#301 |
Learning As I Go
Re: 69 cst-10
i just read the whole thread and oh my that truck is amazing i wish mine had some power like yours but mines just a 350 with an rv cam and a 4 spd basically stock mines slow compared to yours
1972 Chevy C-20 Longbed 2wd Granny Low with a Crate 350: Air Gap Manifold, Edelbrock 600cfm, HEI, Headers to a 40 series flow (soon to be dual again) |
#302 |
Re: 69 cst-10
Well i would consider mine slow as well seeing as it has sat for over 6 years and only has 60 miles on it. Thanks for taking the time to go through it.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
#303 |
Learning As I Go
Re: 69 cst-10
yeah no problem its one hell of a thread with one mean truck you should take it to a local drag strip or get it dynoed see what a quartermile time would be
#304 |
Re: 69 cst-10
While finishing the Alum bed floor i decided to build a Battery tray to bolt on the frame just behind the cab. Turned out better then i thought. Just going to get a piece of rubber to put under the battery. I also bent a piece of alum to set the battery on so it will protect it from any rocks or whatnot. My youngest brother will be in town next week and we will get the trans in and hope to take it to the 1/8 mile race they have in SD (Race legal) and see what kind of times i can get. may be spank a few imports. Will do some tuning also.
#305 |
Re: 69 cst-10
AH S#*T, its back. While i was at a friends shop using his lift, another guy i know showed up. He is building a 800hp 468 (14.1 BB2x)/th400 and going with a 5k stall. He had a brand new (4-5 runs on the street) Dalenzie 3500 10in stall ($300). Lets just say it woke this RAT up a little so ill be looking into a new cam in the near future. Old one was about 2400 or so and 13in. I took it easy and waited to get rolling before i eased into it. Going sideways @ 40 without even trying to. It hits very nicely.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() Last edited by ripdog28; 10-05-2010 at 11:47 PM. |
#306 |
"something witty here"
Re: 69 cst-10
Im glad shes back together so you can enjoy her some more.
With that 17'' cyclone electric fan it was hard to tell in the pics, but do you have it offset to fit past the water pump? Im not sure if I need a short water pump, I only have like 3.5'' of clearance between the pump and rad. On the flex a lite website the fan looks like its flat and is described as 4'' depth, only way I figure it will work is if the fan isnt as thick at the edges.
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
#307 |
Re: 69 cst-10
The fan guard has a small rub mark from the WP pulley bolt. I have a slight offset but my Rad is off to one side to minimize it. I have the 10in on always and the 17in set at 195on/ 180 off so i usually sit about 190. Here is a pic of the current configuration. It is close and had some rubbing (not now) but it works. I should have mounted the motor back another inch or two.
#308 |
Re: 69 cst-10
Im going to do the same but use a 16'' and 12'' added later. I also wish I had moved it back an inch but I didnt want to cut my drive shaft or move my tranny crossmember.
So with that stall does it feel like youre revving high while just cruising, or is that un-affected at all and just helps for a quicker launch? Also what relay did you use? did you use a dual fan relay?
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 Last edited by Wildstreak; 10-05-2010 at 11:40 PM. |
#309 |
Re: 69 cst-10
It revs higher to move but not a crazy amount. Cruising isnt bad but i only put 10 miles on this with a few stop signs. I have a single relay for the big fan. Like i said, the small one is always on so its hard wired to the ignition.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() Last edited by ripdog28; 10-05-2010 at 11:44 PM. |
#310 |
Re: 69 cst-10
Oh yea, it felt good when a guy started rolling down his window in his Titan. I knew what was coming. Next light. Is that a Big Block? I couldn't help but smile. Green: Rolled to about 20 and squeezed the throttle.
#311 |
Re: 69 cst-10
Did you use a one wire alternator? If not could you explain how you wired it, somehow I lose my instructions to the painless harness.
#312 |
Re: 69 cst-10
Yea i have a one wire. If you need, PM me your Email and ill send you a copy of the instructions.
#313 |
Re: 69 cst-10
I actually found my instructions so Im set there, but have another question....lol
When you wired your electric fan in did you use that gray wire in the harness? Is it switch activated? because when I have the key on that wire doesnt have power, and I remember seeing a fan switch wire in the harness for the inside of the cab.
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 Last edited by Wildstreak; 10-09-2010 at 05:45 PM. |
#314 |
Re: 69 cst-10
Gray/Whi 903 (ignition side) needs to connect to Gray/Whi 901 (to Fan). there is a red wired sealed fuse that will need to me somewhere in the mix. I ran the fuse on the Rad support just before the fan thermostat. Hope that fixes it.
#315 |
Re: 69 cst-10
Mine must be different or I am not seeing something. I have a 901 gray/white electric fan (headlight) and a 901 gray/white accessories electric fan switch. In the instructions it says that the 901 accessories is an activation wire for the relay. but have no clue what Im supposed to do with it. Neither wires have key on power which is what the fan relay is supposed to have from that gray wire...
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 Last edited by Wildstreak; 10-10-2010 at 02:19 PM. |
#316 |
Re: 69 cst-10
Well I guess thats what happens when you wire your truck then leave it it for a bit, I had forgotten that there was another wire by the cig lighter wire that was fan switch 903 gray/white that had power. I just hard wired the two together rather than having it on a switch.
#317 |
Re: 69 cst-10
glad to hear it worked.
#318 |
Re: 69 cst-10
So i went through two Mallory 6AL boxes. Possibly from the crappy distributor. I decided to go with the PerTronix Igniter III set up and ditch the Box all together. New Distributor and coil coming in this coming week. Then the bumpers and grill. Then, time to work on the body.
#319 |
Re: 69 cst-10
just checkin back in, like what i see. keep up the good work!!
#320 |
Re: 69 cst-10
Getting so Pi$$ed. almost ready to sell it. Today went for a short ride. Have been hearing a clunk in the rear when i let off and get back into it. Today i found out why when the drive shaft let go. Found one universal cap missing a nut and it came loose. I dropped it into 2nd, hammered it and bang. Wonder how much itll cost to fix the drive shaft now. Got $900 into the damn thing and now its bent a little. The wife will flip if i tell her i need a new one so ill try to work around that and get it fixed if i can.
#321 |
![]() Join Date: Jul 2009
Re: 69 cst-10
Dont give up man. its almost complete. just a few small things that we all know are going to pop up.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
#322 |
Re: 69 cst-10
I expected things to pop up, just last few times it has been $800+ to fix. And i'm really wanting a daily driver and am realizing this isn't going to be one. I have been driving my motorcycle daily for the last 2.5 years and really getting tired of not having a vehicle. Wife drives her new 2010 silverado. I found a 2000 reg cab with a 5.3 supercharged for under 10K. Tempting. I don't know now. just been causing problems.
#323 |
Re: 69 cst-10
Thats just like me man, Ive been On my gixxer for the past few years and just now finally got my truck ready. But things will break, youre just finding the weak links. Stick with the old girl, a few more tweeks and it will be perfect.
#324 |
Re: 69 cst-10
Wow, Wild, when did you get back? I missed you.
#325 |
2WD Jimmy
![]() Join Date: Mar 2005
Re: 69 cst-10
Ripdog;
You have 900 invested in that shaft??? Shoot, my 4" aluminum from inland impire only cost 500! ... and that was with the u-joints and all ![]() |
