08-13-2013, 02:31 PM | #276 |
Re: 56 shop truck build
I think she needs to come down to Iowa for a week.
James "Bierkan" Vierkant 1950 3100 on a 1972 C10 Chassis Truck Blog Motorcycle Blog |
08-16-2013, 06:59 AM | #277 |
The old truck is home from having the inspection and exhaust done. Now to get some bumpers on it and start racking up some miles
Posted via Mobile Device Posted via Mobile Device
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
08-16-2013, 08:20 AM | #278 |
08-16-2013, 09:23 AM | #279 |
sounds really nice. I really like your wheels.
Rich My build http://67-72chevytrucks.com/vboard/s...d.php?t=576185 |
08-16-2013, 12:12 PM | #280 |
Congrats on passing inspection!
We don't have to do inspections here unless the truck is from out of state. On the 58 chevy we just transfered the title. The 58 GMC was from out of state so they wanted see it. They didn't like what they saw (no motor, trans, seat, gauges) and told me to finish it. I told them I didn't want to finish it until I had the new title. They didn't care. Once again I like the stance of your truck! |
08-16-2013, 12:15 PM | #281 |
Sounds real nice.
Kim |
08-18-2013, 10:57 AM | #282 |
Well it's been out cruising a couple times but we were having an issue with over heating. After 15 minutes, the temp would climb to 225 so it's now back in our shop receiving a bigger electric fan set up and I'm going to adjust my water/ antifreeze level and add some water wetter to the mix and see what happens. We also decided to remove the doors so we could install the seals with greater ease. We will put it all back together this morning and take it back out to test it again
08-18-2013, 11:33 AM | #283 |
Check your temp gauge Tim.
Have you checked the water pump? I pulled an old pump once and the impeller had been eaten away.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-18-2013, 11:38 AM | #284 |
The gauge is a mechanical one and they rarely go bad. The water pump is brand new. I'm thinking it was because the fan was only a 16" without any shroud on it. It just didn't seem to cooling it off right.
08-18-2013, 11:47 AM | #285 |
It's probably that crappy radiator you installed. Hahaha, just kidding.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
08-18-2013, 07:22 PM | #286 | |
08-19-2013, 07:17 AM | #287 |
I'm not sure of the brand but it looks very similar to the one you posted. I went to th wrecker and got an 18" fan from a 93 Plymouth Voyaguer and mde it fit. We also drained some coolant out to make the mixture have more water than coolant and added some water wetter to the mixture. The gauge was reading fairly hot last night, around 220 so we pulled over, shut the truck off but left the fan unending or 5 minutes. W got back in, started the truck and the gauge read 195. They can't cool down that fast soi think it's the gauge. We will e checking it with a heat sensing gun tonight to see if its the actual gauge
08-19-2013, 09:23 AM | #288 |
08-19-2013, 11:48 AM | #289 |
08-19-2013, 02:00 PM | #290 | |
I take it you haven't been running into any other over heating problems since you swapped out your fan?
08-19-2013, 02:04 PM | #291 |
Very nice build. I like what you have done and gives me an idea on how low you can get with the straight axle still. My daughter wants me to build her a basic truck like this. Great job.
Build thread:55 Cameo R!! http://67-72chevytrucks.com/vboard/s...d.php?t=519851 |
08-19-2013, 03:28 PM | #292 |
this one is pretty low with the axle, leaf spring and wheel and tire combo. It all depends on where and how you're going to drive it. Mine may be a bit to low for where I live and how I drive but it's done and driving. I can now play around with tire and rim combinations to make it ride better than it is currently. The front tires don't have enough side wall to them for my liking. But all in all, it steers great, looks cool as all hell, and sounds even better.
08-19-2013, 05:58 PM | #293 |
Nice truck.
I drove a '59 Chev pickup in high school that was so low the front bumper just cleared a cassette tape standing on end. Just remember to hit speed bumps, etc. at a 45 degree angle and don't be in a hurry. I never did bottom out. |
08-19-2013, 07:30 PM | #294 |
Thanks. It turned to have the exact stance I was hoping for. So far so good on to ottoming out. I have 3" of clearance from the lowest point on the truck, to the ground. Lie you said, just take my time.
BTW your extended cab build is the single coolest extended cab build ive ever run across. Incredible fab skills man Posted via Mobile Device
08-19-2013, 10:12 PM | #295 | |
08-19-2013, 11:49 PM | #296 |
Believe it or not, the steering is actually very nice. You don't really know it doesn't have power steering until you're moving at a crawl speed. Mind you, I still have the 17" steering wheel still on it. But when driving it, the steering wheel always comes back to centre after you are through the turn.
08-20-2013, 01:02 AM | #297 | |
Kim |
08-20-2013, 10:47 AM | #298 |
i absolutely love the way it looks rolling down the road. I bet I've watched that short video 25 times now. I'm going to paint and install the front bumper tomorrow so it'll look even better once that's on
08-20-2013, 04:31 PM | #299 |
Looking good! I can't what til my lives again.
Build for my 1959 Fleetside... http://67-72chevytrucks.com/vboard/s...d.php?t=518308 |
08-20-2013, 05:30 PM | #300 |
Gotta feel great to get to take it for a ride.
It sounds good also..... Question.. I finally got high speed internet and am considering a video camera. Yours seems to capture the sound better than some that I've heard. May I ask what camera you use to record the sound and action? Thanks Jim. |
