Old 09-09-2008, 11:01 PM   #301
abadsvt
abadsvt's Avatar
Re: Finally my own build thread!
A couple more pics of the gas tank. The top is just taped on because it moving when i was installing it. The alluminum piece attached to the tank was welded on both sides of the tank.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 09-10-2008, 03:47 AM   #302
watahyahknow
watahyahknow's Avatar
looks like you going to turbo it ......... awesome .
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 09-10-2008, 10:15 AM   #303
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
wow man, incredible job on the tank. The tank itself, the mounts everything.
The baffles in the tank are great, I'm guessing the pick-up will be in the middle chamber? I know some people put a special foam in the tank to help reduce the sloshing, but the baffles are awesome, and maintenance free for all intensive purposes.
I also really dig that mount for the tranny you made.
Def going to be a top notch truck once it's done. Keep up the great work.
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 09-10-2008, 06:19 PM   #304
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
What did you weld the tank with. It looks great.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 09-11-2008, 12:56 AM   #305
abadsvt
abadsvt's Avatar
Turbo's are still up in the air but i got the v-band clamps because it fits through my exhaust holes in the frame to remove section if needed.
Originally Posted by Mordachai View Post
wow man, incredible job on the tank. The tank itself, the mounts everything.The baffles in the tank are great, I'm guessing the pick-up will be in the middle chamber? I know some people put a special foam in the tank to help reduce the sloshing, but the baffles are awesome, and maintenance free for all intensive purposes.I also really dig that mount for the tranny you made.Def going to be a top notch truck once it's done. Keep up the great work.
Thanks for the complements. Yeah the fuel pump and sender is going to go in the middle and a large alluminum blank will be bolted down so you have access to the parts.
Do you mean what process of welding I used or what machine do i have? The gas tank was tig welded and i have a Miller Dynasty 200dx with a coolmate 3 water cooled torch setup. Thanks for the complements
Josh
(Project truck)
Old 09-11-2008, 10:31 AM   #306
Daniel U
Daniel U's Avatar
Very nice Josh. I still would like to see it in person someday. My '54 is in my garage for a while, until my finances get better. Call me when you're in Paso.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 09-11-2008, 03:15 PM   #307
kyull67
kyull67's Avatar
Wow! Nice work.
kyull67 is offline   Reply With Quote
Old 09-12-2008, 10:57 PM   #308
jlaird
jlaird's Avatar
josh,
So the bed structure you built is welded directly to the bedsides?
jlaird is offline   Reply With Quote
Old 09-13-2008, 05:48 PM   #309
abadsvt
abadsvt's Avatar
I agree we will have to meet soon!
Josh
Old 09-13-2008, 05:56 PM   #310
abadsvt
abadsvt's Avatar
Originally Posted by jlaird View Post
josh,
Yeah it is welded directly to the bedsides. The front panel and rear panel are welded where the metal turns 90*. I am also going to weld the front panel to the besides to have a cleaner look. The steel around the tires was built to match the inner fenders so they have something to bolt to.
Josh
(Project truck)
Old 09-18-2008, 06:22 PM   #311
oldstyle
oldstyle's Avatar
Josh,
Your truck is looking so sick dude. Keep up the good work!
oldstyle is offline   Reply With Quote
Old 09-24-2008, 02:54 PM   #312
abadsvt
abadsvt's Avatar
Well i got a little more done. I was able to get the driverside header done but it was a long week. I originally built a "shorty" header but after i got it built i decided that i wanted long tubes and i wanted them equal length primaries. So i started over and built a new header. I did some reasearch and found out that 32" primaries are the ideal length for the LS1's. The final out come was well worth my frustrations because it looks sweet, equal length primaries (which was a pain in the a$$ to design and build), long tube header, all tucked in the frame (nothing is hangin below the frame) and the best part of it all the collector is the exact height as the rest of the exhaust so from the collector through my frame is all the same height so it will be nice and level. I still have to do a little more welding and build the other side but that should be easier or hopefully less frustrating . Anyways here are some pics and in some of the pics the 3rd tube looks like it is close to the frame but it is actually has plenty of clearance.
Josh
(Project truck)
Old 09-24-2008, 02:57 PM   #313
abadsvt
abadsvt's Avatar
A few more of the headers installed. It is kind of hard to see but you get the idea.
Josh
(Project truck)
Old 09-24-2008, 03:05 PM   #314
PBFAB.COM
PBFAB.COM's Avatar
Josh-
That header is a work of art! You should be extremely proud of it!
Now be nice to the rest of us, and give up your sources for all the parts.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-24-2008, 03:10 PM   #315
gringoloco
A guy with a truck
gringoloco's Avatar
Lookin' good! I wish I had your kind of free time...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-24-2008, 03:16 PM   #316
watahyahknow
those headers look awesome , you prolly could make a living making those for others
Old 09-24-2008, 04:41 PM   #317
abadsvt
abadsvt's Avatar
Originally Posted by porterbuilt View Post
Josh-
Nate
Thanks Nate! It was a fun and fustrating to build. All the bends are from SPD which from my research is one best suppliers for manderal bent tubing. They have some of the newest and highest quality machines to bend the tubing so you get almost perfect bends that aren't deformed.. The collectors and the bullets are from Cone Engeering. Very easy to install and they flow slightly better than a welded high dollar collector and a fairly inexpensive. At least what there test say. Here are the links incase you or anyone else is interested.
http://www.coneengineering.com
http://www.spdexhaust.com/
Yeah i have been lucky lately. We have a few huge jobs coming up and we finished all of our work so i am in a transition period which means FREE TIME!!! I don't ever want to work again. I could get my truck done in a month or two
Thanks for the complements! It would be nice to sell some but i don't think many people would pay for the amount of time it took or does take. So i am satisfied just building them for my projects.
Josh
(Project truck)
Old 09-24-2008, 10:04 PM   #318
71'tahoe
71'tahoe's Avatar
Looking good josh! That truck should be one hella driver when your finished. Just replied to your thread over at pro-touring.com Great build bro!!
71'tahoe is offline   Reply With Quote
Old 09-24-2008, 11:29 PM   #319
68 short step
nice headers, you did a great job
68 short step is offline   Reply With Quote
Old 09-25-2008, 12:02 AM   #320
bagged69c10
Awesome! Ive always wanted to try to build a set of headers.
1965 c-10 long bed
1993 Sierra x-cab
Old 09-25-2008, 01:49 AM   #321
abadsvt
abadsvt's Avatar
Hey man!!! Thanks for the complements!! I hope it will be bad a$$. I am trying to build it as best as i can. I wish i had an unlimited amount of money (don't we all) so i can buy every part i wish. Talk to you later
You should give it a try. There not cheaper but you can build them to your specific needs and clearances. It helps if you have a few specific tools. Normal headers (non equal length) would have been much easier. Let me know if you give it a try and need a few tips.
Josh
(Project truck)
Old 09-25-2008, 02:48 PM   #322
Mordachai
Mordachai's Avatar
wow, that header looks awesome.
Nothing like a custom built part!
Old 09-25-2008, 05:12 PM   #323
lowriden58
lowriden58's Avatar
looking good
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 09-25-2008, 08:25 PM   #324
bowtieboy93
bowtieboy93's Avatar
NICE TRUCK!!
i havent seen this build yet
always been a big fan of the slammed ones
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 09-26-2008, 09:54 AM   #325
coneng
coneng's Avatar
Great build Josh. I especially love those headers, you really did an awesome job!
coneng is offline   Reply With Quote
