Old 04-11-2011, 07:20 AM   #301
mrhino
Re: Silver Dollar
Now I have a Problem, It didn't show up till yesterday. Saturday afternoon, is when we filled the truck at the gas station, as you know I filled it to the top, and then drove home and parked it. no problems. It was a nice day yesterday, so we took the truck out for a drive. we stopped at my parents, and we noticed fuel running out of the fuel fill, we were on a slight incline, and I knew I had it completely full so Ifigured that was it. We decided to burn a little fuel out of it, and take it for a drive. The whole time we were driving fuel was running out of the fill. I got it back home, still running out like it was way to full. So I siphoned some fuel off, not a lot but enough to keep it from running out. My thought was the fuel in the tank was expanding from the heat the 80 degree day, and since it was so full it couldn't vent properly. but after I siphoned it off I let it sit in the sun for a few hours , with no leaks. Until I started it. as soon, as i started it was back to pouring out, shut the truck off, and opened the fill, It is completely full again, right to the top. anybody have any ideas as to why this is happening?
mrhino is offline   Reply With Quote
Old 04-11-2011, 07:42 AM   #302
menace121978
menace121978's Avatar
Re: Silver Dollar
hmmmm.... sounds like the tanks not vented properly and the pressure from the pump is actually collapsing the tank... have you tried just leaving the fill cap off and running her?
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 04-11-2011, 02:21 PM   #303
67C10BUB
67C10BUB's Avatar
Re: Silver Dollar
Is it possible that your return is aerating and causing the fuel to foam up and over?
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 04-12-2011, 07:31 AM   #304
mrhino
Re: Silver Dollar
Boy, That would be a hell of a pump, to collapse a metal tank. I understand what your saying. I do believe it has something to do with the vent system. my vent is a 3/8 hose that pretty much runs along side of the filler hose and then vents into the cap which is suppose to be vented. When I got home from work yesterday, pulled it out in the driveway and started it up, opened the fuel cap and no over flow, so I closed it and let run some more still no overflow. Took it down the road, romped on it. swayed it back and forth still no overflow. I dont understand it. it was pouring out when I put it back in the garage Sunday. It acts as if there was a air bubble in the tank,and has since purged itself, but dont know how thats possible. the only thing i can think of is, it was so full even the vent hose had fuel in it. does that make sense, if so How would I keep the vent hose from filling up as well. thanks for your input, and help.
Old 04-12-2011, 07:35 AM   #305
mrhino
Re: Silver Dollar
I suppose this is possable to, but how would i know thats whats happening, and how would i fix it. I guess i need to better understand the way a fuel tank works. aside from just holding fuel. thank you for you input as well.
Old 04-12-2011, 09:27 AM   #306
menace121978
Re: Silver Dollar
i didn't mean crushing it like a pepsi can! rather than me go back through your thread since i cant remember... how long is your return hose? maybe the regulator is sending back the extra fuel if she was just sitting there idling after you filled up. along with the heat and expansion. is your regulator on the fuel rail at the engine? this has to be something rather simple... i'm thinking man
"Dennis the Menace"
Old 04-12-2011, 10:04 AM   #307
coggonobrien
Re: Silver Dollar
is the vent higher than the fill tube?
coggonobrien is offline   Reply With Quote
Old 04-12-2011, 09:16 PM   #308
mrhino
Re: Silver Dollar
the return hose is the same length as the feed. Maybe 12-15" feet long. They are running side by side. The Regulator is on the fuel rail. I thought about fuel in the line flowing back into the tank, but I drove it home from the station, stop at a few stop lights, idled while I waited on a train and it sat overnight in the garage with no problem, It wasn't until I parked on a slight incline at my parents house the next day. I wonder if thats it, the incline filled the vent hose ( at the back of the tank) with fuel and aloud the air that was in the vent hose to go back into the tank causing the air in the tank . maybe? is that possible?
how much could one, expect fuel to expand. due to heat. I know my gas can for my lawnmower swells up when its hot, but has never lost fuel because of it.
here is a shot of the tank, before the bed was on. The vent is on the right and fill on the left. I ran the vent hose across the top of the tank to run parallel with the fill hose
here you can see the vent hose running along with the fill hose, the vent hose is above the fill hose from just past this photo to the top
yes, but buy only a inch or so.
Old 04-23-2011, 09:34 PM   #309
mrhino
Re: Silver Dollar
Putting the last custom touches on the old girl. installed a auto dimming mirror, with temp, compass with led map lights. works pretty good.
Old 04-23-2011, 11:25 PM   #310
VA72C10
VA72C10
VA72C10's Avatar
Re: Silver Dollar
any resolution to the fuel issue?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-24-2011, 05:20 AM   #311
mrhino
Re: Silver Dollar
Ya Dont fill it up! No, Dont fill it up and park on a incline. That is the best I can come up with. I dont understand why it did that. fill it up again with no issues.
for got to add pics of the mirror
Old 04-24-2011, 09:21 AM   #312
Normy71
Re: Silver Dollar
Like the mirror!
What is the mirror out of and how hard are they to hook up?
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 04-26-2011, 07:59 PM   #313
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Silver Dollar
Nice mirror. I'm guessing you had it so full that when the engine returned fuel, the only place for it to go was out the vented cap. So the same thing would happen if the fuel expanded when it gets hot out. We have some equipment at work that is that way. The operators are supposed to quit adding fuel when it comes to the top one time. Other wise they will have the fill tube and vent plumb full and the return fuel will over flow and act like a syphon and continue to pull fuel out of the tank. Good luck with it!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-01-2011, 09:26 PM   #314
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: Silver Dollar
Very sweet build!! I really like the gauges and rear view mirror.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 05-17-2011, 03:04 PM   #315
thor
thor's Avatar
Re: Silver Dollar
Nice build man! Just read the whole thing. Very cool innovations to save money.
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 05-17-2011, 04:42 PM   #316
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: Silver Dollar
Very nice headlight and wiper knobs. May I ask where you got them?
Old 05-18-2011, 11:43 PM   #317
mrhino
Re: Silver Dollar
Thank you!
I got them through Summit racing. like 3 bucks each.
Old 05-19-2011, 09:47 PM   #318
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: Silver Dollar
Thank you, thank you, mrhino!!
Old 05-20-2011, 02:42 PM   #319
R&K's71
Re: Silver Dollar
Wow just read through your thread and all i can say is congrats on the beautiful truck. You have something to be proud of a family that has no prob helping out. Great family project. Congrats again
R&K's71 is offline   Reply With Quote
Old 05-24-2011, 07:35 AM   #320
mrhino
Re: Silver Dollar
Your Welcome
Thank You
I changed the door handles and window cranks. The ones i had just keep coming loose. I choose handles from the 47-66. they have good clean lines, and they dont have that aftermarket look. what do u guys think.
Old 05-24-2011, 08:17 AM   #321
coggonobrien
Re: Silver Dollar
i like them better
Old 05-24-2011, 09:40 AM   #322
67cheby
67cheby
67cheby's Avatar
Re: Silver Dollar
agree...looks clean
67cheby is offline   Reply With Quote
Old 05-24-2011, 09:58 AM   #323
brossow
Amateur Rust Fighter
brossow's Avatar
Re: Silver Dollar
The stock ones look fine, but I have to be honest and say I like the aftermarket ones better. They continued the "little bit old, little bit new" theme into the door panels. I don't mind newer parts on older trucks, but something just doesn't feel right to me about older parts on newer trucks. Just my opinion, and it looks great no matter what you go with.
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline   Reply With Quote
Old 06-03-2011, 09:03 PM   #324
mrhino
Re: Silver Dollar
I made a video of the truck in action. I plan on listing it for sale soon and thought this video would help.
Old 06-03-2011, 09:18 PM   #325
VA72C10
VA72C10
VA72C10's Avatar
Re: Silver Dollar
nice job on the truck and video. Best wishes on the upcoming sale!
5.3, boss 338, house of kolor, lsx, tank
