the under side tomorrow and I'll use a light from the inside of the cab to find any that I can't see.
03-31-2013, 08:57 PM | #294 |
It'll work for a while. Its just half a$$ed
03-31-2013, 10:04 PM | #295 |
Looks better than the license plate!
-Rus |
04-16-2013, 12:50 AM | #296 |
I still have one more hole to plug up on the drivers side cab. I did get my valve covers that I bought off of ebay. I still haven't gotten my gaskets though. They're on the way. I got a front bumper from a board member and cleaned it up and straightened it out some. I think I'll sand down an outer front grille that Rus gave me and try some chrome paint on it. I need to put a new master cylinder on the truck too. So a new list to add to the other.
Master cylinder front grille front bumper floor patch and insulation valve covers / gaskets trailer wiring oil pan / gasket
04-16-2013, 10:58 PM | #297 |
I'm kinda jealous of this truck. It is a perfect driver that you can "piddle" with here and there.
04-16-2013, 11:36 PM | #298 | |
I put a new master cylinder on it tonight and my son helped me bleed the brakes but one caliper on the pass. side had the bleeder break off. And the drivers side although it did bleed, It looked like water came out of the bleeder first. And the pedal doesn't feel any different. So I will get two new calipers and see how that works. I need to check the vacuum on the booster to see if its enough too.
04-16-2013, 11:42 PM | #299 |
New master cylinder, Broke off bleeder, and my valve covers
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 Last edited by thelonerife; 04-17-2013 at 06:27 PM. |
04-16-2013, 11:48 PM | #300 |
I like those covers! Hopefullly I will have some time to piddle soon!
