Re: Here is a "Not Your Typical" 4wd Blazer build
Glad to see you back at it too! Love this build!
.....I am working on it.....
So, whats the best way to adapt my 3" collectors to the 2.5" exhaust tubing? Do I get reducers then weld on flanges? Any part numbers out there to look at? Summit maybe? Thanks
i may have a set ill send you.... Let me take a look
60-66 Nut
![]() ![]() Join Date: Mar 2007
You could go with either a slip on collector reducer, with a band clamp, or weld on a typical 3 bolt flange collector. Either one will need to have a 3" ID....that is assuming your headers have a 3" OD collector. Summit has both.
ill take a look tonight for you.
Come to think of it, I think I already bought the weld on reducers, its been so long, I think I am loosing my mind
60-66 Nut
I have used these before to repair broken flanges on headers.
http://www.summitracing.com/parts/SUM-G4752ID/ I just welded them onto the collectors on the headers. You could also butt weld these if you would rather do it that way. http://www.summitracing.com/parts/SUM-G4752/ I'm going to be trying these on my next exhaust installation. http://www.summitracing.com/parts/SUM-G4770/ You could also go this route, although more $$ http://www.summitracing.com/parts/FLO-15925/
#13 |
60-66 Nut
There is really no reason the slip fit reducers and band clamps won't work. I posted the links to those collectors, because you said you wanted flanges.
#14 |
I was thinking out loud, I just did not want a leaking system. If I dont like these, I will get one of the weld on flanges you posted. Supposedly these clamps have a good seal, we'll see. Thanks
#15 |
60-66 Nut
Those band clamps work well. one of the reasons I like them, is that you can remove them and disassemble your connection easily, Unlike the typical U-bolt style exhaust clamp.
#16 |
The clamps seem to hold really good! I got all my exhaust done yetserday, but the passenger side needs a little bend to go around the transfer case, its barely off, but a little modifications will be needed. Next, working on getting the fuel cell mounted and the plumbing ran...
#17 |
How about like this high quality exhaust from a Jeep I picked up a few years ago?
#18 |
So Many Ideas, So Little Money
damn, coulda paid for a new pipe in the money they spent in clamps!
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
#20 |
GEARHEAD
Do you really want this to be your last post? I know you have been lurking. Whats up my man?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#21 |
subscribed!
Amazing work!
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
#22 |
X2
#24 |
Why would you sell it after all that work? Arenīt you emotionally connected to your blazer?? I know I am to my K20 and nobody could pay me enough to get rid of it!!!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104 68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441 |
#25 |
That roll bar sick!
Posted via Mobile Device |
