Old 08-14-2017, 04:29 PM   #276
mcbassin
Still Learning
mcbassin's Avatar
Re: 1970 One Owner Short Step
Originally Posted by boynton View Post
So I'm reaching out because I don't know where to look next. I'm having issues with my a/c. I'm using the stock gm compressor with a vintage a/c setup. My system is still pressurized with freon the clutch is working the way it should on the compressor and my Guatemalan says the system has the correct about of freon in it. The heater shutoff works properly so no hot water in the heater core but no cold air. Any ideas? My lines aren't getting cold or sweating under the hood. I'm guessing the compressor went bad and just isn't cycling the freon or compressing it? Any thoughts or guesses will help. Thanks in advance. I have about 8k miles on the a/c setup. And the compressor was used and now has a total of around 30k miles on it.
I would recommend checking it with a set of gauges. That way you know exactly what pressure you are getting with the clutch engaged. I am running a stock compressor on mine too with an older model Vintage air kit. It is very critical to have the correct gas on those systems. I had mine over charged just a little and it wouldn't cool correctly. I had to evacuate a little gas before it worked properly. I was only able to tell with gauges what the problem was.
FYI,
I picked up adapters for my old R-12 gauges on Amazon. They were cheap and kept me from having to buy a new set. Good luck Boynton
mcbassin is offline   Reply With Quote
Old 08-15-2017, 10:39 AM   #277
boynton
boynton's Avatar
Thanks McBassin. Are you going to make good guys again this year?
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 08-15-2017, 04:06 PM   #278
mcbassin
Still Learning
mcbassin's Avatar
I'm going to try to make again. I don't have firm plans yet though.
Old 08-15-2017, 09:17 PM   #279
boynton
boynton's Avatar
I'm in the same boat. Fairly busy and just trying to get things lined up to make all three days but maybe not.
1970 SWB Step-Side
Old 09-23-2017, 09:42 AM   #280
boynton
boynton's Avatar
Well I'm officially registered for Goodguys next weekend. If y'all are there swing by. I'll have this truck, my dads 71 short wide, and his 68 BBC Camaro.
1970 SWB Step-Side
Old 09-23-2017, 05:15 PM   #281
indymachinist
Great looking truck!
Question... on your marker light gas fill, the filler neck is from a 2500 chevy truck, and the "cup" part that you welded to the fender is from an 06 ford truck? Any more pictures of the cup part?
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 09-24-2017, 08:17 PM   #282
boynton
boynton's Avatar
Yes you have all of that correct. Let me know if you are looking for something more specific.
1970 SWB Step-Side
Old 09-24-2017, 08:24 PM   #283
boynton
boynton's Avatar
Two more.
1970 SWB Step-Side
Old 09-28-2017, 10:08 PM   #284
boynton
boynton's Avatar
Well after three years of planning I finally had enough time and money to pull off my center console. I didn't come up with anything original here but it turned out welll. It has a cup holder set from franks trucks and new trim ring. We smoothed out the grain and painted it the same colors as the truck.
1970 SWB Step-Side
Old 09-28-2017, 10:13 PM   #285
boynton
boynton's Avatar
More
1970 SWB Step-Side
Old 09-28-2017, 10:25 PM   #286
boynton
boynton's Avatar
Headed to goodguys tomorrow. I hope to see some of y'all there!
1970 SWB Step-Side
Old 09-29-2017, 07:19 AM   #287
rgunlock
rgunlock's Avatar
Your console turned out really sharp - nice job!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 09-29-2017, 07:36 AM   #288
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks great
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 09-29-2017, 08:47 AM   #289
builtbyKane
builtbyKane's Avatar
That turned out awesome!!!
builtbyKane is offline   Reply With Quote
Old 09-30-2017, 12:06 AM   #290
boynton
boynton's Avatar
Thanks!
Originally Posted by Ol Blue K20 View Post
Looks great
I appreciate it.
Thank you.
I owe most of the credit to the guy that painted my truck. He lays down some great paint.
In other news I hope to have some pictures to share from Goodguys tomorrow. Here is a teaser from today!
1970 SWB Step-Side
Old 10-02-2017, 07:19 AM   #291
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the console! looks great
Old 06-16-2018, 08:25 PM   #292
boynton
boynton's Avatar
Thank you!
1970 SWB Step-Side
Old 06-16-2018, 08:33 PM   #293
boynton
boynton's Avatar
Angry Re: 1970 One Owner Short Step
I decided to re-do my a/c lines where they connect to the compressor. I originally had a guy weld one the vintage air fittings to the original line, however I’m not sure they ever held really well. I found a company on eBay that sells really nice one piece aluminum fittings. I attached a picture of the part number as I ordered three sets to find this one. These came with all of the pieces needed to hook it up. I did all of this because I lost the Freon out of my truck last season. I was really excited to get the system running. Well that didn’t work out. Apparently I have a line or filter blocked with something because I am getting really high pressure on the low side and normal pressure on the high side. I pulled a vacuum a couple of times just to make sure with the same results. I guess I’m going to have to figure out where vintage air has their filters or common places where they clog up.
1970 SWB Step-Side
Old 03-15-2019, 07:16 PM   #294
boynton
boynton's Avatar
Getting ready for the Friday night Cruze in.
1970 SWB Step-Side
Old 03-15-2019, 09:10 PM   #295
rgunlock
rgunlock's Avatar
Sharp looking fleet! Did you sneak the Camaro into it or someone else's?
Rick
Old 03-16-2019, 12:11 AM   #296
boynton
boynton's Avatar
The red and black truck as well as the camaro are my dads.
1970 SWB Step-Side
Old 03-16-2019, 10:13 AM   #297
Ol Blue K20
Looks cool when they're all together.
Dale
Old 03-17-2019, 11:23 AM   #298
boynton
boynton's Avatar
Yes it is. I think this is the first time all of them have been clean and in the same location at the same time. I had just finished wiping down the green truck and stepped back and saw this picture and thought it was too awesome not to share. My dad and I have built all four of these vehicles in the last 6 years. It’s been great to spend time with him and create some awesome rides.
1970 SWB Step-Side
Old 03-17-2019, 11:47 AM   #299
rgunlock
rgunlock's Avatar
That's great that you and your dad share this common interest and that you are close enough to work on them together. Enjoy the time you can spend on it with him because "project Evelyn" is going to take more and more of your time as she grows!
Rick
Old 03-28-2019, 08:58 PM   #300
boynton
boynton's Avatar
Finally got 10k on the odometer.
1970 SWB Step-Side
