#301 |
Re: LFD's low buck truck build!
Yea this is a hard one for me, I am a major car addict and trying to go as Low Buck as posible is like asking a coke head to use flower to save money
![]() ![]() Kevin LFD Inc. |
#302 |
Man, that's sweet. Amazing work on the bed. Really makes it look simple.
#303 |
![]() Join Date: Dec 2006
In the mags for under 5k is amazing i don't care who you are. Keven you are a real reality check to thoes of us who get over whelmed by mounting costs, and high dollar shop builds that run across the same mags. It also helps to see someone from home putting it down. (I grew up in Napa But i Spent most of my teenage years all over the lake, winters, ect...) i just might have to come by and say hi when i get back from my deployment...
#304 |
#305 | |
#306 |
Freeeeee Mason...
#307 |
#308 |
![]() Join Date: Oct 2006
Did I miss where you lowered the rear sidemarker down? Or were you just waiting for someone to notice?
#309 |
Started the flip kit tonight by grinding off all the old brackets and some that made no sence. This axel had a set of spring pads on it at one point that was set up for a spring under but they were not original and had been removed already. Then they had a set of bump stop pads and part of some other bracket that was half removed already. So I removed the old spring pads, bump pads and what ever was left of odds and ends.
I then made the start of my new pads. They are 7" long for now and are made out of 2x2x1/4" tube. I will cut the length down after I am finished with mock up. The old pads are set 1/2" above the axel tube but I made these 1" from the tube to the spring giving me an additional 1/2" lower then regular pads. Also the reason they are 7" long is because I had to get them in place and add the weight of the truck so I could check for the tire being center of the wheel opening. Guess what it wasn't! I will need to re-drill the center pin holes about 1 1/2" offset from center in order to shift the axel back to center things up. I also removed the spring center pins and the add a leaf then I installed new pins from the top down so the new spring pads will have a good mount to center on. The new ones were a hole $2.66 for the set and came with new nuts as well. I also re-used the old U bolts for now but I will get new ones before I do any test driving. So here is were things are tonight after 2hr 30min. I like the ride height so far but I will need to get the front done, gas tank installed and set back on the ground for a good look. Then once that is done I will pull the bed back off and set up the air bags and build the C-notch so I don't bottom out. Kevin LFD Inc. $1188.64 73hrs Last edited by Rokcrln; 03-30-2007 at 12:21 AM. |
#310 |
Kind of a before and during shot.
Kevin LFD Inc. |
#311 |
Are you going to use round u bolts so that the plate and nuts will be on the bottom for clearance?
#313 | |
On a side note do you have any picks of your tank installed? Pics of mounts, filler neck and rear crossmember mods needed. This will help with the many ideas I have in my head right now. Kevin LFD Inc. |
#314 |
For those wanting to see more on the flip kit I will be doing a full pic write up after the mock up is finished and it goes back together with bags and notches! That way I can keep all the info (pin location, C-notch dimentions, shock mounts) in one section and not spread over a few pages. I will not be working on this untill next week so it will slow down for a few days. I am heading out to the In-Laws Friday night and to the GoodGuys show on Saturday morning for some part's hunting.
Kevin LFD Inc. |
#315 |
Kevin,
We spoke last thursday and since then you have come along way on project L/B. It looks great, as far as paint the Green/ white would look great. Dan
Dan |
#316 |
It took 1 5/8" to get the rear end centered and it looks so much better now. I will pull the bed soon and notch, bag, weld and shaft teh rear end once the front is rebuilt and back on the ground.
I pulled the front end apart and I am glad to say I found problems ![]() ![]() I will also be doing a full front to rear brake job before it is back on the road. Well here are a few pic of tear down. Kevin LFD Inc. $1188.64 75.5hrs Last edited by Rokcrln; 03-30-2007 at 12:23 AM. |
#317 |
Gotta love getting dirty and greasy huh!? How do you keep from getting too involved when you take the front suspension apart from sayin...let me just clean this here, let me just paint this here, I need to take this apart and clean this better, maybe I should just pull the motor real quick and hit the firewall with some quick color, man that motor is going to look like hell in there, let me take apart real quick and spray some color on it. Those valve covers look cheap now in that nice engine bay, etc. etc.
#318 |
Easy, I have Project Slow Build to remind me to never do that again!!
Plus the fact that this is Low Buck helps keep me under control. I will be bug bombing the front and rear frame with Rust Tough satin black as I go. Kevin LFD Inc. |
#319 |
Amen! My Blazer next to my truck reminds me of that. What pisses me off is that I have built and painted so many vehicles and motorcycles but never my own. I am too picky about letting anyone else work on my projects to speed them up but this new shop I am at, the bodymen are freaking awesome with the bodyfiller work. One of them just hand made the left quarter panel lower extension on an 88 toyota pickup. I told him it was totaled because the part is no longer available and I could not find a used bedside. He started making it from card board and used a punch to "break" the bodylines and then started away with it. I told him to wait and let me get my camera because no one would believe this. I got busy and went to lunch. When I got back he was DONE!! You wouldn't believe it if you saw it.
#320 | |
Thanks! |
#321 |
He took an old hood and removed the inner skin and then used that flat piece of metal to work with, used a straight edge to mark the bodylines, the reason he used the chisel to punch the lines is because we do not have a metal "break" at work. He is from Honduras and said they hand made panels all of the time.
#322 |
Wow, I've been looking at getting a flip kit on my longhorn but as far as I know they don't make them. Now I see why, It's a whole lot of work......but worth it.
Why, Because it's my truck ![]() 1972 Chevy Longhorn, Dropped 4-7 1984 Chevy Shortbed custom Deluxe (Daily Driver) |
#323 | |
You know I think they do make them and even this route is not really that bad if you can weld and have some spare time. Kevin LFD Inc. |
#324 |
Well I got all my front end parts today and got started tearing into it some more. I got the new A-arm cross shafts and pitman arm from Marty over at "East Bay frame & axle" in SanLeandro (510-569-4285). I have delt with this shop in th epast and they are all hot rodders. I went their last week to run my frame splice by them before doing the work and they said it was right on par. I will be taking Low Buck their for it's 4 wheel alignment and I will take my camera this time. They have a cherry fully rebuilt SWB chassie hanging from their ceiling in the main shop! Also Marty told me he would do a LWB to a SWB conversion for about 1k (frame and suspention only) if any one needs a place to go.
Then off to napa auto parts for misc parts I needed like new wheel bearing, seals, frame rebuild in a can (rust tough ![]() I spent 2hrs tonight pulling the A-arm shafts out and removing the ball joints. I used my elect impact to get the cross shaft nuts off and my grinder and air hammer to remove the top ball joints. I then went into the shop and put about 45ton's of power to the lower joints to pop them out. Then I went to the car wash and cleaned things up before starting to spray on some gloss black. The susp parts that I already had with the steering parts were about $450 and the new complete cross shafts and pitman arm were another $321.57 and then another $55.21 at Napa. I hope to get some time on Sunday to put it all back together. Kevin LFD Inc. $2015.42 77.5hrs |
#325 |
and~
