Closed Thread
Old 12-25-2015, 01:13 AM   #3051
In The Ten Ring
Re: What did you do to your truck today? Chapter II
All I did today was box up the NOS grill guards (first things bought from this site) and put those away in the garage with the rest of the "parts cubicle."
In The Ten Ring is offline
Old 12-25-2015, 03:42 AM   #3052
Lancialonnie
After 5 1/2 months at the paint shop I finally got to bring my truck home today! Merry Christmas to me, now I just have months of putting it all back together.
Lancialonnie is offline
Old 12-25-2015, 11:01 AM   #3053
54belair
54belair's Avatar
For various reasons finishing my build has stalled some this year, but things are getting started again. What I did today is really what Ive done over the last week or so. (no new pics uploaded yet)
first I finished cutting and buffing the grille, lower valance and the front fenders. Then I installed the valance, grille, parking lights, fan shroud and clutch fan.
Then the fun started--reinstalling the right front fender. It took three tries to figure out "why" it wasn't fitting. A little history---- when we dis assembled my truck in the beginning we found serious rust in both upper cowl corners. I had to buy a doner cab, both A posts were cut out and new welded back in. We braced the truck many way to insure no twisting or displacement. The new A posts were welded in below the lower door hinge. IN exactly the wrong place!!!! The weld ended up being just slightly thicker than the original post--at exactly where the inner fender brace came the closest to the door post.
Rather than grinding on the door post where it could be seen (requiring repainting in a noticeable place--I opted to notch the inner fender brace (aprox. 1/4"") All went well---fender fits nicely, inner fender was repainted.
Life is good, Santa is home again with Ms. Claus and I may get to start working on the left front side today or tomorrow.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline
Old 12-27-2015, 08:15 PM   #3054
88fordf150
88fordf150's Avatar
Powder Coated a few parts.
Brad handshoe
88fordf150 is offline
Old 12-27-2015, 08:31 PM   #3055
vidman
vidman's Avatar
Shortened my e-brake cable..I cut off the end and silver soldered the new one on at 88" and cut the openings on my backing plates for the brake adjusters.. Dont have any pics of that
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline
Old 12-27-2015, 09:37 PM   #3056
72.4me
got my kick panels in and I had to move the high beam over..
72.4me is offline
Old 12-27-2015, 09:47 PM   #3057
72.4me
fixed
72.4me is offline
Old 12-28-2015, 02:31 AM   #3058
sawyerrm
sawyerrm's Avatar
Great stuff and amazing talent
sawyerrm is offline
Old 12-28-2015, 01:39 PM   #3059
1quik70
After almost 3 years of essentially doing other to my old K/10 it got a little love over the long weekend!
The tranny gave up the ghost in 2013, and with a new business, life, ect. it sat on the back burner for a bit. I did have a trans built, and went ahead and pulled the 454 to fix a clearance issue.
While the motor was out, and the truck was no longer my daily driver I decided a new cam was in order. While finishing up the cam install I dropped a head and broke a valve spring, valve, guide... Off to the machine shop.
I got the engine put back together and installed, and the truck sat for several months. At one point it was shoved outside and covered with a tarp. After moving it to my new shop, I went to putting it all back together and found water in the pan. Not just a few drops, it was filled to the bottom of the pistons!!! Yank the motor back out and realize its no quick fix, back apart it comes and I send the bottom end to the machine shop for a freshen up. I ordered my parts, and re-assembled the engine this past spring. We got it back between the rails, trans installed and then life got in the way again for a few months.
At christmas dinner the old man finally harassed me enough about it that we made plans to spend a couple days working on it over the weekend. Over the course of a few hours we were able to tie up most loose ends, got the T-case back in the truck and are now working on the small details to get it back to running and driving.
After 3 years, I can finally see the light at the end of the tunnel. I have been building cars for over 10 years and NEVER had one apart this long. Its amazing what life can do to our plans sometimes!
1quik70 is offline
Old 12-28-2015, 05:15 PM   #3060
kilrcady
Real projects never end
kilrcady is offline
Old 12-28-2015, 06:34 PM   #3061
saskman02
I finally got around to installing my Undercover Innovations panels. I needed to Dremel out a hole for the A/C and locate some black edging (as they didn't supply enough to trim both panels completely). Also applied some paint to the bottom of the battery box.
1967 C10 SWB Small Window
saskman02 is offline
Old 12-28-2015, 07:53 PM   #3062
firedemon
I want those for mine not only for the cooling but nice place to set the tools
firedemon is offline
Old 12-28-2015, 07:58 PM   #3063
mud.man.rj
mud.man.rj's Avatar
Nice panel, sure cleans up the area and looks factory.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 12-28-2015, 08:18 PM   #3064
Kowtown
Kowtown's Avatar
Installed my new 20" Rally Wheels.!! 275/40/20 on 20x10.5 and 245/45/20 on 20x9.
Kowtown is offline
Old 12-28-2015, 08:21 PM   #3065
Kowtown
Kowtown's Avatar
Kowtown is offline
Old 12-28-2015, 08:24 PM   #3066
Kowtown
Kowtown's Avatar
Kowtown is offline
Old 12-28-2015, 08:49 PM   #3067
JG67
Originally Posted by Kowtown View Post
Attachment 1481869
Nice rig! Mind me asking what the wheels set you back. They are shatp.
JG67 is offline
Old 12-28-2015, 08:58 PM   #3068
mud.man.rj
mud.man.rj's Avatar
Well thought out rims and sizing, really look good.
5.0 4spd std.
7" lift w 35's.
Old 12-28-2015, 09:34 PM   #3069
GTSideSwipe
Cool Re: What did you do to your truck today? Chapter II
Replaced my taillights, licence plate light, park lamp lights and lenses, and dash lights with leds. The instrument lights are definitely a improvement because they were really dim.
GTSideSwipe is offline
Old 12-28-2015, 10:19 PM   #3070
Synestran
Replaced the Hi/Low beam switch so now my headlights works.
Synestran is offline
Old 12-28-2015, 10:57 PM   #3071
Bomp
Bomp's Avatar
Cut out a section of bed side that was a mess and welded in a new one.
Bomp is offline
Old 12-29-2015, 12:05 PM   #3072
mmiddle
mmiddle's Avatar
Well nothing has been going on for the 70, but I did finally put a new engine in Lula-Bell. Another project down one closer to getting back on the 70.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline
Old 12-31-2015, 07:53 PM   #3073
midniteblues
midniteblues's Avatar
Fixed a cracked fitting and filled the fluid up and got the dump bed workin correctly on the 4x4.
It really needs a manual throttle.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 12-31-2015, 09:07 PM   #3074
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by midniteblues View Post
Fixed
Yup.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 12-31-2015, 10:49 PM   #3075
midniteblues
thank you. and i though the phone an i were getting along now all of a sudden its flippin my pics
kinda wishin my camera still worked
Closed Thread
