Closed Thread
Old 01-19-2016, 09:42 PM   #3151
Boog
laying low
Boog's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by Possmguts View Post
I was gonna go out and see what I could get done... but then out of nowhere a 3 hour nap happened...
You too? Man, I thought it was just me.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 01-19-2016, 10:58 PM   #3152
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Right after I read this, I decided to take a nap. Worked out nicely.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 01-20-2016, 01:27 AM   #3153
Gillnetter
Gillnetter's Avatar
Got the front clip off today.
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline
Old 01-23-2016, 03:52 AM   #3154
OregonNed
OregonNed's Avatar
New wipers put on tonight. Arms and blades.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 01-23-2016, 09:33 AM   #3155
Econman
Econman's Avatar
Bought and delivered both cab corners to body shop. Progress being made.
Econman is offline
Old 01-23-2016, 11:28 AM   #3156
flashed
What are your plans for heat/air ?
flashed is offline
Old 01-23-2016, 11:32 AM   #3157
Econman
Econman's Avatar
Vintage Air. The fresh air vent orifices were totally rotted out, so I opted to cut them off outside and patch the holes to smooth the kick panels for a cleaner look and better watershed from the cowl.
Econman is offline
Old 01-23-2016, 11:46 AM   #3158
flashed
I think you will be happy with that ,if you have not bought it yet check out Nsane Hotrodz ,he hooked me up with a good deal.
flashed is offline
Old 01-23-2016, 11:54 AM   #3159
Econman
Econman's Avatar
I drove up and picked up the cab corners from Dewayne yesterday. Nice guy.
Econman is offline
Old 01-23-2016, 12:02 PM   #3160
flashed
I was supposed to pick up my 72 truck from him today ,this damn snow messed me up ,now I hope to get up there a week from tomorrow .I have not met him in person ,just on the phone but he has done me right .I will definitely use his shop in the future .
flashed is offline
Old 01-23-2016, 12:39 PM   #3161
Econman
Econman's Avatar
http://www.b-rodorcustom.com
This the shop I'm using..
Econman is offline
Old 01-23-2016, 12:49 PM   #3162
Metaldoc
Metaldoc's Avatar
made use of the old washer hose holes, added two more holes to add engine bay lighting. 0.3 watt leds will never kill the battery
Metaldoc is offline
Old 01-23-2016, 06:42 PM   #3163
OregonNed
OregonNed's Avatar
My father in law helped me weld up all the exhaust joint leaks while the bed is off. Currently painting my heater box components to get the heater working again.
Old 01-23-2016, 08:18 PM   #3164
Possmguts
Possmguts's Avatar
did a little more patching on the fender... out with the bondo filled rust holes and in with a new patch... Ill finish up on this one tomorrow...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 01-23-2016, 08:20 PM   #3165
Crushkrew
Crushkrew's Avatar
Completed install of Fitech EFI and took a crappy cell phone vid...
https://m.youtube.com/watch?v=zIqaVJEVBXY
71 C10: Crush10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=650510
Crushkrew is offline
Old 01-23-2016, 08:46 PM   #3166
midniteblues
midniteblues's Avatar
possmgut your really kickin but on that truck.
it wasnt too bad looking when you first got it but your really showing us what we couldnt see. keep it up.
i'll be doing most of the same patch work as econman on this cab i just picked up to build for my 4x4.
yesterday i figured before the snow came i would hit a few jys in the area too see if anything new came in....no trucks but i did find a good light harness off a 71-2 smashed front clip since it was only part of a harness i got it for $4.
when i got the 4x4 it only had 2-3 lugs on each wheel so i got 32 matching lugs
and a set of 67-68 c30 emblems.
and another vac advance mech for the kids truck.it seems he needs one once a year idk why it keeps going out and creating a vac leak.
of course i came back and put my lugs on to go for a short ride around town
in my pile.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 01-23-2016, 08:49 PM   #3167
Synestran
Installed the washer reservoir and bracket that I recently bought. Cleaned up the valve cover, cleaned my air box, found the float on the fuel sender to be full of fuel, adjusted the rocker arms, oh...and installed new seat belts. Passenger seat belt was literally hanging on by a thread.
Ordered a new valve cover gasket and fuel float thing.
Synestran is offline
Old 01-23-2016, 08:56 PM   #3168
Possmguts
Possmguts's Avatar
in my pile.
Thank you sir.. I havnt been to a junk yard in a long time. They're never open when Im home... If I was home more I would be moving a bit faster... but then again if I was home more, I would be broke and couldnt buy squat for it. All the patches Ive been using so far have come from the old passenger side door lol... Ill get that lower front patch ordered for this fender this week so I can finish it up next weekend maybe.
Old 01-23-2016, 09:01 PM   #3169
midniteblues
your welcome,oe steel is the best too use but sometimes the patches are just easier.
i'm fortunate to have a few yards close by and lots of time at this point.
Old 01-23-2016, 09:31 PM   #3170
greywurm
Replaced all 6 cab mounts. My jack wasn't high enough for the two under the radiator but my engine hoist got it lifted just enough to swap out the worn mounts.
Hooked up the heater hoses to see if the heater core leaked... And what would you expect? It leaked... Then followed it up by not popping the cap off the radiator before popping the heater hose off the manifold
71 Long bed C10 w/68 front clip, 350 SBC+HEI, TH350
06 Yukon XL Denali - Stock
greywurm is offline
Old 01-23-2016, 09:55 PM   #3171
Woodnears
Played with aluminum tubing today. This was my first attempt ever bending he stuff. Turned out pretty good I think. A tip for those ever wanting to try this. A bend consumes 1 1/4" of tubing in a 90* bend. I assume different benders differ. I'm waiting on a ridged bender to come then I'll tackle the front lines.
Woodnears is offline
Old 01-23-2016, 10:21 PM   #3172
74baggedbug
Gonna have all this installed in the never ending project
74baggedbug is offline
Old 01-24-2016, 12:46 PM   #3173
68 Stepper
Placed an ordered for a disc brake conversion kit with ECE.
68 Stepper is offline
Old 01-24-2016, 06:03 PM   #3174
tommy3horse
tommy3horse's Avatar
Hello, looks like everyone is busy on the truck, me too. I got the front sway bar installed. Used all grade 8 bolts and nylon nuts. Took her out for a ride and my grin got bigger, handles great.
Next is tackling the leaky oil pan, then...on and on.
Tom
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline
Old 01-24-2016, 06:18 PM   #3175
88fordf150
88fordf150's Avatar
Did a little header and exhaust work to clear the steering shaft.
Brad handshoe
88fordf150 is offline
Closed Thread
