Old 09-18-2011, 06:52 PM   #301
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Re: Rebuild on a shoestring.....continued
I see where you welded the holes from the big tripod mirrors. Have you decided what mirrors your going with? I've got peep mirrors for mine,then I read on here that you can't see very much with them. I'll still use them, because I already have them.
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 09-18-2011, 07:05 PM   #302
BMERDOC
BMERDOC's Avatar
Jonathan, the link to the Meet and Greet doesn't work! Where were you planning to meet? Saturday would be great but Friday will work too. OBTW, nice progress on the truck!!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-18-2011, 11:45 PM   #303
VA72C10
VA72C10
VA72C10's Avatar
I'm going with sport mirrors I have unless I find a really nice set of the original style ones cheap.
Here's the link http://67-72chevytrucks.com/vboard/s...d.php?t=484799
Thanks. truck's going a lot slower than I want and am used to. I am busy but also when I'm home and have no air tools it makes me lazy...i know i can do the same task in 1/4th the time if I wait to do it back at the shop need to score a nice compressor cheap and need somewhere to put it
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-19-2011, 08:16 AM   #304
XxCHEVYMANxX
[QUOTE=VA72C10;4906846]I'm going with sport mirrors I have unless I find a really nice set of the original style ones cheap.
Sport mirrors look good. what did it have originally. mine came with baby rv.
John
Facebook LoL
Old 09-19-2011, 01:40 PM   #305
VA72C10
VA72C10
VA72C10's Avatar
[quote=XxCHEVYMANxX;4907145]
it had the smaller tripods with the big rectangular heads.....they weren't on for long
Old 09-19-2011, 07:09 PM   #306
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
The build's coming along nicely, I just wish i had access to a welder. maybe then I'd be moving along with yours. Keep up the hard work, with the truck and the new baby.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 09-20-2011, 12:01 AM   #307
VA72C10
VA72C10
VA72C10's Avatar
Thanks. I feel blessed for all the help I've gotten from Glenn on this build.
Working on cleaning up the floor. Got the seam sealer cleaned up, took the bench seat out, got the rest of the padding ground off the floor and cleaned up the rest of the floor, and took the mismatched seatbelts out. Will have some pics later. Getting ready to spray rustoleum rusty metal primer on the floor and then top it with the paintable undercoating. Using it because Glenn recommended it (and gave it to me for free ) It dries hard vs a lot of the undercoating that stays sticky.....
Old 09-20-2011, 02:18 AM   #308
VA72C10
VA72C10
VA72C10's Avatar
Well...I'm going to need some more undercoating But I think I can pick up a can tomorrow and spray it before a meeting I have.
First off, I saw this today while looking at paint products and decided it would be good to have in the garage. It's a long lasting extinguisher that is a point and spray can.
Old 09-20-2011, 02:24 AM   #309
VA72C10
VA72C10
VA72C10's Avatar
I'm thinking now I'll buy a can to keep in my car also in case I ever run across an emergency...
Here's the floor before I took the seatbelts out (bolts are loose in the pic
Here's the floor after some more grinding/wire wheeling and blowing it out...
Doesn't look as messy now
Old 09-20-2011, 02:35 AM   #310
VA72C10
VA72C10
VA72C10's Avatar
Here's the next step
Looking better
Then the undercoating
Looking better but ran out. Going to mask off the rockers and apply a second coat on the areas after I finish the first coat everywhere.
Old 09-20-2011, 02:38 AM   #311
chevy88
chevy88's Avatar
You'll never reget having a fire extinguisher. The floor is coming along great, It should last a long time now.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 09-20-2011, 10:58 AM   #312
68 TT
Still plays with trucks
68 TT's Avatar
I was reading on rustoleums site that the rusty metal primer doesn't work well on clean metal and that the clean metal primer works well on lightly rusted metal (like your well cleaned floor) as well as on bare clean metal. It mentioned something about the rusty metal primer needing the rust to make the paint adhere properly. I hope it works out well as you used it.
I will see if I can find the page I was reading and get the real data from it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-20-2011, 01:45 PM   #313
VA72C10
VA72C10
VA72C10's Avatar
Thanks for looking out. I've actually used this primer several times on lightly rusted metal and even a completely cleaned frame with good results and nice durability. The floor is pretty heavily pitted at the front and still rust colored so I wanted something to stop the rust from deteriorating the metal.
Old 09-20-2011, 10:14 PM   #314
VA72C10
VA72C10
VA72C10's Avatar
Thanks, that's the plan...function over form on this one. Hopefully the floor should be solid and it'll look nice once the floor covering goes down.
Old 09-21-2011, 01:29 AM   #315
VA72C10
VA72C10
VA72C10's Avatar
I called oreilly's which is the only place in town with more of the undercoating.....glad I did as the closest store is 25 minutes away and they didn't stock it...but they have three cans coming for me in the morning so I'll pick it up and get the rest of the floor sprayed sometime tomorrow.
Old 09-21-2011, 07:42 AM   #316
Darkrider
Darkrider's Avatar
Nice project! i stumbled upon this thread while looking around the forum. Def gonna re read it a couple times to get a better understanding as to what im in for with my GMC.
Darkrider is offline   Reply With Quote
Old 09-21-2011, 01:32 PM   #317
VA72C10
VA72C10
VA72C10's Avatar
Thanks for checking it out and welcome to the forum!
Old 09-21-2011, 11:32 PM   #318
VA72C10
VA72C10
VA72C10's Avatar
Well, I got the rest of the undercoating...and got some cheaper undercoating for the underside of the cab.
Also found the herculiner bedliner kit for $49 with a $20 mail in rebate at Oreilly's. The quart size was 29 so I think I'm going to get a second full kit (need more than one kit for a longbed) and I'll use the leftovers to do the underside of the rear wheel tubs and the underside of the inner fenders.
So I finished the spots with less than half a can so I started going over the rest of the floor with a second coat. Put one and a half cans on tonight for a total of two and a half cans. I am happy with the look and of course it'll be covered by the mat anyways. ...but it should help with noise as the panels with the coating were already a lot quieter than parts of the same panel without coating when I first applied it.
Old 09-22-2011, 12:14 AM   #319
VA72C10
VA72C10
VA72C10's Avatar
After spraying the floor I decided the air was already full of caustic fumes...so why not spray some carb cleaner....I have a fire extinguisher
SO...I decided to clean up the carb. I'll take it off the intake when I clean and paint the motor, but I felt like cleaning it up a bit tonight....figured I'd get a lot of the overspray off of the hoses and intake because somewhere years ago decided to just spray everything without masking obviously.
Here's the carb after I started...already looking a lot better....forgot to take a good closeup before picture...
Old 09-22-2011, 12:14 AM   #320
VA72C10
VA72C10
VA72C10's Avatar
And after
Old 09-22-2011, 12:25 AM   #321
VA72C10
VA72C10
VA72C10's Avatar
I actually cleaned up more after that but forgot a pic....it'll get cleaned up more when it comes off for the engine paint so I'll get a good pic after that
While under the hood I took some pictures of all the cool original parts and stampings (at least I think they are cool )
Intake
water neck
Rad hose original clamp
Original or NOS upper rad hose
Old 09-22-2011, 12:27 AM   #322
VA72C10
VA72C10
VA72C10's Avatar
Also got some new plug wires off the board to replace the horrible yellow ones.
And here's the floor after drying for a bit..
Old 09-22-2011, 01:17 AM   #323
heeroyue2002
fat old dude
heeroyue2002's Avatar
what did u clean everything with? wire brush and grinder?
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 09-22-2011, 01:19 AM   #324
VA72C10
VA72C10
VA72C10's Avatar
yes, used the grinder with the heavy duty grinding wheel to grind down the welds, then used the twisted cup with the grinder for a lot of the floor, and a wire wheel in the grinder for the hard to reach spots.
Old 09-22-2011, 01:21 AM   #325
VA72C10
VA72C10
VA72C10's Avatar
Looking back at the picture it looks like I see some of the primer showing through...I'll have to get it out in the light and use the last 1/2 can saturday if that's the case. Busy the next couple days including a trip Friday to pick up some parts at Top banana and pick up all the consoles Tim Christian sold me so I can restore them and make some more truck $$$
