Old 05-29-2014, 11:16 PM   #276
mcbassin
Still Learning
mcbassin's Avatar
Re: '72 chevrolet c20 custom camper build "Craig"
Originally Posted by Dean'smeanmachine View Post
thanks guys,
its just regular filler youd get at napa or an auto parts place. nothing special.
like a freind of mine says "all filler is basically the same"
I used to use Bondo brand and Dyanlite fillers back in the 90s. When I started my son's 86 project back in 2009 I kept seeing green looking filler on Overhaulin and similar shows. I researched and found it was an Evercoat product. Let's just say there really is a defference in my opinion. It is more expensive but so is sand paper. The newer fillers sand so much easier than the old sticky stuff. They are less prone to shrinkage which will show up as sand scratches after the paint cures.
I promise you, if you try Evercoat you won't go back. Personally, I prefer the Rage gold. LINK.
Not knocking your choice of filler at all Dean, just sharing what I have learned from 100s of hours of sanding....
Nice progress on the door by the way.
mcbassin is offline   Reply With Quote
Old 05-30-2014, 08:51 AM   #277
Dean'smeanmachine
Dean'smeanmachine's Avatar
I Agree totally. there are many different fillers. what i meant was . filler is filler you know.. not like leading..but any way
thanks for the link, im gonna have to try that stuff. ive seen it too
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 05-30-2014, 08:10 PM   #278
gdavis
gdavis's Avatar
Originally Posted by swamp rat View Post
The stuff I bought has small strands of glass in it. Its supposed to be impervious to moisture.
The bondo that has strands of fiber glass in it is stage two. It is for larger spots and deeper than a dine. Stage three bondo is for spots thinner than a dime. Then you have stage four is for blocking. it fills little spots left in the paint. or stage three bondo.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 06-05-2014, 10:00 PM   #279
Dean'smeanmachine
time for an update
i test fitted some parts (mainly so i can see the truck again lol)
put a skim of filler on the cab corner
and check out my lock knob
Dean
in God we Trust
Old 06-05-2014, 10:35 PM   #280
Mustard72
Mustard72's Avatar
LOL. Another cool idea! Probably pretty good to see it at least sort of back together again, eh?
I haven't noticed the sliding rear window before. I want one of those pretty badly, but haven't found one yet. LMC sells them, but I'm not sure if they are any good. Kind of hit and miss from them for quality some times.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 06-08-2014, 08:54 AM   #281
Dean'smeanmachine
yeah, that was one of the things i liked about this truck. the rear slide is handy
Dean
in God we Trust
Old 06-08-2014, 09:17 AM   #282
Dean'smeanmachine
finally painted the engine. i used duplicolor hugger orange. i cant believe i used almost a quart! but i really like the paint. once its dry, it is really tough paint. i did 2 thin coats and a slightly thicker coat.
Dean
in God we Trust
Old 06-08-2014, 09:21 AM   #283
Dean'smeanmachine
oh, and i also tinkered around and started fabricating the other cab corner!
its actually thicker metal than repop and the shape is closer to original, i had the old cab corner to look at and copy
still needs some more hammer and dolly work. then i will make the other part of the cab corner and weld them together
Dean
in God we Trust
Old 06-08-2014, 09:23 AM   #284
Dean'smeanmachine
the reason i didnt just order the other one is simply becuase i wanted to try something...i like fabbing stuff and not relying on repop peices.
Dean
in God we Trust
Old 06-09-2014, 01:15 AM   #285
Mustard72
Mustard72's Avatar
Cool! The repop pieces don't fit well anyway.
Nick
Old 06-09-2014, 01:25 AM   #286
swamp rat
swamp rat's Avatar
Awesome! Is that the last of the barrel?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-14-2014, 08:21 PM   #287
Dean'smeanmachine
thanks guys, actually the 2nd barrel
Dean
in God we Trust
Old 06-14-2014, 08:25 PM   #288
Dean'smeanmachine
cab corner finished
Dean
in God we Trust
Old 06-14-2014, 08:30 PM   #289
Dean'smeanmachine
engine somewhat reassembled
carb needs to be rebuild. ill do that sometime when the cab is back on. i wanna fire this thing up soon. im getting copper header gaskets it the mail, and i need to get a starter, then ill fire it up and set the timing
Dean
in God we Trust
Old 06-14-2014, 08:32 PM   #290
Dean'smeanmachine
i thought the starter was good but when i tried to turn it over it just clicked , so i pulled it and bench tested it and the motor is shot. will be getting new one
Dean
in God we Trust
Old 06-14-2014, 08:34 PM   #291
Dean'smeanmachine
oh the joy of scraping of undercoating
Dean
in God we Trust
Old 06-15-2014, 11:57 PM   #292
swamp rat
swamp rat's Avatar
Making a lot of progress Dean!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-16-2014, 08:06 AM   #293
mcbassin
Still Learning
mcbassin's Avatar
Very good progress Dean. Nice work on the engine paint too.
Old 06-16-2014, 09:02 PM   #294
Mustard72
Mustard72's Avatar
What're the plans for the bottom of the cab? Looks a lot more solid than mine was, that's for sure.
Nick
Old 06-18-2014, 11:45 AM   #295
Dean'smeanmachine
got some copper header gaskets and had a big cookout and baked in the header paint. then i put them on. the passenger side went on smooth but the drivers side required a BFH....no one will see it
Dean
in God we Trust
Old 06-18-2014, 11:49 AM   #296
Dean'smeanmachine
before and after..
Dean
in God we Trust
Old 06-18-2014, 11:50 AM   #297
Dean'smeanmachine
dont listen to the date on the before pic LOL
Dean
in God we Trust
Old 06-18-2014, 11:53 AM   #298
Dean'smeanmachine
and no the lower a arm is not touching the header. the picture is kind of an illusion. there is about an 8th inch space
Dean
in God we Trust
Old 06-18-2014, 01:57 PM   #299
sduckworth13
sduckworth13's Avatar
Looking pretty good Dean
Scott
sduckworth13 is offline   Reply With Quote
Old 06-18-2014, 02:03 PM   #300
Dean'smeanmachine
im just going to paint it black, that way if it starts to rust i can catch it unlike bedliner or undercoating. ive heard that the moisture gets trapped between bedliner and metal
Dean
in God we Trust
