Closed Thread
Old 01-24-2016, 07:06 PM   #3176
chevy2tom
chevy2tom's Avatar
Re: What did you do to your truck today? Chapter II
Sweet fenderwell headers, I've got a set of those on my small block 63 nova wagon. Let's see more pics of your truck!
chevy2tom is offline
Old 01-24-2016, 07:11 PM   #3177
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by tommy3horse View Post
Hello, looks like everyone is busy on the truck, me too. I got the front sway bar installed. Used all grade 8 bolts and nylon nuts. Took her out for a ride and my grin got bigger, handles great.
Next is tackling the leaky oil pan, then...on and on.
Tom
Flip.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 01-24-2016, 07:40 PM   #3178
poway
Originally Posted by Woodnears View Post
Played with aluminum tubing today. This was my first attempt ever bending he stuff. Turned out pretty good I think. A tip for those ever wanting to try this. A bend consumes 1 1/4" of tubing in a 90* bend. I assume different benders differ. I'm waiting on a ridged bender to come then I'll tackle the front lines.
Excellent job!
poway is offline
Old 01-24-2016, 08:44 PM   #3179
Barnfind46
Barnfind46's Avatar
I removed the drive shaft to change the U-joints and found that the bolt on the front shaft that holds the yoke for the second shaft had backed out and the threads are damaged on both the shaft and bolt. It has been rattling around trapped by the U-joint for a while. I also got my new gauges almost done.Still need the Trans Temp gauge.Name:  003.jpg
Barnfind46 is offline
Old 01-24-2016, 11:14 PM   #3180
OregonNed
OregonNed's Avatar
I've about got my heater refurbish done and ready for installation
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 01-25-2016, 10:25 PM   #3181
Econman
Econman's Avatar
Bought 2 OEM doors to replace my rotted out, badly patched doors. Off to be blasted and primed..
Econman is offline
Old 01-26-2016, 10:26 PM   #3182
68 Stepper
Received my Tru-Ram unpolished SS manifolds, hopefully I'll get them installed this weekend.
68 Stepper is offline
Old 01-26-2016, 10:32 PM   #3183
70cst
70cst's Avatar
Pulled my truck out of the barn that was hit by a tornado.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline
Old 01-27-2016, 12:57 AM   #3184
OregonNed
OregonNed's Avatar
Finished my heater box project tonight and she really blows air now!
Old 01-28-2016, 10:55 AM   #3185
73737373
Patina trucks call for patina parts....installed UOS (Used Old Stock) dash pad (wish I had taken a before pic....) and accomplished quite a bit of buff/wax on the interior. PROGRESS!! Note the factory "orange peel" paint finish to the right of the center dash vent.
Supposed to be 70 and sunny on Sat and Sunday here in southwest OK.... sounds like more PROGRESS!!
73737373 is offline
Old 01-28-2016, 11:17 AM   #3186
73737373
Before/after fuel tank filler neck opening. Again, patina trucks call for patina parts. And the "magic formula", Wizards, and a lot of rubbing.
73737373 is offline
Old 01-28-2016, 11:25 AM   #3187
Lanman1972
Lanman1972's Avatar
What did you use for polishing pads? Foam? What color?
That looks great! Thanks
Lanman1972 is offline
Old 01-28-2016, 11:48 AM   #3188
73737373
Smile Re: What did you do to your truck today? Chapter II
Thanks. For the wide/open spaces on the body, I use a Meguiars yellow foam pad, but for what you see in the pics, I used a very nice (thick/fluffy) 100% cotton washcloth. I wet it, wring it out so it's damp, fold it in fours, squirt a little compound on it and away I go. No wet sanding needed on the interior because its usually fairly well protected from the elements. If the oxidation is heavy, I'll wetsand w/2000 and then use the Wizards.
Still have some dirty work to get done. This truck was just about at the "more than I'm capable of accomplishing" point for me because I have to hire out my welding, but it came w/such a strong provenenance and was such a good deal, that it was hard for me to not buy it.
For the welders out there, anyone need some practice?
73737373 is offline
Old 01-28-2016, 05:13 PM   #3189
Sklptrljay
Sklptrljay's Avatar
Looks great! Really inspiring me to do mine. I have some overspray from a rattle can used to paint a camper shell by PO. Would you wet-sand that or maybe just use acetone first?
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline
Old 01-28-2016, 05:17 PM   #3190
Sklptrljay
Sklptrljay's Avatar
Here is a picture for reference.
Old 01-28-2016, 05:49 PM   #3191
73737373
Probably cheapo Walmart 99 cents/can. I'd try the Wizards first, but if it's not taking it off fast enough, 2000 grit. Would not use acetone. The paint is durable, but fragile...make sense? It will look GREAT once you're done.
73737373 is offline
Old 01-28-2016, 06:41 PM   #3192
Lou Boffa
Lou Boffa's Avatar
Those are nice. Let us know when you get them on how they fit and perform. Might have to get me some of that.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline
Old 01-28-2016, 07:34 PM   #3193
Econman
Econman's Avatar
Picked up my passenger door from the blaster today. Took it to the body shop for repair. Repair done and hung already.
Exchanged a bad driver door I'd bought for a better one. Dropping it off at the blaster in the morning.
Rust removal and metal repair on the cab and doors almost finished!
Econman is offline
Old 01-28-2016, 08:04 PM   #3194
Bowtiguy
Bowtiguy's Avatar
After living in Colorado for 12 years, I finally have HEAT in the Garage! no excuses now for finishing everything on my LS swap 68' SWB in time for spring.
Bowtiguy is offline
Old 01-28-2016, 08:11 PM   #3195
Bowtiguy
Bowtiguy's Avatar
First project in HEAT ( its 60 degrees here now, go figure), get the wood bed supports pulled for blasting/powder coating so I can run the bed down to the body shop and get the insides/wheel wells/tailgate/new front bed piece painted to match the rest of the truck before getting the wood floor finished.
Bowtiguy is offline
Old 01-29-2016, 01:39 AM   #3196
88Stanger
88Stanger's Avatar
new dual exhaust installed
88Stanger is offline
Old 01-29-2016, 08:17 PM   #3197
Econman
Econman's Avatar
Talking Re: What did you do to your truck today? Chapter II
Driver door shell went to the blaster. Paid the shop who did the rust repair. Picking it up tomorrow en route to the paint shop.
Econman is offline
Old 01-29-2016, 10:48 PM   #3198
swamp rat
swamp rat's Avatar
Trying my hand at some rust repair:
http://67-72chevytrucks.com/vboard/s...&postcount=863
http://67-72chevytrucks.com/vboard/s...&postcount=867
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline
Old 01-30-2016, 12:37 AM   #3199
Possmguts
Possmguts's Avatar
I see you're using some No Limit stuff on the rear.. I hope its does as nice as they claim it does...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 01-30-2016, 10:13 PM   #3200
Possmguts
Possmguts's Avatar
Found out how bad LMC lower front fender patch panels fit...
Closed Thread
