Old 10-24-2020, 02:55 PM   #276
TXgearhead67
Re: 67 SWB First Build
Just read through your thread. Very inspirational. Great job and congratulations on the boy.
TXgearhead67 is offline   Reply With Quote
Old 11-08-2020, 04:08 AM   #277
Scurry67
Originally Posted by TA_C10 View Post
All awesome work man. Really like all these ideas, grill mesh and relocated handle is sweet. I'm in the fence too on cup holders with bench seat. Where do I put them.
Hey thanks TA. Looking forward to the day that i can actually use the cup holder
Glad you enjoyed the read. It has been a fun project so far, but definitely looking forward to seeing that light at the end of the tunnel. Also, much appreciated on the congratulations. Being a dad has been a blast so far. Lots of work but totally worth it!
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 11-08-2020, 04:32 AM   #278
Scurry67
After we put the kiddo down for the night, I Snuck up to the shop to get a small project going and also listen to the WSU cougs on Pac-12 after dark. Made a little progress and my cougs won!
Starting to tear the pickup apart again to go through some final sanding and get all my panels ready for urethane primer and paint. I started with the doors tonight. Got everything seam sealed.
Also, Last weekend i use my dad’s sand blaster cabinet to hit a few small parts. I robbed the door panel trim from some old doors i have. They were in pretty good shape. I’ll need the trim to hold my new door panels in place. Got them in primer last week, too.
Lastly, while i was using my dad’s sand blaster cabinet last weekend, we started flipping through some paint chip books. Really liking this blue/teal color chart. Hope to get a color picked out soon do i can get the paint.
Cheers.
67 SWB First Build
Old 11-22-2020, 10:19 PM   #279
Scurry67
Pickup is being blown back apart. Hopefully next time it’s goes back together it’ll be in a color! Probably a ways out still.
Been painting small random brackets and pieces whenever i get a chance, too.
67 SWB First Build
Old 12-31-2020, 03:17 AM   #280
Scurry67
It’s been over a month since i last updated thread. I managed to accomplish a couple of small items, mostly consisting of sanding.
Had some family swing by a couple weekends ago and i took advantage of the extra bodies to help move my box to a rolling cart. Once on the cart, i did a final sand before urethane primer.
With better access to the back of the cab, I sprayed a couple areas with the feather fill to clean up the body lines a bit more. After a couple rounds of that, the cab is ready for a few coats of urethane primer.
I also finished prepping the front bumper as well as the entire front clip and doors for final primer. My raw hands will appreciate the break from the sand paper.
I put the core support patch off for so long that i had forgotten about it until i saw the damage when dismantling the front clip. It needed a small patch where the battery acid thinned/pitted the metal pretty bad. Also had to weld in a nut that had popped out at some point.
I’ll be meeting up with my parents for a small get together this weekend, so hopefully my dad and I can get my paint order finalized. Also picking up the catalyst for the urethane primer so hopefully that happens in the near future!
Have a happy new year!
Al
67 SWB First Build
Old 12-31-2020, 10:03 AM   #281
MDPotter
MDPotter's Avatar
I know exactly what you're going through - the sanding never seems to end. We've been sanding on our truck for months and decided to take a break from bodywork to work on mechanical items. Besides, it's hard to get the shop warm enough to spray anything right now anyway.
But keep going - one day, all of a sudden, you'll be spraying color!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 01-12-2021, 04:11 PM   #282
Scurry67
Thanks for the words of encouragement. I’m looking forward to switching over to the mechanical side eventually.
67 SWB First Build
Old 01-12-2021, 04:24 PM   #283
Scurry67
I’ve been tinkering in the shop a little bit each night. I’ve got the bed ready for a spray in liner. I went back and forth on whether to paint or line it, but because the wheel tubs and front panel are original and have minor flaws, i think the bed liner will hide it better. So hopefully that happens this weekend.
Also, I’ve been doing a lot of searching here on the forum regarding my partial vin on the frame. From what i can tell, it is a 67 frame, based on the first # being a 7. I had a few reservations on the accuracy of this as my frame has the dimple for power steering, and it also looks like the core support mounts have too large of holes. It’s hard to tell if a previous owner enlarged them or not. Does anyone know if a 67 frame could have power steering?
67 SWB First Build
Old 01-29-2021, 02:34 AM   #284
Scurry67
Quick update.
To make sure i had the right mounts for the core support, i decided to install and align the front clip of the cab. Looks like it is a 67/68 frame for sure!Name:  C28ECCFD-EED8-424C-BC06-CCB69DD4B147.jpg
Finally got to spraying some urethane primer. Started off by spraying the bed floor just so i could get a feel for how it sprayed.
Next i sprayed the cab and front clip. It turned out decent other than a little orange peel.
This week i started to wet sand the urethane primer with 400grit. I have to admit, i actually don’t mind the wet sanding (so far). It’s pretty satisfying feeling the panel get so smooth and looking so straight. Pretty sure I’ll need one more coat of the urethane primer to finish it up before i seal it.
I’m going to try to sneak up to the shop this weekend to make some more progress on the sanding
67 SWB First Build
Old 03-12-2021, 02:04 AM   #285
Scurry67
After wet sanding everything I went through and sprayed another coat of 2k urethane primer. I’ve started up in the sanding again after i let it cure for a bit. Mainly been working in the evenings for an hour here and there.
The cab is looking pretty good. I went through and marked it up with some tape to fill in all the small little pin holes i missed earlier. Also hit a couple spots with seam sealer that i had missed and then the are a few spots that need a small spot prime and sand to get right.
I hope to finish up the sanding in the near future so I can move everything out of the shop and to a potential bodyshop to cleanup anything i missed and to get paint rolling. Looking forward to putting this step of the project behind me.
Pictures aren’t anything special, but nothing exciting has really happened haha.
67 SWB First Build
Old 03-12-2021, 10:43 AM   #286
MDPotter
MDPotter's Avatar
I'm right there with you - not much visual progress to see, but it all pays off when the paint goes on. This is a time-consuming part of bodywork for sure. But it looks like you're close to paint!
Old 03-12-2021, 08:07 PM   #287
TA_C10
TA_C10's Avatar
It's looking good man, keep grinding it out.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 03-13-2021, 11:55 AM   #288
88Stanger
88Stanger's Avatar
Looking Awesome! Great to see another Pacific NW Person here. I was born in Spokane and went to college there, great place.
Great job on the truck!!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 05-03-2021, 01:13 AM   #289
Scurry67
Getting closer!
Hey thanks! It’s a slow go but still motivated!
Much appreciated. Spokane is a pretty great place. It’s been a pretty nice spring here so far... means more yard work and less time on the truck
67 SWB First Build
Old 05-03-2021, 01:21 AM   #290
Scurry67
As i mentioned above, still trying to stay motivated on the project and making the most out of my short stints in the shop!
I have pretty much the entire pickup sanded down to 400. Only a few minor things to go over before i call it good on my end!
Switched gears to the frame. I had been talking forever about getting the frame blasted and I’m finally ready to make it happen. I stripped the frame bare and have it ready for a mobile blaster. Lots of rivets removed for the future suspension
67 SWB First Build
Old 05-03-2021, 01:28 AM   #291
Kronald_70GMC
Kronald_70GMC's Avatar
Awesome! Glad to see your finding time for the truck with the little one. How is the adjustment? I will be in the same place in the next few weeks and I have been going hard on my truck while I still have the time. I am very excited to meet our little one and hope to still get out there too. Great work on the truck!
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 05-10-2021, 12:26 AM   #292
Scurry67
Thanks much! I remember doing the same thing before he was born. I took probably about a month off from the truck and then eventually started getting in the shop an hour here and there after he went to bed. The first few weeks are the most tiring, but it’s totally worth it!
Congrats on the baby, btw. Being a parent is one of the coolest things ever. And a little advice, spend a little time before the baby is born cleaning up your shop. Makes it much easier to stay productive on the project with a clean work area and less time to work on it... ohhh and coffee
67 SWB First Build
Old 05-10-2021, 12:32 AM   #293
Scurry67
Blasting done! Hope to get everything coated in the next couple of weeks and then dive into putting it back together.
Planning on using a POR15 frame product.
67 SWB First Build
Old 05-10-2021, 12:35 AM   #294
Kronald_70GMC
Thanks for the advice man, I appreciate it. Though you will probably think I am weird as I do not drink coffee. Frame looks awesome btw.
Kyle
IG: kyle_ronald
Old 06-02-2021, 12:40 AM   #295
Scurry67
Managed to get the frame and front crossmember in paint. I did a couple coats of POR-15 rust preventative and then a couple coats of POR-15 top coat chassis black. Looks a whole lot cleaner and seems to be very tough. I made sure to test fit the c-notches before paint. Getting the QA1 suspension kit installed is next on the list.
67 SWB First Build
Old 06-02-2021, 12:45 AM   #296
Kronald_70GMC
Looking good! I wish I could afford QA1, it looks super nice and I bet it handles like a dream. Unfortunately I feel that by the time I would pay conversion plus shipping it would be like twice the cost.
Kyle
IG: kyle_ronald
Old 06-28-2021, 01:04 AM   #297
Scurry67
The suspension kit front and back is mostly installed. Biggest pain of the entire project was all the rivets that had to come out. It me roughly a week and a half to get the entire kit installed with an hour here and there.
Started off by reinstalling the front crossmember and wheeling the rear diff to the rear.
I did most of the frame modifications prior to paint, but this one slipped my mind. Just a quick coat of paint over it after I finished.
Suspension front and rear installed mostly. Everything fit together really nicely. Definitely seems like a quality product. Removing Rivets were the toughest part of the entire operation.
Mocked up my fuel cell to makesure there weren’t any conflicts with the Pan head bar and the rear sway bar.
Should have plenty of clearance to my rear filler.
Some more parts are on order and hopefully by end of this summer I’ll have a roller to send off to paint.
67 SWB First Build
Old 06-28-2021, 12:01 PM   #298
CMGreen8812
That's an impressive amount of quality work! Can't wait to see how that paint turns out.
CMGreen8812 is offline   Reply With Quote
Old 06-28-2021, 02:02 PM   #299
TXgearhead67
Lookin good bruh!
Old 06-30-2021, 10:01 AM   #300
88Stanger
88Stanger's Avatar
Damn that is looking great!!
How in the heck are you able to work on it in this crazy stupid heat!?! It is killing me not working on the truck... I will be a bit this weekend though... I am at that point i need to add primer and start the final filler and well in this heat i cannot. So i will be installing Seam Sealer and POR15 in places. I can keep the shop door down, fans going and mini-split on to keep it around 80 inside maybe, otherwise i need to open the shop door to exhaust the paint fumes from the the primer..
Stay safe and cool sir.
