04-01-2012, 08:30 PM | #301 |
Re: Mesquite 1966 C10 - LS3 W/Air Ride
Got the power steering hose fixed, that was me the the swivel joint was loose. Pluged the tach into the right spot on the bulkhead and wala it works.
Ran it long enough to get the fan to come on. I'm out of argon gas so can't fix the radiator just yet. It's a very small pin hole. Posted via Mobile Device
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
04-01-2012, 08:35 PM | #302 | ||
04-01-2012, 09:49 PM | #303 |
As she said at the end of the video..SWEET! Great job on your build.
The fleet 94 Chevy 4x4 reg cab 2018 Traverse (wifes car) 1977 SWB stepside 1949 Chevy truck |
04-01-2012, 10:29 PM | #304 |
Congrats on the start up!!!!!!!!! It sounds great!!!!!!!
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
04-01-2012, 10:42 PM | #305 |
Rollin' Old Skool
quoting from the video: "Sweet!"
i gotta agree
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
04-03-2012, 11:21 PM | #306 |
Started working on the bed. 45 year old wood looks every bit of it
Posted via Mobile Device Posted via Mobile Device
04-03-2012, 11:24 PM | #307 |
I think the bed is solid.
04-04-2012, 10:38 AM | #308 |
I got mine fired up as well.. Video came out crappy though.. Always a great sound to hear them fire up for the first time..
62 long box with a little SBC http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
04-04-2012, 03:46 PM | #309 | |
Thanks, even the neighbors like it I agree as well Lots of little details to make it happen, always good when it works.
04-04-2012, 04:15 PM | #310 |
I agree lot of details... stupid things like a brand new fuel line kit to carb..and the fiber rings they send leak. I feel for the most part that quality is long gone as well for the most part any understanding of what we go through to build these trucks or cars and have to deal with poorly made parts or kits.. Money spent and you get the.. well send it back yada yada yada
04-04-2012, 10:27 PM | #311 |
Put the bed on for a test fit. Looks like I will have to raise the the bed floor didn't see that coming. Had to trim the inner panel at the wheel. Pictures are on the bump stop.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
04-04-2012, 10:32 PM | #312 |
The drivers side door did not look like when I bought it. The previous owner did this while loading it.
04-04-2012, 10:35 PM | #313 |
Tires clear just barely.
04-14-2012, 12:24 AM | #314 |
Striped down the cab tonight. The fuel tank brackets were a PITB, did not see that coming. Whoever decided to spot weld them to the thin metal on the back of the cab needs his butt whooped.
04-14-2012, 01:16 AM | #315 |
chevy only
such a nice build!!
CHEVY ONLY... Nothin Else ! |
04-14-2012, 11:37 PM | #316 |
04-14-2012, 11:44 PM | #317 |
Will test fit the cab tomorrow to see how things fit.
04-16-2012, 11:54 PM | #318 |
Got the cab back on. The low hump hits the transmission right at the shifter location. If I'm right my low hump is not removable.
So I'm guessing my only option is to cut and make a custom cover? Any other ideas are welcomed, everything else seems good. Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
04-17-2012, 12:00 AM | #319 |
The 60-66 GMC/Pontiac guy....
Look close, the tunnel covers are bolted on.
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
04-17-2012, 01:47 AM | #320 |
60-66 Nut
Not all of them are bolted in. Some of them are stamped as one piece with the floor.
04-17-2012, 07:20 AM | #321 |
Before you do any cutting get a high hump and you should be able to cut out the stamped section and bolt in the high hump.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
04-17-2012, 12:24 PM | #322 |
Will do, I am now in search of the following:
High Hump Trans Cover Clutch Pedal, mounting hardware and spring Does anyone have a under dash picture of an installed clutch pedal? Thanks,
04-17-2012, 04:19 PM | #323 |
I have, or can get a photo of that clutch pedal for you. I installed one on mine.
I will check your post later when I get home to see if someone has not already beat me to it for you...
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
04-17-2012, 04:59 PM | #324 |
There are 4 clutch pedal setups that I have found on 60-66 GMC/Chevy trucks.
1-GMC V-6 set up mechanical 2-GMC V6 hydraulic 3-Chevy mechanical 4-Chevy hydraulic For mechanical set ups 1 pulls the bell crank (Z-bar) and one pushes and I don't remember which is which. I have both mechanical setups and can photograph them if you need. I also have extra setups laying around loose if you need photos of that. Just let me know.. and thinking about it I have a cab that I can probably take better photos of since it has no gauges etc..
04-17-2012, 05:36 PM | #325 | |
I just need the underdash components not the linkage, I will be using a hydraulic clutch with this truck.
