Old 02-09-2012, 01:35 PM   #3076
VA72C10
VA72C10
VA72C10's Avatar
Re: 67 cheby's Dropmember build thread
Originally Posted by 67cheby View Post
that is actually my exact plan, a set of post behind my flip down tag bracket
On my longbed project I used to have, I was going to have the posts and also have a quick connect for an air hose connected to my tank so I could either fill it if the comps broke....or use it to fill my tire/friend's tire if someone got a slow leak flat...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-09-2012, 01:57 PM   #3077
67cheby
67cheby
67cheby's Avatar
great idea on the air hose ! got my SPAL fan controller in today, gonna get this cooling/shroud project wrapped up in the next couple days i hope !!
67cheby is offline   Reply With Quote
Old 02-09-2012, 04:14 PM   #3078
watahyahknow
watahyahknow's Avatar
i was thinking about it but figured that when the power is off the airvalves dont work either
i seen some people with pickuptrucks use industrial co2 cylinders with a simple pressurevalve and no pumps watsoever there getting quite a few hops out of those
if you hook up a small cylinder like one out of a fire extinguisher/paintballgun to the tanks you should be able to lift it one time
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-09-2012, 06:22 PM   #3079
m6z
m6z's Avatar
looking great.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 02-10-2012, 01:24 AM   #3080
superflysteiny
superflysteiny's Avatar
Looken good
superflysteiny is offline   Reply With Quote
Old 02-10-2012, 10:15 AM   #3081
67cheby
67cheby
67cheby's Avatar
Thank you ! here is a pic for JTP67-72, shot of the carrier bearing and the bolt inside the yoke that bolts them together after you press the bearing on. Sorry for the terrible pics i should have slid a piece of white posterboard behind it , i didnt know they came out this dark !
Old 02-10-2012, 07:03 PM   #3082
jtp67-72
jtp67-72's Avatar
That's what i was missing-the yoke unbolting--mine off of the lwb is pressed on over the slider splines--different setup...........thanx for the pic.....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 02-10-2012, 07:08 PM   #3083
67cheby
67cheby
67cheby's Avatar
no problem ,anytime !
Old 02-12-2012, 04:10 AM   #3084
RustenPaines
RustenPaines's Avatar
What color are you going with?
One shop last year quoted $10,000 to paint my Nova. The example car he showed me was a non metallic yellow Mopar. All I could say was you must be kidding. Good luck
69 C10 "Torchered"
RC Crawler Nut
http://www.dorkstarproductions.com/orcrc.com/forum/
RustenPaines is offline   Reply With Quote
Old 02-12-2012, 05:37 PM   #3085
David67
David67's Avatar
Also very interested. Looking good.
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 02-12-2012, 08:48 PM   #3086
67cheby
67cheby
67cheby's Avatar
Going with a really washed out baby blue with white around the bottom
Old 02-12-2012, 09:22 PM   #3087
jasonhall
jasonhall's Avatar
Very Nice color combo!!!
jasonhall is offline   Reply With Quote
Old 02-12-2012, 09:43 PM   #3088
babyblueoval
babyblueoval's Avatar
Copy cat.......
Just kidding, Just kidding.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 02-12-2012, 09:46 PM   #3089
babyblueoval
I think the color you're going with is a little lighter and has a bit of grey tint to it. At least that's what I remember from your previous post of colors.
Jim
Old 02-12-2012, 09:47 PM   #3090
67cheby
67cheby
67cheby's Avatar
Imitation is the most sincere form of flattery . Right !! I just want to be like you !!
Old 02-12-2012, 09:48 PM   #3091
67cheby
67cheby
67cheby's Avatar
Yes that is correct on the color
Old 02-12-2012, 09:56 PM   #3092
babyblueoval
Awww, so nice of you.
Jim
Old 02-13-2012, 01:09 AM   #3093
VA72C10
VA72C10
VA72C10's Avatar
Going to be cool!
So....are you going to do some stone washed denim on the seats?
Old 02-13-2012, 04:16 AM   #3094
RustenPaines
That's a nice
Color combo
69 C10 "Torchered"
RC Crawler Nut
Old 02-13-2012, 09:18 AM   #3095
raull
raull's Avatar
WOW !!!! mike good progress , i cant wait to get back to mine
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 02-13-2012, 10:22 AM   #3096
67cheby
67cheby
67cheby's Avatar
Originally Posted by VA72C10 View Post
Going to be cool!
you are somewhat on the right track !! they will be totally different !! the interior is what will make the whole thing really POP !!
Old 02-13-2012, 10:27 AM   #3097
67cheby
67cheby
67cheby's Avatar
I had about 6 hours in the garage yesterday !! That was NICE ! here is what i accomplished (without a sheetmetal brake) bent everything by hand ......got to get a brake ! After scrapping my original plan because of room , i somewhat loosely followed N2BILLETS lead on the shroud he made (my feeble attempt anyway) i built the upper braces into the top cover , so i could remove the upper mounts for a smoother look...anyway here are the pics
Old 02-13-2012, 10:46 AM   #3098
Bowtie468
Bowtie468's Avatar
That looks great , Mike !!!! Nice work !
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 02-13-2012, 11:01 AM   #3099
67cheby
67cheby
67cheby's Avatar
thanks , i appreciate that, still a little work left, but most of it is done
Old 02-13-2012, 11:54 AM   #3100
oldman3
oldman3's Avatar
Looks great, nice job....Jim
oldman3 is offline   Reply With Quote
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
