Old 04-15-2019, 08:31 AM   #3051
Kevin Mac
Kevin Mac's Avatar
Re: What did you do with your truck today, Part 3
Nice hardware Mark, and awesome tuck, you should be very proud.
Mac
Kevin Mac is offline   Reply With Quote
Old 04-15-2019, 09:42 PM   #3052
MARTINSR
MARTINSR's Avatar
I am using an old trick I used years ago on a friends 8" in his Model A that got warped by the shop that welded the spring rests on. My 55 rear had the same issue, so here I am. I heated and cooled the opposite side to bend it back. It looks "ok" with a square running down the side off the flange but I need to bring my other tools I made at home to measure it that I forgot when I brought it to the shop this morning.
Cross your fingers for me.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 04-15-2019, 10:28 PM   #3053
Kevin Mac
Kevin Mac's Avatar
Hey Brian, in the pipefitting world we heat in a diamond pattern to get the pipe to pull to that side. Hope it gets better.
Mac
Old 04-15-2019, 10:30 PM   #3054
Kevin Mac
Kevin Mac's Avatar
[quote=oldman3;8506095]Got out and polished my wheels today...Jim[/quot
Jim what polish do you like? They look nice!
Mac
Old 04-15-2019, 10:59 PM   #3055
MARTINSR
MARTINSR's Avatar
Mac
Ahhhh, a straight up diamond, ok. You can see I have sort of an oval "diamond" so I had the idea but I will go with a straight up Diamond, thanks.
Brian
1948 Chevy pickup
Old 04-15-2019, 11:22 PM   #3056
oldman3
oldman3's Avatar
[quote=Kevin Mac;8507860]
Mac
I've used several, they all seem to work about the same. Mother, Mequires, this time I used Busch, polish and sealer. Have pics in my thread...Jim
oldman3 is offline   Reply With Quote
Old 04-16-2019, 10:00 PM   #3057
MARTINSR
MARTINSR's Avatar
Got the rear axle housing straight, ready for primer.
Brian
1948 Chevy pickup
Old 04-17-2019, 09:46 AM   #3058
MARTINSR
MARTINSR's Avatar
Yep, I was done, or so I thought. As I was putting my tools away it hit me, what about the toe? I hadn't checked that, well, it was off a little so I will be correcting that today.
Brian
1948 Chevy pickup
Old 04-17-2019, 10:05 PM   #3059
MARTINSR
MARTINSR's Avatar
WHOOO HOOOOO! Got the toe corrected, rearend in Marge's trunk and we are home.
Brian
1948 Chevy pickup
Old 04-18-2019, 05:06 AM   #3060
MiraclePieCo
MiraclePieCo's Avatar
One step forward, two steps back.
Intended to clean my door edges for door seal installation today but there was lots of old weatherstrip and glue residue at the front by the hinges that was unreachable so I had to pull my doors off to get at it - unfortunate since I already had them perfectly adjusted.
At least I'll take this opportunity to paint the inner doors and jambs.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 04-18-2019, 10:50 PM   #3061
MARTINSR
MARTINSR's Avatar
I got out there and cleaned up the rear end housing. I will do some spot blasting tomorrow and it's ready for primer, WHOO HOOO!
Brian
1948 Chevy pickup
Old 04-19-2019, 01:47 PM   #3062
idbeast
They got my rear window in, they had to remove 1/4" from both the top and bottom to get it to fit, they need to do the same to the windshield. I bought all new tinted glass, and now I find out it is common to have to have them cut. Oh well, it's only money.
idbeast is offline   Reply With Quote
Old 04-19-2019, 02:28 PM   #3063
DransportGarage
DransportGarage's Avatar
That's the first I've heard of needing the glass cut, but it doesn't surprise me considering most glass is being made in Taiwan. Speaking of surprise, this is another surprise I have to look forward to!
I'm still doing body work on the bed sides when it's not raining, and today (while it's raining) I'm back on the wiring.
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 04-19-2019, 04:30 PM   #3064
MARTINSR
MARTINSR's Avatar
I solved the problem by just chopping the top 3.5 inches so I KNOW I have to cut the glass.
Actually I will just have it all made from scratch being it's flat. Other than the corner windows of course, and I got replacements of those that are laminated so I can cut them unlike the originals which were tempered.
Brian
1948 Chevy pickup
Old 04-19-2019, 10:25 PM   #3065
Black_Sheep
Black_Sheep's Avatar
I needed to pick up a filter and oil for my Plymouth so I jumped in the truck and made a run to the parts store. On the way home I stopped for 10 gallons of fresh gas.
It sure feels good to get behind the wheel again...
Black_Sheep is offline   Reply With Quote
Old 04-19-2019, 11:17 PM   #3066
oldman3
oldman3's Avatar
Mark, that's the way to enjoy them...Jim
Old 04-20-2019, 12:05 AM   #3067
idbeast
They got the windshield in! I get to bring the Beast home tomorrow and start building it now!!!!
Old 04-20-2019, 12:51 AM   #3068
MARTINSR
MARTINSR's Avatar
Right on! OMG that is so damn cool!
Brian
1948 Chevy pickup
Old 04-20-2019, 01:50 AM   #3069
MiraclePieCo
I screwed up today. After painting my door jambs I reinstalled the door. Oops, forgot to install the door seal weatherstrip first! You guys who've done this know how hard it is to get the seal in the front by the hinges with the door on the truck. Oh well, I've got the door adjusted so I'm not taking it off again. It is possible to get the seal on with the door installed, just a lot harder.
Old 04-20-2019, 11:51 PM   #3070
MARTINSR
MARTINSR's Avatar
Today I spent 10 hours driving my Gran Sport to my brothers house so he can make a cam and carb change for me. I used 15 gallons of gas going 170 miles! Yeah, you think I need to change the carb and cam so I can start driving it every day?
Anyway, so my five minutes on the truck was 2 minutes, getting the frame in the garage where the Gran Sport usually sits so I can get it together, WHOOO HOOO!
I have to prime the rearend, and after that I can assembly the chassis and get the cab on the frame, that is my goal this week.
Brian
1948 Chevy pickup
Old 04-21-2019, 12:31 AM   #3071
idbeast
Brian
Now the fun begins as you watch it come together!
My 5 minutes, actually close to 10 hours involved get my friends trailer, (yes, I do have a couple friends who still claim to know me!) and getting the Beast home, then a couple guys on my street offered to help me today when they saw me bring her home! So we got her unloaded and the bed put on!
Old 04-21-2019, 08:56 AM   #3072
oldman3
oldman3's Avatar
Martinsr, nice day for a drive...Jim
idbeast, looking great...Jim
Old 04-21-2019, 11:29 AM   #3073
MARTINSR
MARTINSR's Avatar
You know the funny part, this is a convertible and the day before I was wondering if I will take this long drive with the top down. I got up yesterday to misty overcast! It looked like it would rain the majority of the drive up and back! This photo was taken at a good point.
Today I look out my window next to me right now, there isn't a spec of a cloud in the sky! LOL
Maybe next week when I drive it back we will see.
Brian
1948 Chevy pickup
Old 04-21-2019, 03:51 PM   #3074
MARTINSR
MARTINSR's Avatar
This Easter morning I got out to the garage and arranged some parts, did a little planning on getting the cab onto the frame, got something done. There is no way I would have fired up the compressor or power tools as it's Easter and my neighbors are just feet away from the garage. And it seemed like every single thing I wanted to actually accomplish would have required that. So I kept it to what I did and called it a day.
Brian
1948 Chevy pickup
Old 04-22-2019, 07:05 PM   #3075
MARTINSR
MARTINSR's Avatar
And the first bondo is on the truck WHOOOO HOOOOOO!
Brian
1948 Chevy pickup
