#301 |
Re: Project' 69 c10 aka sin.
hi on my 250 i6 there is a flange that slides up and down the exhaust pipe and slips onto the 2 bolts coming out of the exhaust manifold.there is also a ceramic/fibre type washer about 1/4" thick that goes inbetween.its the same size as the exhaust pipe and is champhered both sides-this might be what you are missing.they also come out on 283 v8's with ramshorn manifolds so should be readily available.hope that helps.cool pickumup by the way.
#302 | |
FarmBoy.
There's a donut that goes between the pipe flange and the studs on the manifold. That should be all you need to get it to seal, if I remember right.
-Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
#303 |
Yeah I got her sealed up there.
Bought a new donut and had to weld a flags cup type thing on. But now it's leaking between the intake and manifold. Is there a gasket I need or... Will have a vid up soon.
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
#304 |
Is it possible the oiling hole in the crankshaft had an obstruction in that journal causing a severe lack of oil to the bearing? Thats what it appears to be, but without seein it, it's tough to say.
63 C10 65 Chevy Custom Cab w/ Big Back Window 66 C30 72 skylark w/ 454 65 K10 May the bridges I burn light the way.... ![]() |
#305 |
thanks for the advice could be what happended.
Got the exhuast sealed up at the manifol but now its leaking right below the intake manifold is there a gasket or could it even leak there? vid to come.
#306 | |
FarmBoy.
There's a gasket that goes between the intake and exhaust manifold, since the exhaust provide heat to the bottom of the intake.
-Sam.
#307 |
so what do you do if you run headers?
im going to need a new gasket then cause its leaking but ill have that vid up after school gets out. the truck sounds really cool and strong. the exhaust isn't loud since i got a mufller instead of a glasspack. thrush turbo muffler. cheap. but works and sounds prettty good.
#308 | |
![]() ![]() Join Date: Jul 2002
I think Clifford has an intake that runs the engine water thru it to heat it up. Mine was juts a bit cranky when I had the headers on my six. After the engine warmed up things were OK.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 03-18-2010 at 04:29 PM. |
#309 | |
FarmBoy.
Bill is right. If you run a stock intake with headers, you just have to let it warm up longer, and keep it choked longer, thus coating the intake with fuel so that it runs. When the intake finally warms up, the fuel will be much better atomized, etc etc.
Many of the aftermarket intakes have provisions for water heat that is just tapped in off the thermostat housing, I believe. That way there's a constant heat source, which helps the consistency with which the engine runs. I'm sure you could rig up a water heat to the stock manifold, if you ran headers with it, with just a plate and some lines. But with the carburetion already strangling the engine, it'd be better to step up to an aftermarket. That is, if you're considering playing with the 6 before you build the 8. -Sam.
#310 |
nice headers may be an option.
The six had some power now tho. Damn 2 wheels caught up two me Broke my leg this afternoon. Fractured my fibula. Riding my bmx bike 360ed off a park bench, bailed and landed bad on my foot.
#311 |
i dont know about headers. should have the video up this afternoon.
not much work is going to get done on the c10, maybe getting a car this afternoon.. pics to come here is a pic of what i look like lately and why i wont be wrenching much. ![]() ' pretty upset.
#312 |
Grandpa in the rustmobile...
nice dummy!
leme guess, bycicle dirtbike wich one? what happened im assuming its...broken
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#313 |
idk if im a dummy.... but thanks....
**** happens. if you read the post above that pic it tells the story. Quote... Damn 2 wheels caught up two me Broke my leg this afternoon. Fractured my fibula. Riding my bmx bike 360ed off a park bench, bailed and landed bad on my foot. End Quote. edit... Broke it biking Doing a 360 and rolled my ankle soo ive been kinda bumming as of late.. springs here and i have to wait 6 weeks to do anything... and i may need surgery. the trick was on this bench only i was 3ing off not 180ing. got a video up of the truck now. here it is
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) Last edited by threeonthetree; 03-19-2010 at 06:04 PM. |
#314 |
I didnt mean it to be rude. But thats sweet! No video of the wreck? I guess its better that it wasnt on the dirtbike (faster lol). Now you'll have lots of time to think about truck parts/plans
#315 |
It's cool man.
Pretty dumb I guess
#316 |
got a car today.
have pics up in a bit! pretty cool ol girl
#317 |
what kind what kind? 67 camaro? anything awesomeer than sin? (trucks name)
#318 |
played with my brothers new 62 all day. a 67 camaro. haha i wish. sin;s pretty cool. idk if it beats this old girl.
here are some pics. something to do well my leg heals up. having a lot of trouble getting the motor to run. the valves are stuck and pulling the rocker arm studs out. so we have to pull the head. got it going on the other pistons for a little bit tho. so tomorrow where gonna drain the antifreeze and pull the head. pretty neat little ride may resell but gonna get it road worthy. just needs brakes. has a 2 spd powerglide im not sure what the motor is. a 235 inline six? not sure well her a some mixed pics some of the car and some of the truck like the vids...? 409 someday!!! ![]() me doing all the work haha ![]() valve cover off for the first time..... how do they get like this? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) Last edited by threeonthetree; 03-21-2010 at 08:09 PM. |
#319 |
Bel air
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) Last edited by threeonthetree; 03-21-2010 at 11:06 PM. |
#320 |
wow beautiful impala i wish i had one and both inlines!! i love impalas i used to have a 77, not as good looking it was boxy compared to yours but i loved it. i believe the rockers were like that due to being too loose they worked them self sideways, or PO started on the motor and never finished just put the covers back on, and forgot about it.
#321 | |
we have 2 now. cool motors do you know what motor this is. what came in a impala in 62. yeah they where quite loose so i tightened them down and turned the motor. and the valve being stuck worked the rocker stud out. on 2 intake valves. pulled the intake off and there is gunk in the port and i'm wondering what would clean this up. i think its due to bad gas. i hope to hear this old inline run!
#322 |
SELL!!!! That things fricken sweet!!!!!!!! bag/lower it with diff. steelies/whitewalls and drive it!!!
looks like the same motor in our 53 belair 235 I6 but ours is 3spd. is yours 12v or 6v your lucky thats a sweet car!!!! Your lucky! You crack me up pegleg working on old car. I wish you were closer id give ya a hand. Dont sell. You need another old car. Its really sweet! You can drive this one cause its auto (broken foot). Good luck keep us posted! im assuming its drums up front...whatcha think you've gotta replace? here is a pic of a local's car
#323 | |
FarmBoy.
That's either a 230 or a 250 - the square intake ports give it away. 235/261's had round intake ports.
*****in' car man, That sucker is cleeeeaaaannnn. Is it a Impala, Bel Air, Biscayne...? I see it only has two tail lights, I dunno when Impala's starting running 3 - so I ask. As far as cleaning the ports out. Well, take the intake off, and scrape it out? Hah. If the valves are stick and rocker studs are pulling out...it might be best to pull the head and give it a good cleaning and fix everything before you try to start it up. Don't want to bend a pushrod or worse yet, have a keeper let loose and eat a valve. Still, awesome car. Your brother's? Not gonna lie, I'm a bit jealous. ![]() -Sam.
#324 |
Your jealous too? It looks EXACTLY like our 235, everything looks the exact same, i'll snap a pic tom. eve. after school to compare...
#325 |
It's a bel air
was it worth a grand ? Is the question Yeah my brothers lucky. We pulled her home with my dads 75 gmc. The kids old man hated working on her. And the said it's been in a gardge for 15 years. They said it ran last fall... I don't see how it could. I hope no pistons or valves contacted. What's the best way to drain antifreeze. I remeber on the blazer it was ****ty. I'm glad you guys like it. No big plans yet. Patina. For now. Thinking of just a disk upgrade up front. Haven't had the wheels off. This car only came with engines 235, 285 v8, and a 327 How do you tell oil pan? I know it's not a 250
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) Last edited by threeonthetree; 03-21-2010 at 11:02 PM. |
