10-05-2009, 01:58 PM | #301 |
Under Construction
Re: My build. Project Karma. 71 stepside.
looking good!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
10-05-2009, 06:53 PM | #302 |
Some times you want it to be over ..looks good
10-05-2009, 07:42 PM | #303 |
Saweet project!
1990 Dodge Ram D250 Cummins |
11-10-2009, 04:38 PM | #304 |
I wish I had your patience and money....
You are doing an outstanding job. I can wait to see the results. You are on my bookmarks now. |
11-10-2009, 05:58 PM | #305 | |
PITbut
Currently im building a cheap sandblast cabinet so i can blast my hinges.. Once i have that done i can install my hood and start running some wiring so i can do a mayden voyage on this thing... Some body work and shes ready to roll.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
11-19-2009, 03:35 PM | #306 |
Under Construction
must have updates.........
11-19-2009, 03:37 PM | #307 |
PITbut
IM STILLLL building that little blast cabinet.. It will be operational today.. Once thats done i will get a ton of pics of that, then i can do my hinges, then ON WITH The assembly and some minor wiring...
Pics to come..
11-19-2009, 03:48 PM | #308 |
Under Construction
Sweet... looking forward to your blasting cabinet and truck pics....
11-23-2009, 12:56 PM | #309 |
PITbut
Ok. So i have spent the last few weekends just tinkering around. I didnt really have a welding cart. I just had this little dinky thing that the bottle liked to fall over all the time.
I picked up a cart for free from work. I took the rack that my welder was on, removed the wheels and welded that to the underside of the cart. Added some bracing for the bottle and now im set. Place for my plasma and welder. I also can put all my welding/grinding tools in one place so i dont have to walk all over looking for the right tool... I added a few hooks to have a place to hang the cords and what not... Cost was a few bucks. Pics.
11-23-2009, 01:00 PM | #310 |
PITbut
The last time i worked on my truck i was getting ready to install my hood.. My hood hinges were so crappy i needed to blast them. I decided i wanted a cabinet to do that. I didnt want to spend over 40 bucks for a cabinet and i know the 99 dollar harbor freight ones arent very big.
So, i proceeded to find a 55 gallon barell and do some work. I cut out to arm holes and used cut a 6 inch muffler apart and welded them into the holes. I then attached the gloves to the end. Bought some angle iron and added a window. Cut open one end for the door. And on the other side there is one fitting that i used off a sink that my vacuum goes in and the other hole my blast hose goes through.. Its pretty friggin ugly but works GREAT..... Now that the hinges are done sandblasting i can put soem paint on them and mount the hood... Then. once thats done im going to get some of the wiring done so i can drive this thing around the block.. Then its back in for paint..
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. Last edited by lyrikz; 11-23-2009 at 01:01 PM. |
12-07-2009, 01:34 PM | #311 |
PITbut
Got some progress. Painted my hinges for my hood. Once i get the hood mounted on, im going to run a few wires so i can drive this beast around the neighborhood. ahahah...
And a silly question. Where does this go and what is this??? I had it blasted so i painted it figuring i would need it. LOL. It has been awhile since i took this thing apart.. Cant ya tell.
12-07-2009, 02:34 PM | #312 |
Under Construction
progress... looking good. I dont recognize that part either.
TTT
12-07-2009, 08:16 PM | #313 |
GEARHEAD
It's for under the steering column by the foot pedals.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
12-09-2009, 10:32 AM | #314 |
Your truck is going to be awesome.
Someday I hope to be in the same boat. --Matt |
12-14-2009, 07:15 PM | #315 | |
PITbut
AHHH HAAAA!!!!! I knew it. I told my buddy that but he really didnt believe me and i honestly couldnt remember where it went. Thank you...
Not much on pics but you get the picture. Can you use everready metal glaze in 45 degree temps??? I wont be painting over it until summer if that matters...
12-15-2009, 08:42 AM | #316 |
GEARHEAD
At least your getting something done. If I had to wait for 45* temps, it would be next April. My heater LP conversion finally came in, so I might have heat in the garage by xmas.
12-15-2009, 11:04 AM | #317 | |
PITbut
Happen to know if you can do body work in that temperature.
12-15-2009, 06:52 PM | #318 | |
GEARHEAD
As for the other stuff, read the label.
12-15-2009, 06:57 PM | #319 |
PITbut
LOL, i knew better. ahaha
12-16-2009, 01:46 AM | #320 |
Restoring a 68 SWB
Good idea on the sandblasting cabinet.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
12-16-2009, 01:35 PM | #321 |
Under Construction
looking like a truck!
01-10-2010, 11:02 AM | #322 |
GEARHEAD
You must have gotten something done by now. Where you at?
01-10-2010, 02:47 PM | #323 |
PITbut
IM here. Im wiring the truck. The engine bay and the valves/compressors. I MIGHTTT have it done today. I have a few more relays to wire up and hide and test out. End of next week i should have the truck started with the key. ahaha Excited/scared... I do have pics of the wiring but i dotn know how interesting that is.
01-13-2010, 01:38 PM | #324 |
PITbut
Heres some feable update pics. Almost done running the wiring. Mostly all of the wiring will be hidden. None running on the fenders... Running the wiring for the valves now. Once i get that done, i will install the guage cluster, and get this thing running...
Just some pics. This is of the relays for the front headlights. Uhh, big ass 6 month old puppy. Got her she was 7lbs. She is now like 400 pounds. ahaha This is what i originally had planned, i just didnt like that many wires on that one junction so i changed it. Changed it to this. Slow burn fuse setup. After taking apart the wiring, this is what i managed to remove. Bunch of junk. I need to run a few new wires so i went to napa and got some new plug ends. this is one installed, boring i know. I finished the front headlight harness.. Im running 4 bulbs up front. I wired it to 4 brights, and 4 low beams. Thats about it for now. once im wired and running and the temperature picks back up i will finish the body work. I dont have any more money for the windows or seats so i dont really know what im going to do once i have it painted. ahaha I have the paint and everything already.. Just doing what doesnt cost me much money now.. I will keep you updated with a video once the air is setup and its running again with the key.
01-13-2010, 03:05 PM | #325 |
Under Construction
nice progress. gonna have to wire my son's soon, and try to hide it some....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 01-13-2010 at 03:06 PM. |
