Closed Thread
Old 04-18-2014, 02:28 AM   #1
55metalmonkey
Re: What Did You Do With Your Truck Today ?
I gave my truck its first bath to get all the shop dust off it and took it for its first drive. Still a few bugs to sort out but its getting there.
55metalmonkey is offline
Old 04-18-2014, 04:04 AM   #2
TNACUSTOM
Looks Great.
TNACUSTOM is offline
Old 04-19-2014, 03:08 AM   #3
55metalmonkey
Originally Posted by TNACUSTOM View Post
Looks Great.
Old 04-22-2014, 12:00 PM   #4
lt155ruck
lt155ruck's Avatar
Looks great. Look forward to seeing it around Victoria this summer.
lt155ruck is offline
Old 04-18-2014, 08:27 AM   #5
FarmerSid
FarmerSid's Avatar
Got started on a front cross member for my 51 to install Corvette C4 parts on. Thanks to Stockish!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline
Old 04-18-2014, 09:45 PM   #6
Stepside Jim
FarmerSid, a fine job of fabbing up everything, good work.
55metalmonkey, gotta be great to have it move for the first time. You have the near exact paint scheme I'm planning on just slightly different colors. Do you have more picks showing more angles of around the truck, it's looking good from here? Thanks.
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132
Stepside Jim is offline
Old 04-19-2014, 03:06 AM   #7
55metalmonkey
Thanks all, yes I have a video of a full walk around after it was painted. Just go to YouTube and type in my name. I have a few vids on there of the major things as I got them done. And should be uploading a new one now that its mostly done.
Old 04-18-2014, 11:06 PM   #8
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Sid, those look amazing man! Absolutely amazing work buddy, cant wait to see your truck build. Now start that build thread man.
--Josh
STOCKISH is offline
Old 04-19-2014, 03:53 PM   #9
FarmerSid
FarmerSid's Avatar
Thanks Jim! Got the recessed firewall, floors and trans tunnel done. Huge milestone for me. Got like 40 hours in it. Now off for Easter dinner at my parents place. They are building a new house so we are all going to check out the progress.
Happy Easter to all!
C4 IFS & D44 IRS
5.3 HO L33
Old 04-20-2014, 03:18 PM   #10
OrrieG
OrrieG's Avatar
Got the e brake sorted out, ended up welding a new bracket on nice painted frame (arghhh) and redoing the cable connection. Here is the bracket, details in the build thread.
Also figured out that my carb may not be bad either. I put in a solenoid that will increase the idle when the ac is on. I had not but a switch in the circuit yet. When I started the truck it idled a little fast, so I turned it down. Then is stopped idling all together. In the heat of the moment the solenoid was forgotten. Yesterday I discovered the wire had come off the connector, shorted to the manifold and blew the fuse, probably when I was test running, hence the change in idle. When I get some time I am going to pull it out and try it again to see if that is the issue. Hope so, will save me $300 for a new carb.
OrrieG is offline
Old 04-20-2014, 04:35 PM   #11
hsdropout
Installed seats (another steal from OrrieG, thanks.); need to figure out how to remove head rest or get a smaller steering wheel to flip drivers seat up.
Gas pedal needs to go up about six inches otherwise comfortable fit.
Happy Easter!
hsdropout is offline
Old 04-21-2014, 12:53 AM   #12
iowaboynca
iowaboynca's Avatar
That's real sharp what are those seats and column out of
iowaboynca is offline
Old 04-21-2014, 01:40 PM   #13
hsdropout
07 Suburban, third row, Ididit col., Lokar shifter.........
Over spring break, I hope to get glass in, wood bed, wiring kit installed, dash components, sound deadner, carpet, misc. int................what?
My dad used to say:" sh!t in one hand and wish in the other, and see which one fills up first".
Old 04-22-2014, 01:25 AM   #14
Rambow
Rambow's Avatar
Put a gallon of MEK in the old gas tank on Saturday afternoon to soak & try to get rid of the 3" of black nastyness in the bottom.
Drained it out today and hit the inside of the tank with a pressure washer. Followed that with some alcohol to dry it out.
Looks like it all came out!
Inside looks pretty decent. A little bit of surface rust- but overall not bad for an original tank- I think i'm gonna try and run it.
Going to wirebrush some spots on the outside and bottom then hit it with rustoleum and re-install.
Tank will eventually get replaced with an under the bed unit- but for now I just wanted to get it clean enough to run the truck and get it on the road again.
_____________________________________
Ben R.
1953 Chevy 3100
Classic Seat Restorations -Preventing me from working on my own projects since 2009!
Rambow is offline
Old 04-22-2014, 08:20 AM   #15
mgossage
Over the weekend drove 70 miles one way to berryville, va. And back. Drove great 65 mph there and back.
1958 apache 3100
1972 c-30 dump
mgossage is offline
Old 04-22-2014, 08:50 AM   #16
tbrown5079
Painter came to look at the truck last night! Time to strip it down and trailer it to his place. He will do the cab first then feed me parts to keep going. Lots to do!
tbrown's 56 Cameo Build
tbrown5079 is offline
Old 04-26-2014, 10:42 AM   #17
Johnny49
Rear wheels all painted and ready for tires! I was expecting the "dark steel" paint to be a little darker but I think this works. Not overly concerned with the look anyway (especially since the fronts are plain old GM factory wheels), just wanted to clean things up and get down the road. Needed a small repair to one of the fronts, which is done. Now I can do the final cleanup and get those painted as well, then it's off to the used tire store...
Johnny49 is offline
Old 04-26-2014, 04:40 PM   #18
crossfire84
crossfire84's Avatar
put new windlace channels in, removed all the old rusted panel nut retainers and replaced with new. put on left & right rear brake light brackets. installed new glove box and lock. new cig liter, put in new radio speaker grill.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 04-26-2014, 04:52 PM   #19
ghettoluxury
ghettoluxury's Avatar
I pulled the windows and all the trim from my donor cab.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline
Old 04-26-2014, 05:33 PM   #20
FarmerSid
FarmerSid's Avatar
6 friggin hrs of putting gravel back on the friggin driveway! Started filling in the radio hole and steering column recess.
C4 IFS & D44 IRS
5.3 HO L33
Old 04-27-2014, 05:56 PM   #21
OrrieG
OrrieG's Avatar
Modified the throttle linkage to clear the HEI. Details in the build thread.
OrrieG is offline
Old 04-28-2014, 12:11 AM   #22
yossarian19
Hey Dropout, nice truck man! I'm just in the next county... maybe see you at some of the GV car shows?
On my truck, I got the lap belts bolted in & discovered a "gotcha" for using the B-pillar to mount the shoulder belt. After that I called it a night.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline
Old 04-28-2014, 12:11 AM   #23
yossarian19
On my truck, I got the lap belts bolted in & discovered a "gotcha" for using the B-pillar to mount the shoulder belt. Also welded in a patch panel to fill over the old gas tank filler. After that I called it a night.
"Over my head"
Old 04-30-2014, 06:31 PM   #24
FarmerSid
FarmerSid's Avatar
Got a complete 1996 Corvette IRS Dana 44 3:54 ratio for my 51 AD.
C4 IFS & D44 IRS
5.3 HO L33
Old 04-30-2014, 10:19 PM   #25
lgoodso1
Finished with painting the frame yesterday, started on new fuel tank in frame installed all springs and axle housing, assembled front steering linkage and front axle spindles, started on installing front disc brake conversion kit in my 57 3200
lgoodso1 is offline
Closed Thread
