Closed Thread
Old 04-20-2016, 10:42 AM   #1
chevy2tom
chevy2tom's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by Ft.ValloniaStreaker View Post
Thanks Coley, and it sounds a LOT quieter than the original idea......
I'm thinking about doing the same thing (through the fender) off of a cutout
chevy2tom is offline
Old 04-20-2016, 12:17 PM   #2
Ft.ValloniaStreaker
Ft.ValloniaStreaker's Avatar
I'm running a big block, the passenger side was a breeze, the drivers, well....I thought about cutouts and tail pipes, but the cab floor is hot enough as it is.
Ft.ValloniaStreaker is offline
Old 04-20-2016, 09:25 AM   #3
JG67
The big brown truck dropped off a set of 5 lug replacement axles for my 67! Yeah buddy
JG67 is offline
Old 04-20-2016, 10:44 AM   #4
Ekliptix
Ekliptix's Avatar
Installed new shocks on my Dad's 71 big block.
Took my 72 out from winter hibernation and washed it.
Ekliptix is offline
Old 04-20-2016, 10:44 AM   #5
chevy2tom
chevy2tom's Avatar
Homemade side pipes , love it
Old 04-23-2016, 10:25 PM   #6
JWSmith
got the bed and cab all sanded and primer, doors hung and aligned - we are ready to lay down some paint
JWSmith is offline
Old 04-23-2016, 10:54 PM   #7
gottattooz
gottattooz's Avatar
Today on the way home from work, I recessed the grille and lowered the passenger headlight a little with the help of some friends I made in a Hyundai. Also I vented my aluminum radiator, trans cooler and engine oil cooler with the water pump pulley.
- Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline
Old 04-23-2016, 11:21 PM   #8
Metaldoc
Metaldoc's Avatar
- Josh
Ah man that sucks But it's just steel , it can be repaired as long as all is where ok.
Metaldoc is offline
Old 04-24-2016, 12:01 AM   #9
firedemon
- Josh
that _ _ _ _ _ man hope you are ok and insurance covers it
firedemon is offline
Old 04-24-2016, 07:14 AM   #10
kilrcady
- Josh
That sucks
kilrcady is offline
Old 04-24-2016, 11:30 AM   #11
66clow
66clow's Avatar
- Josh
I'm sure the sense of humor didn't come out right away, lol. But glad you have it. I'm sure you'll get it together.
66clow is offline
Old 04-24-2016, 01:08 PM   #12
35boulder
35boulder's Avatar
I took mine for a drive on this nice Sunday morning!
35boulder is offline
Old 04-24-2016, 07:12 PM   #13
CST10
CST10's Avatar
Nice, want to myself but had too much to do.
Nice truck too.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 04-24-2016, 05:36 PM   #14
Possmguts
Possmguts's Avatar
- Josh
Aw man!... thats so sad
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 04-23-2016, 11:05 PM   #15
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Sweet mod........That's a bummer. How's the frame?
I only built shelves above the garage door, for the cowl and an NOS inner grille I couldn't pass up.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 04-24-2016, 12:06 AM   #16
Dimebagdavesc30
Dimebagdavesc30's Avatar
I got the bed on and the bed lights mostly working.
72 C30 283 flatbed
66 silver eagle bus
Dimebagdavesc30 is offline
Old 04-24-2016, 08:49 AM   #17
custom10nut
custom10nut's Avatar
I'm in the process of re painting my rear bumper
custom10nut is offline
Old 04-24-2016, 10:02 AM   #18
tutone
tutone's Avatar
Found out my rear wheel cyls were toast. started yesterday and have the pass side replaced. Brake adjusters were froze. Gonna knock out the driver side later on this aft. Brakes have been a little iffy since I bought the truck.
tutone is offline
Old 04-24-2016, 10:18 AM   #19
RodnRudy
RodnRudy's Avatar
Yesterday actually, finished insulating the fire wall and under cowl with EZ Cool insulation. I applied two layers on the fire wall and one on the cowl area, used 3M head liner spray adhesive, adheres really well.
http://www.amazon.com/ESP-Low-%C2%AE.../dp/B00PX2C8DC
RodnRudy is offline
Old 04-24-2016, 01:59 PM   #20
1quik70
Less than 500 miles into driving the pickup in its current configuration, the trans is toast!
It was just rebuilt, hopefully the builder stands behind it!
1quik70 is offline
Old 04-24-2016, 05:08 PM   #21
Possmguts
Possmguts's Avatar
I hate to ask... but what trans is it? If its a th350 or th400, the detent (kick) down cable is VERY important to get set Correctly... or it will slip the clutches and fry a good trans... Sorry for your luck though..
Old 04-24-2016, 05:32 PM   #22
CK67
Put wheels and tires on which are almost too big. Almost
CK67 is offline
Old 04-25-2016, 03:25 PM   #23
1quik70
TH350, everything was adjusted right, and it was running good. It came apart under full load shifting into 3rd. I got it out last night and it seems as though the input shaft sheered all the splines off inside or I broke the drum. 500hp shifting right at peak power was just a little more than it wanted.
1quik70 is offline
Old 04-26-2016, 10:20 PM   #24
Possmguts
Possmguts's Avatar
ahh... May want to look into a built 200r4 they can handle a bit more than a th350 and you also get an O/D... its the lesser known brother of the 700r4 and you can get then cheaper
Your builder may have used some cheap innerds in it... see what he will stand behind and go from there.
Old 04-25-2016, 04:32 PM   #25
Bocephus69
my TH350 will not shift down on its own, i always i have to manually do it under load (if i feel it needs a downshift). could my kickdown cable not be adjust correctly?
69 C10 fleetside long bed - 6.0/4l80E in progress
Bocephus69 is offline
Closed Thread
