#301 |
![]() Join Date: Dec 2010
Re: 1977 Chevy K30 Crew Cab Build
Here's some initial fabrication shots of my side steps. Really like the hoops & step pad look!!!
![]() They initially mounted the actual rail too low & a little too inboard so they're gonna have to move it a bit. Hopefully will get a better shot of the final position before the end of the week. |
#302 |
![]() Join Date: May 2009
This is a cool build!!
#303 |
Here's the front Mile Marker hubs finally installed. They had to machine a groove inside the hub for these to work... Notice the nicely painted OE calipers & upgraded EBC GreenStuff brake pads - should stop nicely!
#304 |
Junk Yartist
Why the groove? Snap ring?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#305 |
And here's the correctly "repositioned" side step bars! They're still not final welded or anything as they wanted me to Ok everything before going into that part... Think they look GREAT & there surely won't be another crew cab out there with ones like these on it!!!
#306 |
#307 |
A few clearer pics of the actual mounts for these rails. Somehow doubt that I'll ever have much trouble with these getting weak or sagging on me!!!
#308 |
Second Chance Program
Those do look good! And very stout too! i didnt realize the frame was so clean already!
#309 |
6>8 Plugless........
![]() Join Date: Sep 2007
Those steps are sweet!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#310 |
Yeah, frame has already been media blasted & powder coated just like the axles. The frame mounts for these step bars will also get added gussets before all the final welding is done.
#311 |
I really love the side steps!
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#312 |
Finally got the correct part number for the A/C condenser so it's all ordered from LMC Truck & en route. The shop will then have everything for the system other than the actual lines (which need to be custom made) & the correct o-rings for the R134a.
#313 |
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
#314 |
Well... For some reason Summit cancelled my order for the left hand door latches (Goodmark) - guess because it kept getting pushed back for whatever reason. Oh well, LMC Truck has them in stock, so I will just place the order with them (like I should'a done in the first place it turns out).
#315 |
Summit just did the same thing today on my cold air kit from Spectre... Must be cleaning out all the back orders I guess.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#316 |
Be nice if they'd ask ya first....
#317 |
I like this truck! It's coming along nicely and it's going to be awesome when it's all done!!
Keep it up dude!
![]() 305 ci | TH350 | NP208 | 60k miles |
#318 |
They used to and I'm sure they got tired of people yelling at them so they quit doing it.
#319 |
Shop's telling me that the Corbeau seat brackets I bought don't fit my truck properly... They called Corbeau & they do have the correct part for my year, but think it has to do with my truck being a crew cab rather than a regular cab, so they'll just have to modify them to work in mine - not a big deal really...
Should have new pics to post tomorrow evening with any luck as well. |
#320 |
Probably needed to have ordered them for a suburban. Oh well. It will all work out in the end.
#321 |
wow very nice work your doing on the man keep it up....
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... ![]() |
#322 |
Well, the shop called & talked to Corbeau for quite a while - apparently they only sell one style bracket for the 73-87's.... No biggie really, seat brackets get modified & mounts changed all the time - plus the shop is GREAT at fab work!
#323 |
Here's some additional pics of the side step assemblies after getting more permanent welding. Still gotta get smoothed & sent out for powder coat a little later on. Also, the bolts you see on the step pads still need to be swapped out with a button head style to match the other stuff on the truck.
#324 |
The Corbeau bucket seats actually got mounted today after they modified the brackets - still gotta final weld it all & "dress it up" a bit. Can't freaking wait to be behind the wheel in these seats!!!!
Factory rear seat will be sent out after paint to be recovered to match the look of these seats, so it'll all tie in pretty well. |
#325 |
Here's another shot of the front hub look too. These are the wheels & tires that came on the truck when I bought - NOT the one's that will be on the finished product! Just wanted to see what the brake calipers looked like through the holes - although the other wheels have round holes & are black in the middle...
